E34 (1989 - 1995)
Old 03-22-2011, 08:38 PM
ricks5series's Avatar
ricks5series ricks5series is offline
Mein Auto: 525i, Corvette
Originally Posted by E36 Phantom View Post
Good write up, but I just wanted to add a little something: when I had my 94 530i, it did NOT advance to the next code after a brief pause like all the write-ups and procedures say, it continually repeated the same code. I had to push the pedal 5x after each code to make it advance to the next code. I started a thread and some people agreed this was the case with their car and others didn't, so it looks like there's some inconsistency across the models. YMMV.
Disregard
Old 03-23-2011, 05:21 AM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Thanks Chad. I had actually discovered this recently and forgot to put it in the write up. I will edit it.
Hope you are doiing well.
Steve
Steve
Calypso Red 1992 525i with 170K miles
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-23-2011, 04:42 PM
Originally Posted by BMR_LVR View Post
94 does have the stomp test ability. Not sure why yours is not working. I think it is a good chance that the TPS is the culprit on the engine problem.
I wish I knew more about the trans program error. I can't be of much help here.
Did you have either of these problems prior to your recent head rebuild?
Steve
Steve,
My TPS readings are 1.09ohm (closed) - 4.26ohm (fully opened) with no variance in between. So it looks like its ok.
Old 03-23-2011, 05:00 PM
BMR_LVR's Avatar
Humble E34 lover
Originally Posted by ricks5series View Post
Steve,
Well, I'm glad and sad at the same time. I'm glad that the TPS is not bad, but I'm sad that you still don't have an answer. I can't think of anything else at this time.
Good Luck.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 03-23-2011, 10:33 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is offline
King of the Ballers
Mein Auto: Dreier, Fünfer & Siebener
Steve
Doing good Steve, how about you? Sorry to hear about the E36 troubles.
I really wish I (or anyone) had some definitive reason for why and which cars need to have the pedal pressed.
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium //
E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. .
Originally Posted by SlimKlim View Post
You're a derbanana
Old 05-13-2012, 07:22 PM
Costa's Avatar
Costa Costa is offline
Mein Auto: Supercharged E34 540i6
How the hell do you understand what number is being shown.. Does one blink mean one and two blinks mean two?
Old 05-13-2012, 08:01 PM
BMR_LVR's Avatar
Humble E34 lover
Yes.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 05-13-2012, 09:04 PM
Costa's Avatar
Originally Posted by bmr_lvr View Post
yes.
lol...
Old 05-14-2012, 02:05 PM
Costa's Avatar
Can anyone decode this? I don't understand it.. Lol
Old 05-14-2012, 05:50 PM
BMR_LVR's Avatar
Humble E34 lover
I believe that is code 1000 which is what must be present to clear the codes by pressing and holding the accelerator for 10 seconds.
The only thing I can think of is that your stomp succession may have been too fast. You may want to slow it just a tad and see if you get a different result. If not, then I would go ahead and clear the codes and see if any come back when you crank and drive the car again.
Hope this helps.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 10-30-2012, 04:59 PM
Ena01 Ena01 is offline
Mein Auto: 525i and 325is
Hello, I'm having trouble with my 525i 1995. I try the stomp test and nothing happens? Why is that happening?
Old 10-31-2012, 10:11 AM
Mein Auto: 1989 525i M20B25
http://www.bimmerfest.com/forums/sho...65#post5936965
Old 10-31-2012, 10:25 AM
BMR_LVR's Avatar
Humble E34 lover
Does your check engine light (CEL) illuminate when you turn the key to position 2 (which powers everything up, but does not engage the starter)? If not, your CEL bulb may be burned out.
If the bulb is burned out and you don't want to pull the instrument cluster to replace it at the moment, you can see if someone you know has a code reader for the OBD I BMWs. That instrument can read the codes regardless of the CEL bulb.
Another remote possibility is that the DME (engine management computer) itself may be bad. However, there are many other things to consider and rule out before you come to that conclusion.
Hopefully for you, the DME is not bad. On the 95 models, there is a drive away protection system called EWS II. It is a pain in the butt when it fails. Fortunately there are a couple of easy and inexpensive fixes. That can be looked at later if your DME is deemed to be faulty. We don't want to get the horse before the cart.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 10-31-2012, 10:43 AM
The check engine light dose come on when the key is in.
Old 10-31-2012, 10:45 AM
How could you check the Ews II?
Old 10-31-2012, 11:32 AM
You need to remove the cluster and replace the bulb then.
EDIT:
My mistake I just realized you live in Georgia. If its not the one in the United States then you do NOT have a check engine light. Therefore you cannot perform the stomp test.
It is a US model only thing.
You need to make a new thread for this, explaining the situation.
Old 10-31-2012, 11:51 AM
Ok. I'm located in the united states.
Old 10-31-2012, 11:57 AM
BMR_LVR's Avatar
Humble E34 lover
If the check engine light comes on with ignition key in position #2, then your stomp test should work.
It can be difficult to do it the first time. Watch the video in the thread and keep trying. Once you get it, you'll wonder why it seemed so hard at first
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 10-31-2012, 12:20 PM
Yea, i took a look at it and tried it on my brothers 325is and it work but it will not work on the 525i?
Old 10-31-2012, 02:49 PM
BMR_LVR's Avatar
Humble E34 lover
"Well, that indicates that you know how to do it then. It is possible that the DME has failed. Here is a very lengthy thread on the subject of EWS deletion in the 95 model.
http://www.bimmerfest.com/forums/sho...ght=ews+delete
Again, you will need to rule out all other possibilities like the CPS, fuel pump, fuel pump relay etc., etc.
The Bentley manual has a good trouble shooting guide in it. If your brother (I think that's who you said would be helping you) is not very familiar with BMWs, you may want to try to find a good local independent BMW mechanic with a good reputation and have him take a look at it.
Good luck.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 10-31-2012, 03:00 PM
Banned
Mein Auto: car
Good luck.
Her engine seems to be cranking (she said so in another thread). So it can't be an EWS issue, right ?
Old 10-31-2012, 06:14 PM
BMR_LVR's Avatar
Humble E34 lover
Agreed. As you may recall, my engine would crank over fine, just no fuel or spark and it ulimately turned out to be a faulty DME. Since her car is the 95 with EWS II, and if her DME is bad, she will have to do the EWS bypass and red label DME swap. Perhaps the EWS delete chip would work, but I don't have a high degree of confidence if the DME itself is bad.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 10-31-2012, 08:03 PM
Banned
Mein Auto: car
Oh yes, your engine was cranking away. Forgot sir.
Old 11-18-2012, 05:49 PM
mark cherry mark cherry is offline
Mein Auto: 535i & 318is
the code : 1222 has appeared, wat is the lambada 1
