E46 (1999 - 2006)
The fourth generation 3 Series (E46 chassis) was introduced in 1999 and set the standard for engineering and performance during it's years of production including being named to Car & Driver's 10 best list every one of those years! ! -- View the E46 Wiki |
Dual Vanos Repair Results: share your experience
What are some of the things you've experienced after installing a new VANOS system?
I did not have the MAF or the air cabin filter completely installed. Tonight I was only checking to see if the engine would turn over. during this project, I installed a new DISA valve, new intake and exhaust cam sensors, new Spark plugs (NGK), new VANOS seals and a Dual Vanos unit from Dr. Vanos, and a new AC belt. Last edited by DoubleDEAS2011; 03-23-2011 at 10:31 PM. |
What? You checked if the VANOS was installed correctly?
Before putting the cover, the fan, and the MAF back together, which I wasn't going to have time to do, I asked the mechanic if it would be ok to turn the engine on to see if there was any rattle and if I put everything back together correctly. There was no rattle and the engine turned on.
I'm working at an auto hobby shop. I have a bay and tools. The only inconvenience is that they close at 730. Last edited by DoubleDEAS2011; 03-23-2011 at 10:07 PM. |
- How to objectively test VANOS seals in operation (1) We have been successful in determining your options though: - What options do you have for your engine VANOS repair And, we have some videos of VANOS rattling noises: - VANOS rattling noise video (1) (2) And, some people make their own VANOS tools: - How to make your own VANOS tools (1) & socket tools (1) These links are all from the VERY best of E39 Links but most should apply to the E46 (I hope): - I6 VANOS SEALS DETERIORATE: they're made out of the wrong materials so that they harden and leak over time causing degraded performance (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) & how VANOS works (1) (2) (3) & what your options are (1) and vanos application table (1) I sincerely hope these help. |
| Bookmarks |
| Tags |
| common, idle, post vanos, signs, symptoms |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
