Old 03-24-2011, 02:58 PM
chance144 chance144 is offline
Mein Auto: 2001 M Coupe
Left side of 2001 M Coupe 3/8 of an inch lower than right?
Hi everyone,
While washing the car today, I noticed that the left (driver side) of my car is about 3/8 to .5 of an inch lower than the right. it is the same at both the front and the right wheel. It is not a difference in tire pressure, as the difference is in the gap between the fender and the top of the tire. The vehicle is completely stock, and has never been in a wreck.
What could possibly cause this? The car only has 37,500 miles on it. My only thought is that there has rarely ever been a person in the passenger seat, but I weigh 170 and I can't believe that the little bit of driving I do in it every year would drop the side of the car that much.
Any thoughts, suggestions, or ideas what might be causing this?
Old 03-24-2011, 06:24 PM
marin marin is offline
Mein Auto: 2007 M Coupe
Are you parked on level ground? If not, then it's easily possible to see something like this.
Old 03-24-2011, 07:40 PM
Mpire's Avatar
Mpire Mpire is offline
The Anti-Rice
Send a message via AIM to Mpire Send a message via MSN to Mpire Send a message via Yahoo to Mpire
Mein Auto: S54 M Coupe x2, M52 Z3
Its damned near impossible to get it perfect on every corner.
Just give up.
If you are that anal, I suggest you get coil-overs so you can adjust them for two days and then get the car aligned...
Only to find that its off another quarter of an inch when you get back home.
Ask me how I know.
2001 Alpine / Schwartz Coupe
2001 Estoril / Estoril Coupe
2001 Steel Grey / Estoril Coupe
1999 Estoril / Estoril Coupe
Sunroofs are for girls.
Old 03-25-2011, 06:43 AM
Good, that makes me feel better. It doesn't pull, and it doesn't affect the driving in the least. I was just hoping that it wasn't some massive problem.
Thanks,
C
Old 03-25-2011, 07:07 AM
Drivewfo Drivewfo is offline
Enthusiast
Send a message via AIM to Drivewfo
Mein Auto: 2008 Z4 3.0si Roadster
You are setup for short track racin'
BMWCCA Member
2008 Alpine White Z4 3.0si Roadster 6spd
2006 Silverstone II M5 SMG (gone)
2002 Alpine White 325i Steptronic (gone)
Old 03-25-2011, 03:44 PM
Terry J. Harris's Avatar
Terry J. Harris Terry J. Harris is offline
bimmerfest Supporting Member
Mein Auto: '05 Z4 3.0i & '08 X3.0si
So you're the guy we see going clockwise around the track every week?
Old 03-25-2011, 04:01 PM
PhillyNate's Avatar
PhillyNate PhillyNate is offline
BMWCCA Member #405750
Mein Auto: 2011 E92 M3 ZCP
This has been discussed on this board before. Your situation is unusual in that it's your passenger side that sits higher than the driver's side. When this was posted before it was everyones driver side that sat higher than the passenger. As mine does. Someone credible concluded that it was due to BMW assuming that most of your drives are going to be sans passenger and it's an attempt to perfectly level out the car. It sounded very German so I adopted it as gospel.
2011 Alpine White BMW M3 Coupe 6-speed Manual w/ ZCP.
2008 Alpine White 328i Coupe 6-speed Manual/ BMW Performance Exhaust/ M6 Wheels. (Retired)
Future owner of a Jetson's fold-up briefcase car. So I can TRULY park worry free.
"what I'm driving here...is an ending." Jeremy Clarkson
2001, m coupe
