Old 03-24-2011, 09:15 PM
LeeRey LeeRey is offline
Mein Auto: 1997 Z3
Question Z3 Windshield washer pump not working
Ok, here is the problem. Washer pump stopped working on my 97- Z3. No humming noise or any noise when activating pump. Checked fuses (all related fuses checked ok). No plugged lines. Removed pump and tested pump with a 12volt battery and pump runs just fine when connected to battery. So pump is in good working conditions. Connecting pump back into place and nothing happens, not even a humming noise. Wipers work just fine.Also, noticed that when I connect pump into place and pull lever (@ stiring wheel) to activate pump nothing happens. But if I disconnect the pump and pull lever to activate washer pump wipers start to move.
Please help me!!!
Thank you in advance
Old 03-25-2011, 03:46 AM
bob lindquist's Avatar
bob lindquist bob lindquist is offline
A Clean Windshield
Mein Auto: 2000 Imola M Coupe
Check voltage at connector.
Check for pinched wires which might be an area of a short or open.
2000 Imola Red M Coupe
Dinan suspension, M rotors /Axxis pads
Eurosport Cam Kit 1, touch lane change
Zaino polish, Beach Sand
Garys mirror adapter, S54 Oil Cooler
seat tilt coupling nuts, spare tire
"life's to short to drink cheap beer"
Old 03-25-2011, 06:13 AM
Mein Auto: 1997 Z3
Thanx
Bob,
Thank you for your suggestions; I will do that and I'll get back to you with the results.
Old 03-31-2011, 07:02 AM
Mein Auto: 1997 Z3
Greetings Bob,
Finally had the opportunity to check the voltage on connector, and here are my findings:
Checked voltage on connector, with connector connected to pump; voltage read 0.35V
Checked voltage on connector, with connector disconnected from pump; voltage read 11.30V.
I searched for pinched wires, but could no locate any.
What are your thoughts based on these findings?
Many thanks.
Old 03-31-2011, 10:03 AM
A Clean Windshield
if you feel comfortable with wires and power.
pull the pump out and with a 2 conductor wire (lamp cord) try connecting it direct to the battery. see if it works. (or an old cigaret lighter cord from a discarded device and use the lighter plug instead of the battery)
Old 03-31-2011, 11:59 AM
Mein Auto: 1997 Z3
I did remove the pump and tested it with the battery and pump runs fine doing it that way.
Thank you for taking the time to reply to my questions Bob.
Old 04-25-2011, 11:43 AM
MrToSlo MrToSlo is offline
Mein Auto: 1996 BMW 328i
were you able to resolve this issue?
i'm having the same EXACT problem...although my car is an e36.
pump is brand new and works fine when hooked up directly to power source such as battery. i'm almost certain there's a faulty wire somewhere, but haven't had the time to look.
Old 04-26-2011, 11:28 AM
Mein Auto: 1997 Z3
Greetings MrToSlo!!!
I have not resolved the problem yet. However, coincidently, yesterday I had a visit from an old friend, who is a Mechanic, and looked at the issue with my 97 Z3. After running a diagnosis; he said that with 95% certainty, that the culprit is a relay ( Window Pump washer relay) which is located ( on the 97 Z3) behind the glove compartment.
So as soon as I get some time off from work and catch up on my honey Do's list, I will replace the relay.
Hope this info was helpful. Let me know if you get to resolve your problem. Good luck!!!
Old 04-28-2011, 11:55 AM
i've tried replacing the washer relay and it still doesn't fix the issue. in my case, i'm almost certain that it's a grounding issue.
hopefully replacing the relay will fix your issue!
Old 10-17-2011, 12:56 AM
marrulengo marrulengo is offline
Mein Auto: '97 528i bmw
Hi guys, I have the same issue on my wife's '97 528I. Anybody has actually solved the mistery?
ANY idea would be greatly appreciated.
Marrulengo
Old 12-03-2011, 10:11 PM
hey everyone. i have an e36, but i fixed my issue by replacing the actual windshield washer lever/switch inside the car. hope this helps.
Old 03-07-2014, 02:05 PM
guy10596 guy10596 is offline
Mein Auto: BMW Z 3 1998
same problem fuses good , and not even a hum from my unit
