Old 02-17-2004, 03:04 AM
Dennis33's Avatar
Dennis33 Dennis33 is offline
BMW Z4 Coupe
Mein Auto: 2007 Z4 Coupe 3.0si
Talking S52 vs S54 M Coupe ( I have one of each)
Ok guys, about two weeks ago, I bought a 2001 S54 M Coupe.
Until I sell my S52 M Coupe, I have both cars to play with (and no $$$)
When I just had my S52 M Coupe and tried to defend how great I thought the S52 engine was and compared it to the S54 engine, I was blasted
by all the S54 dudes, defending their S54 engine. I really enjoyed the debates because it helped me decide if I really wanted to upgrade to a S54. Well, you guys must have done a good job because now I have a S54 M Coupe. Now I am trying to defend my OWN purchase of the S54 M Coupe.
I am going to upgrade the stock 3.15 diff to a 3.73 diff, as soon as I sell the S52 M Coupe.
I did some time testing with both the S52 and S54 M Coupes on my favorite stretch of (flat no-curve) expressway, this last weekend.
There is a test that "Metric Mechanic" suggests to test all cars/engines to eliminate the driver's skill level and to make all things even.
They call it the 60-80mph test in 3rd gear.
They claim that most engines are in there peak torque/horsepower RPM range at 60-80mph in 3rd gear (I now believe the S54 is higher).
Well, I tested both the S52 and S54 with this test.
The S52 times were 2.6, 2.7, 2.8 seconds, every time from 60-80 mph (4320-5760 RPMs) with the stock 3.23 diff.
The S54 times were all above 3.0 seconds, every time from 60-80 mph (4213-5617 RPMs) with the stock 3.15 diff. I could not get a time under 3 seconds. I was really shocked.
I know that the S54 torque curve is higher at an earlier RPM and stays flat longer and than the S52, which supposed to be better.
I also know that the S52 with the "Shark" software and CAI (like mine), does have more torque, for a real short RPM range (around 4000 RPM), but still I really thought that the S54 would produce lot better times than the S52.
I believe this test just happened to be testing the S52 in it's strongest RPM range.
I'm sure if the test was 50-90 mph, the S54 would have better times......I hope...
I hope with the 3.73 diff in the S54 makes a lot of difference.
I also received the latest software update from my BMW dealer Saturday on my S54 engine.
The BMW mechanic told me that ALL the S54 software updates were for the "Cold start" problem and not the throttle respond problem. Is that true?
Also, we talked about how BMW purposely "DE-tuned" the S54 engines for the M Roadster & Coupe from 333HP to 315HP, so they would not out perform the M3. It was not due to the more resticted exhaust system in the M Coupe (I had heard this before).
He said that the Dinan software upgrade for the S54 for M Coupe simply changes the engine back to 333HP. Is this true? I believe Jim Conforti now has "Shark" software for the S54. Is this true?
Oh, by the way, I have one of the best looking, best running and best maintained 1999 M Coupe FOR SALE. Someone better come and buy before I decide to keep it and sell the S54 (just kidding).
2001 M Coupe
Steel Gray with Imola Red/black
BBS RKII wheels
Old 02-17-2004, 04:23 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
AFAIK the less HP is a combo of exhaust differences, intake diffeences and lower redline (7400 versus 8000).
Yes, Conforti has a Shark out for the 54, and I personally would believe that his claims are closer than Dinans claims.
Why not test your two at 50 - 90 and 60 - 90 and see if that helps the S54. But the S54 has a pretty flat torque curve, so its strength is in that the acceleration is pretty much the same throughout the rev range, unlike the S52, which does a a very definate peak.
And yes, to get a software upgrade at this point, you have to complain abuot cold start issues. I have to call and get our M3 in this week.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 02-18-2004, 10:16 AM
Mpire's Avatar
Mpire Mpire is offline
The Anti-Rice
Send a message via AIM to Mpire Send a message via MSN to Mpire Send a message via Yahoo to Mpire
Mein Auto: S54 M Coupe x2, M52 Z3
Airbox. The Coupe has a smaller airbox on it to fit under the Z hood.
We need to change this before we can change the software.
Mpire
Old 02-24-2004, 11:55 AM
songziou songziou is offline
M Fans
Mein Auto: S54 M ROADSTER
I drive a S54 M ROADSTER, I've tested the redline is 8000RPM as E46 M3's S54.
Well, if Dinan's software will turn back my M roadster back to 333HP, I will do it immediately
Old 02-24-2004, 02:20 PM
Pinecone's Avatar
M Mad
Interesting, as the publsihed one is 7400 aqnd the Shark Injector takes it up.
But teh S54 rev limiter is known to be soft. M3s have been taken well over 8000 with tripping the limiter. Each car seems to behave slightly differently.
And no way does the Dinan software give you back the 18 HP.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 02-24-2004, 02:40 PM
ARC///M's Avatar
ARC///M ARC///M is offline
Mein Auto: BMW 01 M Rdstr 00 M Coupe
The amazing art of un-truths.!
This board is getting to be like the comics,But it has some real funny but fun articles to read!This info is like saying the if you add Jon`s spare tire you will go faster.
Old 02-24-2004, 02:45 PM
JonM's Avatar
JonM JonM is offline
Moderator
Mein Auto: 01 Mc, 08 M3, Motorrad x2
That's just nuts.
Now - on the other hand - if you upgrade to curved M badges, well then that's a horse of a different color.
Jon Maddux
10 S1000RR | 09 F650GS | 08 E90 M3 | 07 R1200RT | 06 M Coupe | 01 M coupe
Old 02-24-2004, 02:59 PM
ARC///M's Avatar
Tire speed
Well I can not remember what Ron said with the tire it is faster in a side by side or that wright if the tire light comes on he wins any way~!So yes the tire makes you faster if yours is flat.P/S THE S-52 May be faster in the long Run as engines are still stopping permentaly in are S-54 cars.aLSO jon give me a price on the tire please!And how much for the 99 coup please.I want one to race.
Name:	Euro Speed Pipes 020.jpg
Old 02-24-2004, 03:03 PM
Ron Stygar's Avatar
19,585 Miles
Rev limit on the M-Z3's is 7600. But like the speedometer the tach is also not accurate.
Old 02-24-2004, 03:23 PM
flashinthepan flashinthepan is offline
Mein Auto: unimobile
Sounds like you have been correct all along....lol, IMO 60-80 mph does me very little or no good at all. But a cool bit of info you have provided.
My favorite barometer is the tried and true 0-100 MPH, easily done & would tell you which car is packing the hot-sauce ! perhaps you can do this & test the S54 with both axle ratios...???
I will bet the 0-100 test will turn the tables a bit.
Hopefully you end up keeping the right car too !!
Old 02-24-2004, 05:43 PM
M Fans
Are there any relations between the de-tuned 18HP and MZ3's 5MT instead of M3's 6MT ????????
2002 S54 M ROADSTER(second engine)
Old 02-24-2004, 06:07 PM
The Other Tom The Other Tom is offline
Mein Auto: 2008 335i
No. As Terry said, it has to do with engine breathing, or lack thereof.
2008 335i
2001 325i retired
2000 M Roadster Imola Red retired
1998 Z3 2.8L retired
Old 02-24-2004, 08:43 PM
D///Mill D///Mill is offline
Send a message via AIM to D///Mill
Mein Auto: 2000 Z3 "///M coupe"
Ron ... The tach may not be accurate, but I sure hope the rev limiter is! Would you know?
Old 02-24-2004, 08:50 PM
Ron Stygar's Avatar
19,585 Miles
I would think so. I'll check it this Spring.
Old 02-25-2004, 06:03 AM
///M Rakete's Avatar
///M Rakete ///M Rakete is offline
Rocket Scientist
Mein Auto: 2010 M3 and 2011 135i
Originally Posted by JonM
That's just nuts.
And I thought the oil baggie was good for 20 hp not to mention the taco I had for dinner last night...
2010 BMW M3 Coupe M-DCT w/Tech-EDC, BMW M Performance Exhaust, BPM Stage I Tune, Space Gray / Fox Red Extended, and a Trunk Monkey known as "Der Stig",
plus the daily driver...
2011 BMW 135i M Sport DCT, w/BMW Performance Power Kit, Exhaust, and Brake Rotors, Space Gray / Coral Red, known as "Stiggie" with an outlaw F20 "M135i" badge.
Old 02-25-2004, 06:07 AM
Rocket Scientist
How for off is the tach? I use it as my speedometer.
Old 02-25-2004, 06:16 AM
Pinecone's Avatar
M Mad
At least int he M3s it is not. It is quite soft. People have gone WELL past the rev limit and it has later shown up in a DME dump (failed engines early in the time frame).
BMW used the DME dumps to "prove" missed shifts, until SMG cars started showing up with failed engines and DME dumps showing 8200 - 8500 max RPM.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 02-25-2004, 08:57 AM
MDork MDork is offline
Send a message via AIM to MDork
Mein Auto: '02 ///M Coupe
me too...
i have tested the "tach as speedo" against gps and it was w/in 2mph.
scott
Old 01-09-2008, 11:51 AM
kenkalan kenkalan is offline
Mein Auto: 2002 m coupe
S54 M coupe 2001
I have a 2001 S54 that I was thinking about selling, and I was wondering if you knew a good price to set it at? Or if you knew a good place to sell it. It is a rare car and a lot of people don't know what it is.
Thanks,
Ken
Old 01-09-2008, 12:00 PM
ARC///M's Avatar
Sell It
Try Rondel that real safe,Or Ebay.
Old 01-09-2008, 02:47 PM
SUNZOUT SUNZOUT is offline
Mein Auto: '00 M Roadster
Thanks,
Ken
And this 3 year old thread has something to do with you selling a car because....
TC Kline S/A Coilovers | Sharked | Turner Slotted Rotors | Axxis Ultimate Pads | SS Front Strut | IE Subframe Bushings | IE Rear Toe/Camber Kit
Whalen Shift Machine | Stygar Clutch Pedal | CDV Delete | LeatherZ Armrest | Whalen seat bushings | Z3Solutions Windblocker | Shift Pin fix
Old 01-12-2008, 08:24 AM
Gibber66's Avatar
Gibber66 Gibber66 is offline
You 'fly' for a living?
Mein Auto: 1998 Z3 2.8; Volvo 940SE
1998 BMW Z3 2.8 - S52 Cams, Dinan CAI & Strut Bar, Butt Strut, JC Sharked, SS Exhaust, EuroSport UD Pulleys,
Fan Delete Mod -- EuroSport M50 Intake Mod, E30 3.73 LSD, Evo M3 6-speed tranny install COMPLETE!
Old 01-12-2008, 01:29 PM
Blak Blur Blak Blur is offline
Mein Auto: 98 E36 M3
I had a very early 2001 M3 (neat car no roof hole & M cloth inserts) and now have very early 2006 Z4MC. Are both S-54?
Old 01-14-2008, 09:49 AM
Renee's Avatar
Renee Renee is offline
Mein Auto: S52 E30 M3, WRX Wagon
I think he sold the S54 for around $34K.
I wouldn't expect to get that much w/o a motor warranty in the dead of winter.
Wonder how he likes the Z4 Coupe compared to the Z3s. Respond if you are out there Dennis.
'90 S52 E30 M3
'02 WRX Wagon
'99 M Coupe - sold
S52 E30 M3
