Old 03-26-2011, 06:58 PM
Mrsox05 Mrsox05 is offline
Navy Chief's Wife
Mein Auto: 2001 530i- Metallic Blue
Cool Reset ABS, Air Bag & Traction Control Lites
Anyone know how to reset the ABS and Traction control light after replacing/remanufacturing the ABS module????
Also Air Bag light reset after disconnecting to work on passenger window.
Thank you!!!
Old 03-26-2011, 07:43 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
I don't remember 'resetting' the ABS & traction control light (and Brake light) when I got the trifecta. When I replaced the ABS control module, the trifecta went out on its own.
Methinks you 'might' have a bad wheel speed sensor but of course I have no data saying that other than you had the ABS control module steel wire reattached to its gold bond pad (which isn't a bad thing).
What were the values of your DMM tests of your four wheel speed sensors?
This is a common problem. Did you read one of the DIYs here for the passenger window fix? If so, which one does NOT mention how to avoid the SRS light? We should fix that.
- One user's experience with diagnosing the front left driver door window regulator (1)
Anyway, too late now. You really needed more garlic when you did the window.
Details here:
- What can cause an SRS airbag light (1) (2) (3) (4) (5) (6) & what tools reset the fault (1) (2) (3) (4)
Old 03-28-2011, 04:30 AM
Jimmys 530i Jimmys 530i is offline
Mein Auto: 2003 530i
You have to get your steering angle sensor realigned, then the light will go away.
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03
Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02
Old 03-28-2011, 07:00 AM
bluebee's Avatar
If it's that, there's more about testing and aligning the steering wheel sensor here:
- All about BMW DSC and the score of sensors innervating this traction control system (1-pdf) (2-pdf)
Old 03-28-2011, 12:44 PM
Navy Chief's Wife
OMG!! You guys are amazing! I will get all of this info to my handy dandy Hubby!! LOL I don't know any of those numbers.. hopefully he will know what you all are talking about. I am clueless.
Thanks again!
I will keep you posted as to what we find out.
