Old 03-26-2011, 11:32 PM
Dean Long Dean Long is offline
Mein Auto: BMW 540i (99) Silver
Question Crank,no fuel,no spark?
Hello, My 99 BMW 540i will not start.Everything comes on as normal and cranks over but no joy.There is no spark or fuel coming on.Anyone have an idea what's going on?
Old 03-26-2011, 11:50 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
I believe a failure of the crankshaft position sensor prevents the engine from starting.
What P-code is stored?
Old 03-27-2011, 03:17 AM
Crank sensor
Yes I have seen that.But have a cheap OBDII reader and there is no fault codes coming up.Should the crank sensor bring up a fault code? The Car dose not register anything is wrong.I don't get it.The BMW dealer had a quick look and said it looks like the computer.But the computer gives read outs and communicates with the OBDII reader.
Old 03-27-2011, 03:19 AM
What is a P-code? I s that a picture of your Car? Looks good
Old 03-27-2011, 09:02 AM
filon102 filon102 is offline
Be american, get a bimmer
Mein Auto: 00' 540i, 87' benz 300DT
Have you ever heard of google?
Old 03-28-2011, 04:29 AM
Jimmys 530i Jimmys 530i is offline
Mein Auto: 2003 530i
A crank sensor will not always throw a code. I would place my bet on the crank position sensor.
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03
Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02
Old 03-28-2011, 05:45 AM
poolman poolman is offline
Mein Auto: 525i station wagon
Might be one of the fuses causing the problem. Check them all. There are fuses hiden under the cabin air filter cover under the hood on the passenger side of the car. There are also fuses located inside the car--check them all.
Old 03-28-2011, 06:13 AM
mujjuman mujjuman is offline
tappa tappa toit
Mein Auto: hoopty
That would be my guess too. The fuses and the relays under the hood
mujjuman
Old 03-28-2011, 09:28 AM
P-codes are the generic OBD-II trouble codes. They take the form of "PXXXX", where the Xs are digits. A good scan tool will actually read out in English what a given code means.
There are also pending codes: if the ECU detects a fault, but it goes away, the ECU stores a pending P-code. Some scan tools won't read pending codes.
Bentley says a bad crankshaft sensor prevents engine starting. The code is P0335.
That's my car at a ranch house up Mt. Hamilton Rd.
Old 03-28-2011, 09:39 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
What is a P-code?
- How to identify all BMW computer-specific OBDII DTC diagnostic fault codes (1) & how to better understand the key EPA federal test procedure (FTP) concept of the BMW SES "drive cycle" (1) & how to diagnose a typical BMW E39 engine misfire (1) or a sporadic-temperature-change cold-engine intermittent misfire (1) (2) obtaining the pending or diagnostic trouble code (DTC) using free or freeware scans (1) [except in California or Hawaii (1) (2)] or the cheapest ODII scanner in the world (1) (2) or a better overall scanner (1) or the best diagnostic tools (1) (2) (3)
Old 05-06-2011, 11:48 PM
yes is looking like the crank position sensor.who knows.Have ordered a new master key.Will try that.If that don't work I give up.I will give it to the Dealer to figger out.You would think with a $150,000 price tag from new,they could get it rite. glad I didn't pay that.
Old 05-07-2011, 09:13 PM
xraye39 xraye39 is offline
Mein Auto: 530i
1. Is there fuel in car?
2. Is the electric fuel pump running?
3. Have you checked the fuel pump relay?
There could be many different causes, you need to start eliminating potential causes to include the CPS as mentioned by other folks.
BTW the dealer sounds like an idiot.... when folks say it sounds like the "computer" it translates to "we don't know but we will charge the bejezus out of you"
2003 530iA Sport - Titangrau Metallic/Schwarz Montana
Build Codes: ZSP/ZPP/ZCW. Born on date: 09/02, Dingolfing, Deutschland
NAV MKIV | PP | CWP | Xenons | Style 42s | Rear Shades | OEM ULF Bluetooth | Euro Armrest | Beisan Vanos Seals |
2003 530i/5Spd Sport - Titanium Silber/Schwarz Montana
| PP | Xenons | Style 42s | OEM TCU Bluetooth | Euro Armrest | Beisan Vanos Seals |
2001 525iA - Anthracite Metalic / Grau Montana
Sold but in the "family"
Old 05-15-2011, 06:12 AM
yes plenty of fuel, fuel pump not coming on.Yes have checked fuel pump relay.Key was not the problem.no spark.Looking like I will be getting charged the bejezus out of me.
Old 05-16-2011, 07:34 AM
Mein Auto: 530i
Ok, if the fuel pump is not coming on. You say you have checked the relay and it is good? Have you confirmed power at the fuel pump relay terminals? If yes did you jump terminals to see if fuel pump worked.
You have to keep tracking this upstream to find out the issue.
I would not give it to the dealer yet!
Hang in there, you will be able to figure it out
Old 08-17-2011, 04:06 PM
dmann2 dmann2 is offline
Mein Auto: 1998 BMW 528i & 540i
Hey guys did you ever find out why the 540i would not start? I have found myself in the same position with one of my BMW's , checked all fuses under hood, glove box, & trunk... Check fuel pump relay, has power, not sending to pump, jumped 30 / 87 to pump it works? Pulled plug no spark, battery is up to charge no problems, Im guessing cam & or crank sensor may be my problem! One of my scanners dont work on bmws, & i have a little cheaper scanner by actron that did attempt to read it but NO Codes, but have found out that not all scanner that work on BMW's will read the codes, so now looking for something better of ebay... Just wondering what was found?
Old 05-02-2013, 03:25 PM
moar_corn moar_corn is offline
Mein Auto: e39 M5
Just solved a no start issue on my e39
Assisted by a hint in this thread.
My e39 2000 M5 had a no start issue. Checked the fuel pressure (at the shrader valve under the panel near the driver's seat) Pressure was fine, but there was no spark. (pulled a plug and propped it near ground.
Tracked it down to a blown 30a fuse in the little fuse block under the passenger side cabin air filter. Starts now.
Figured I'd post here for posterity.
Old 05-02-2013, 06:05 PM
acerocks415 acerocks415 is offline
Mein Auto: 2002 540i6
Thanks Moar having the same issue and really hope this it. Will check this tomorrow, hopefully my beast comes back alive.
Do you know why your fuse blew?
Old 07-09-2014, 04:03 PM
josemedeiros007 josemedeiros007 is offline
Mein Auto: 1998 528i 4Dr
Glad to hear that you figured out the issue. Do you recall which fuse number it was for future reference? Was it the ECM fuse?
Just in case some one else is experiencing no start issue's, This diagnostic guide may be helpful, the ECM relay can also be an issue.
BMW No-Start Diagnostic Guide DIY
http://blog.bavauto.com/3562/no-start-1989-325i-e30/
BMW 5 series E39 common no start issue
