E46 (1999 - 2006)
Old 03-28-2011, 05:13 PM
Robert.Petersen Robert.Petersen is offline
Bimmer Buerto
Mein Auto: 2001 BMW 330Ci
Question 2001 BMW 330Ci covertible top won't go down
I have a 2001 BMW 330Ci convertible, and starting today, the top won't go down. When I push the button to lower the top the orange indicator light on te switch comes on and nothing else happens. I haven't had any issues with the top before, but it has been about 2 months since I've had it down due to rain and low temps.
The trunk is empty, so no issues with blockage, but I did notice this appears misaligned but I am unsure if it's related to the convertible top issue I'm having:
Alternate link to the images:
http://www.facebook.com/album.php?ai...3&l=011e5e2d5d
Any thoughts or suggestions?
Old 03-28-2011, 05:35 PM
davecpa davecpa is offline
Mein Auto: 2005 330CI
Gernerally its the Trunck expansion lever. Happened to me just today. first day of sunshne in a while here in the Napa Valley, I push the button, nothing happens. Then I remeber that I put up the trunck expansion to take my daughter to the airport last week!
Problem solved!!
Old 03-28-2011, 05:38 PM
marinekilz's Avatar
marinekilz marinekilz is offline
Noone Special
Mein Auto: 01 E46 330 xi
that piece is not related to the top going up and down. But the trunk divider will have to be down. It will also have to be above 37 degrees out for the top to work.
01 E46 330Xi
06 E92 328i ZSP
07 E92 335i ZSP
E9 One Day It Will Be Mine
Old 03-28-2011, 05:42 PM
I can't seem the type the word Trunk correctly!
Old 03-28-2011, 06:04 PM
marinekilz's Avatar
Noone Special
lol, I didn't even notice until you posted it
01 E46 330Xi
06 E92 328i ZSP
07 E92 335i ZSP
Old 03-28-2011, 07:57 PM
Bimmer Buerto
Talking w00t!
Thanks for the replies guys, got it working. Feel dumb now, the trunk extention was just in the wrong position. Still, I would have felt far more dumb if I had ended up taking it to a BMW shop to get it 'fixed' ;-) Thanks!
Old 03-29-2011, 02:37 PM
SJBimmer's Avatar
SJBimmer SJBimmer is offline
Living Life At The Beach
Mein Auto: 2004 325 Convertible
Don't feel bad. I did the same thing a couple of years ago. You are just not in summer mode yet!
Old 03-04-2012, 08:30 PM
325ciguy 325ciguy is offline
Mein Auto: 2001 325 ci convertible
Well Mine is still not working. I'm not sure what the problem is. Does anyone have a list of common issue with these tops so I can trouble shoot??
Cheers
Old 03-05-2012, 10:02 AM
SJBimmer's Avatar
Cheers
Go to E46fanatics.com and check the convertible forum. More info than you want to know.
Old 04-10-2012, 05:57 PM
benyce740 benyce740 is offline
NyceBMW
Mein Auto: 1998 BMW 740il
Top Light flashes
I bought a used 2005 3 series convertible today and the top light is flashing
Tried to lower the top - no luck. Checked the trunk and the storage bin appears to be in the correct position. Anyone have a suggestion of what else to check.
I did notice the cap for the allen wrench hole in the roof is missing and the allen screw is tight. Does this need to be fully released to put the top down or doesn't it matter? I figure if it has been manually closed it is because the top motor is shot. Don't get any noise from the motor.
Advice appreciated. Bob
Old 04-10-2012, 05:59 PM
NyceBMW
Repair shops, Allentown, PA
Does anyone know if there are legitimate repair shops other than the dealer in Allentown, PA.? Thanks, Bob
Old 10-18-2016, 04:08 PM
matonon matonon is offline
Mein Auto: 330 ci
330 ci top wont go down
THANK YOU THANK YOU THANK YOU bimmerfest. It was the trunk expansion lever and you probably saved me a few hundred $$$ at the dealer, plus car rental, plus time, aggravation, etc. My repair shop is VERY impressed.....
330, 330ci, convertible, stuck, top
