what size wheel spacers?? - Bimmerfest - BMW Forums
Old 03-29-2011, 04:24 PM
edmonem's Avatar
edmonem edmonem is offline
Mein Auto: 97 528i
hey guys...ive been reading up all day and ive been coming across different infos which is getting me confused. im picking up a set of 18" style 42, which from the info i got is 18x9 and et24...i may be wrong on the et but thats what i read somewhere...anyways, im gonna mount on 265/40/18 on them all around for driving comfort. so my question is, what size spacers do i need? ive read all kinds from 3mm to 15mm...i was thinking of going 10mm all around...will this be a problem? also, with the 10mm spacers, what length lug bolts will i need?
BMWCCA member #446696
aloha state
Old 03-29-2011, 04:35 PM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
You will get different answers, "search xxx threads" yadda, yadda, yadda.
In my opinion, the best bet is once you get your wheels and the rubbers on, mount them
Then take a tape measure and take measurement from the most outer edge of your tire to the inner edge of the fender wall. The distance will be your spacer thickness.
I am saying this, because some people buy the spacers ahead, then they don't fit, or they are to narrow,
If they don't fit, they have 2 choices: return them for another set at your expense, or: flare the fender.
I have 18" wheels and 245 width tires all around, and they do not touch. I am curious how they will sit once I will lower the car. But this will have to wait until I cross that bridge.
Old 03-29-2011, 04:39 PM
Joe@Bavarian Joe@Bavarian is offline
Past Sponsor
Mein Auto: Me - E39 5spd, Wife - E36
OEM are, sty-42 36111094377 e39 8Jx17 ET:20 3-piece
even with after-market 18's i'm not sure why you would want spacers?
Old 03-29-2011, 04:44 PM
edmonem's Avatar
Mein Auto: 97 528i
Thanks for the input...yes I'm going to drop it also, so I'm pretty sure the drop will make the tires rub. And also, the wheels I am picking up are 18" not 17"... And from what I've read the 18" are 18x9 et24....
Sent from my iPhone using BimmerApp
aloha state
Old 03-29-2011, 05:05 PM
Past Sponsor
I had 18" M5 (style-65) wheels with 275/35/18 on the rear and my car is lowered as well with no problems at all.
Old 03-29-2011, 06:19 PM
champaign777's Avatar
Mein Auto: 2003 530 Sport Twins
http://forums.bimmerforums.com/forum....php?t=1525776
Old 03-29-2011, 08:15 PM
edmonem's Avatar
Mein Auto: 97 528i
Originally Posted by champaign777 View Post
Thanks for the link... It had a lot of useful info for me.so I decided I will go with 10mm spacers just to give it a little aggressive stance...
aloha state
Old 03-30-2011, 07:15 AM
Mack's Avatar
Mack Mack is offline
Thebizzy.com
Send a message via AIM to Mack
Mein Auto: '02 525i
Keep us posted. I'm considering spacers as well. The more I look at my setup the more I see how the wheels are inset a bit too much into the wheel well. I would be considering 10 to 15mm spacers, possibly 15 front and 10 rear. My only reservation is getting the longer lugs which will be heavier. Minutely so but still, I like to save weight wherever possible, especially down at the wheels. Keep us posted bro!
Mods: Shark Injected | Magnaflow Exhaust + Resonator | H&R Springs | Bilstein SP Shocks + Struts | TMS Power Pulleys
Eibach F+R Sways | BeastPower Brackets | M-Tech bumpers | Predator ICE V3 + HID Fogs | Eurodyne CF Hood | BSW Sub + Dice + spec dock
[---Quote (Originally by Tex330i)---
You can warranty a turd, that way when you have a problem you can exchange it for a new turd.---End Quote---
Old 03-30-2011, 08:03 AM
bobdmac bobdmac is offline
Older than old school
Mein Auto: 2001 540i/6, '90 k75s
Originally Posted by Mack View Post
...My only reservation is getting the longer lugs which will be heavier. Minutely so but still, I like to save weight wherever possible, especially down at the wheels. Keep us posted bro!
How much do the spacers weigh?
Old 03-30-2011, 08:09 AM
Mack's Avatar
Thebizzy.com
Mein Auto: '02 525i
Most if not all spacers are aluminum so they weigh very little.
Old 03-30-2011, 09:54 AM
edmonem's Avatar
Mein Auto: 97 528i
I ordered ecs 10mm spacers and should get here by Friday... The wheels will be here next week Tuesday along with the shocks and drop springs...and other misc. Goodies... I'll keep you posted when I install the stuff.prolly take a while cause I'll be installing them myself...
aloha state
Old 03-30-2011, 10:26 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
I'm gonna add this link to the bestlinks so that we have a start on again answering 'what size wheel spacers' ...
If you know of better threads for answering that question than are already in this thread, let me know.
- Choosing the right BMW tire size (1) (2) & tyre circumference, diameter, offset, & clearance calculators (1) (2) (3) (4) (5) & a torque conversion calculator (1) & how to logically choose tires by the numbers (1) (2) or by recommendations (1) & where to buy your tires in the USA (0) (1) (2) (3) (4) (5) (6) & tire plant codes (1) (2) (3) & tire safety (1) & recommended tire pressures (1) (2) (3) & the claimed benefits of nitrogen gas (1) (2) & tire terminology (1) (2) & wheel terminology (1) & BMW wheel specs (1) & BMW & replica wheel styles (1) (2) (3) (4) & the difference between cast vs forged wheels (1) & where to find the wheel markings for proper match mounting (1) & the best products for cleaning wheels (1) & how to choose the right size wheel spacers (1) (2)
Note: I didn't do the research (as wheel spacers aren't my shtick); so that's why I ask the OP to let me know which links were best from his research so I can add them to the bestlinks for others to stand on his shoulders.
Old 03-30-2011, 10:34 AM
Past Sponsor
That's going to look so good!! Don't forget to take before & after pictures.
edmonem's Avatar
Mein Auto: 97 528i
Sounds good bee... Although I can't really give accurate info at the moment, until my parts do come in, but I have to say that the first link posted by champain gave me a rough idea of which way I should be headed as the link had the wheels I am going to mount...but well see what happens in 2 weeks or so.and yes, I will try my best to take clear pics of the install and before and after pics...thanks for the help guys
aloha state
Old 03-30-2011, 02:03 PM
franka franka is offline
Mein Auto: E39 540i Sport
This Works
These numbers work, so you can extrapolate from here...275s on 18x9s, w/ ET24, 10mm spacers on front, no spacers on rear.
H&R hub-centric spacers are best spacers on the market, and they come with the proper length lugs.
Frank
540/6
540, Dirrezas (4) @ 275/35-18 ea, Eibach springs & bars, Bilstein Sports, Dinan Stage 2, slotted ATEs, Hi-Temp HTP pads, SS Lines, UUC-SS, White/Tan, Bling-free & Stealthy
Old 03-30-2011, 02:18 PM
Mack's Avatar
Thebizzy.com
Mein Auto: '02 525i
Hmm good call. TMS has the whole lot of 'em here http://www.turnermotorsport.com/BMW-...l-spacers.aspx
I don't want to give up my tuner lugs though. I may just get the spacers and get extended tuner lug bolts.
Old 03-30-2011, 03:15 PM
edmonem's Avatar
Mein Auto: 97 528i
Yeah your tuner lugs are nice. Not the type you see in most cars... I was thinking if getting a set
aloha state
Old 03-30-2011, 09:14 PM
edmonem's Avatar
Mein Auto: 97 528i
So I came home and this was at my door
The last pic is the shadowline rear bumper moldings...
That was hella quick! I just ordered these yesterday morning. Eac is on top of their game! Now I'm just waiting fir the drop springs, rotors and the style 42's....
aloha state
Old 03-30-2011, 11:44 PM
540 M-Sport's Avatar
Mein Auto: 01' 540 M-Sport, Scuderia
There are a lot of variables with selecting spacers. 10mm should work fine, but you will probably need to have the rear fenders rolled.
I have stock, staggered style 66 wheels in 8x17 and 9x17, with 235/45/17 front and 255/40/17 rear. With a mild drop using Bilstein B14 PSS coilovers I had no rubbing anywhere. After installing 15mm H&R spacers, I had very light rubbing of the rear fenders when going fast up an incline, from flat...like the start of a hill. I had to be going quickly, to compress the rear, but the fenders would lightly touch the outside edge of the rear tires. I had the rear fenders rolled at a race shop for $100 and no more rubbing.
540 M-Sport package (Canadian market), factory Bluetooth phone integration, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, M5 rear subframe braces, H&R 15mm wheel spacers, ST X (KW) coilovers, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, USA Spec Ipod/Iphone integration.
Old 03-31-2011, 12:27 PM
The wheel's ET is critical in determining the spacer thickness. They are both speced in mm.
Frank
540/6
Old 03-31-2011, 04:10 PM
Mack's Avatar
Thebizzy.com
Mein Auto: '02 525i
Is there a chart or formula somewhere that will help determine which size spacers are best for specific offsets?
Old 03-31-2011, 04:17 PM
edmonem's Avatar
Mein Auto: 97 528i
I think it would be hard to make one...most of it will be based on personal preference, and vary from person to person...
aloha state
Old 04-01-2011, 09:32 PM
edmonem's Avatar
Mein Auto: 97 528i
The wheel spacers (10mm) came in today. Came with extended bolts.
Also ordered a oil filter cap socket and got a wrong item. I asked for a BMW scan reset tool but I got sent a vw/Audi scan tool. Lol I think it's pretty funny that it's called a vagcheckerpro... I think a gynecologist invented it
Oh and yesterday this came in
It's pretty nice. A little confusing to navigate at first though, but looks okay in the car.
Before
After
Now just waiting for the wheels... Should be in by Tuesday
aloha state
Old 04-02-2011, 06:04 AM
Mack's Avatar
Thebizzy.com
Mein Auto: '02 525i
Dang, I want to know more about how well the Dynavin performs. There is almost nothing out here for E39's. Start a thread and let us know if it's worth a $hit!!!
Old 04-02-2011, 06:35 PM
edmonem's Avatar
Mein Auto: 97 528i
Mack, I'll try it out the whole week and find pros and cons I have with the dynavin. So far I only have a few complaints... Mostly the iPod functions, but yeah I'll make a thread next week...
aloha state
