E46 (1999 - 2006)
Old 03-29-2011, 11:49 PM
CJ_313 CJ_313 is offline
Mein Auto: 1998 Ford Explorer
Just bought an '01 BMW 325i... No reverse.
It's a black on tan 2001 325i sedan, auto transmission. I just bought it yesterday (03/29), it's my first Bimmer, I LOVE IT even with the issues it has... and it has ALOT of issues (no power steering (pump?), leaking radiator, leaking oil, no reverse) but the engine runs great and I only paid $1,000 for it off Craigslist, the owner said he was selling it because of the transmission. $1,000 seems really low for the car even with the problems, but I hope I got a good deal, the transmission issue makes me nervous. The inside and outside is in really good shape, no dents and only a little rust over the passenger rear wheelwell. It has 179,000 miles. It shifts great in forward gears, but no reverse engagement. Can this be fixed without a rebuild??? I read something about it being a Valve Body? My moms Saturn needed one of those last year and it was only $400 bucks @ indi transmission shop, so I hope that's all it needs. I searched the site and found mostly people with 323i's and 330i's with this problem... Is this a common problem for the 2001+ 325i's too? I'll post pics in the morning. Thanks guys.
Old 03-30-2011, 12:28 AM
Valceparksent Valceparksent is offline
Mein Auto: 2001 325i
Me 2 same car but mine is stuck in 5 th gear its an automatic it just takes off a lil slow from light or stop sign. Reverse and picks up speed good
Sent from my LS670 using Bimmer App
Old 03-30-2011, 03:25 AM
bmw2001-325ci bmw2001-325ci is offline
Mein Auto: 325ci
You bought a car with no reverse? You're brave. Do what smolck did, a swap for a manual.
$1000 for a car full of expensive-to-fix problems? wow. Please keep us posted b/c i would like to know how much ahead you come out of this seemingly good deal.
Old 03-30-2011, 06:16 AM
CarlsonTheFlyer's Avatar
CarlsonTheFlyer CarlsonTheFlyer is offline
Paraglide! Walk on air!
Mein Auto: 2010 335i Coupe 6MT
An '01 325i in excellent cosmetic and mechanical condition with that many miles would be about $8k, but with body rust and other wear is probably about $6k, so if you can get it all fixed for under $5k you'll come out ahead.
Good luck and keep us informed on your progress.
Carlson The Flyer | BMW CCA # 423862
The problem with common sense is that it's not very common.
2010 335i, ZSP, ZPP, M-Sport, Le Mans Blue, 3 pedals of course!
Heated Seats | USB & iPod | Black Dakota Leather
Cobb AP Stage 1 Aggressive + | Cobb FMIC | BMW Performance Exhaust
Previous BMWs:
2001 330i ZSP ZPP 5-speed - sold, but not forgotten.
Old 03-30-2011, 06:39 AM
Starless Starless is offline
Mein Auto: 2002 325i Auto
Your build date indicates you have a ZF transmission. The failure of the reverse drum is the most common cause of no reverse in these units.
See this thread for a DIY instructions:
http://forum.e46fanatics.com/showthr...verse+drum+diy
Old 03-30-2011, 07:26 AM
ventsyv ventsyv is offline
Mein Auto: 03 BMW 330ci
Worst comes to worst, you can always part it out and get your money back, so I think you got a good deal.
From what I've read switching to manual is a pain, but could be done. Buying a new (used) auto transmition should be much simpler. You'll need to do a number of other things as well though - CABs, cooling system, PCV, Vanos maybe ...
All filters and liquids, belts, spark plugs.
Have you been able to locate where the oil leak is coming from? Hopefully the engine was not overheated (due to old and obviously broken cooling system)??
Old 03-30-2011, 07:34 AM
jonathan2263's Avatar
jonathan2263 jonathan2263 is offline
Cogito Ergo Zoom
Mein Auto: 325iT
I would suggest you take it to a trustworthy mechanic who can give you a complete list of what it needs. The oil leek and coolant leak are both potentially terminal problems that could lead to the death of your motor. The trans could be fixable, but sometimes they just need to be replaced.
It sounds like you bought a car with lots of problems that was poorly maintained which spells trouble in high mileage bimmers. Try to get a complete list of what it really needs before you get in too deep.
Good luck...
http://www.facebook.com/home.php?sk=...?id=1338939628
"I May Be Going To Hell In A Bucket But At Least I'm Enjoying The Ride"
Old 03-30-2011, 08:46 AM
smolck's Avatar
smolck smolck is offline
ROLL TIDE!
Mein Auto: 2002 330i ZSP
At $1000 I'd put a manual in there. I paid $1200 for my swap. Then it'll last you a LONG time.
Old 03-30-2011, 09:56 AM
kunal_D's Avatar
kunal_D kunal_D is offline
Mein Auto: 2008 335i Sport 6MT
Then the car will have the proper transmission
08' E90 335i, Sport, Premium, Logic 7, 6-spd
01' 330i TiAG, ZSP, ZPP, ZCW, 5spd - R.I.P 04/12- gone but not forgotten.
Old 03-30-2011, 10:04 AM
ThreeTwoFive ThreeTwoFive is offline
Mein Auto: B25
Time for m/t swap
Old 03-30-2011, 11:49 AM
I don't really want to swap the transmission out for a manual. I drive in alot of heavy traffic during the week to and from class, that would suck if I had a stick. I just want to know what this means for my car not to have reverse??? Is it a good chance that I'll have to replace/rebuild the trans? Or could this be something that I might be able to get away with just a fluid drain-and-fill and a new part? I love this car, I'd hate selling it if the transmission is no good.
ID:	272461   Click image for larger version
ID:	272462   Click image for larger version
ID:	272463   Click image for larger version
Old 03-30-2011, 11:56 AM
Mein Auto: 325ci
For smolck the Tranny God, it's a mere $1200. For the rest of us mere mortals, it would be an arm and a leg, literally. Here's how it plays out. We'll try to do it ourselves first. In the process we get pinned underneath the detached tranny - on one side of our body, if we're lucky. Then since we are most likely to be working alone by ourselves because we are fiercely independent true men, our arm and leg on the pinned down side will turn blue until our significant other gets home. By then it would be too late and those bluish limbs will have to be amputated.
Old 03-30-2011, 12:00 PM
Mein Auto: 325ci
"I just want to know what this means for my car not to have reverse???"
Umm, you can't back up? IMO, I guess no harms in the long run because you could keep on driving forward and be careful not to get yourself in a spot where you have to do some backing up, like getting into a U-turn-not-able dead-end.
Old 03-30-2011, 12:17 PM
kunal_D's Avatar
It's time to replace that transmission, either with another slushy or the smarter choice a manual box, which will not give you this problem again. No reverse usually means the end of the line for these autos.
Old 03-30-2011, 12:28 PM
Thanks, that's all I wanted to know. If it is salvageable or not. It'll be back up for sale tomorrow then.
Old 03-30-2011, 12:30 PM
Don't be a smart ass. My question was clear as day.
