318i wont start - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Do-It-Yourself H.Q.
Do-It-Yourself H.Q.
Share your DIY projects that have helped you keep your BMW running. For questions about how to fix your BMW use the model specific forums. All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 02-18-2004, 04:42 PM
Slider Slider is offline
Mein Auto: 69 Vette
318i wont start
All,
84 318i wont start a lunch time. Starts fine in morning, but needs a jump start at lunch. Has a new battery, have checked alternator. All is good. I have also checked for a short and everything seems fine. What am I missing at this point. He told me today that he opened the door so he could see the interior light when he tried to start the car. It did not fade or even blink when he went to start. He can hear the fuel pumps working, but thats all. The starter is not even clicking. thoughts?
thanks in advance.
Old 02-19-2004, 12:28 PM
The Roadstergal's Avatar
The Roadstergal The Roadstergal is offline
Any ride will do
Mein Auto: 2014 320i
Checked the connections to the starter? Checked the voltage across the battery with the car off (should be no less than 12V) and with the car running (should be ~14V)? Have you tried giving the starter a little bink with a stick when it won't turn?
"This is a revolution, dammit! We're going to have to offend SOMEbody!"
Old 02-20-2004, 05:33 PM
Mein Auto: 69 Vette
You mentioned the electrical connections to the starter. Thats where I went today. I found that the spade type connector from the ignition was very loose. It was piggy-backed on another connector that was running the driving lights. I think that when the car got hot and sat for a while that the connector expanded slightly making the connection even worse....at least thats what Im hoping for. I tightened the connection. Time will tell on this one. thanks for the suggestion.
