Old 03-31-2011, 08:33 AM
DAvEyStRiNgS DAvEyStRiNgS is offline
Mein Auto: 2001 E39 530D
Help! ABS leak no brakes!
Hi all - my dad was complaining about bad brakes on his e39 1997 540i ... i took a look last nite and pumped the pedal with engine off and it didnt firm up, so i suspected master cylinder leak.
On investigation i found that there is some sort of valve mounted on the ABS hydraulic unit, into which the main feed from the master cylinder is fitted.....
there are 3 little holes on the under side of it and it is leaking fluid from them.... on pumping the pedal u get lots of sucky noise coming from it....
does anyone have any idea wat this part even is? some sort of pressure regulator? scoured the brake diagrams on real oem and lots of searching on forums but still no idea what it is....
only markings on it is the number 0667
See pic here, the offending yoke is circled in red,
any help appreciated!
Old 03-31-2011, 08:56 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
EDIT: I deleted what I had written because it was off track (since I don't have the same ABS control module).
See also this ABS PDF which shows how the entire system works:
- All about BMW DSC and the score of sensors innervating this traction control system (1-pdf) (2-pdf)
Old 03-31-2011, 09:05 AM
bluebee's Avatar
I might end up deleting all that I said above because it doesn't seem to have wires coming out of it and the older Bosch 5.3 units have the brake pressure sensor in a different spot.
So, again, to the OP ... YOU need to look up in REALOEM what that part is (if you suspect it).
And, you need to reassure yourself that you've tested the 'normal' part of the braking system first.
Note: Someone with the older ABS might also chime in but you can just look it up yourself in realoem.
Old 03-31-2011, 09:20 AM
Hi, thanks for all that... yes this car has the older abs unit, its a 1997 model, my 2001 530D is different from this too.
The rest of the braking system has no visible problems.... i dont think its the pressure sensor, because as u rightly state there are no wires coming from it.
I suspect it as the fault because it is leaking brake fluid, and as a result the system isnt sealed hence why im not getting any firmness on the pedal....
i had seen that post u had pasted in there, but where the pressure sensor is indicated is the wrong side of the hydraulic unit.... the rectangular item in question that i circled is on the opposite side of the ABS unit, and goes between the main brake line from the master cylinder and the abs hydraulic unit
watever it is, it shudnt be leaking fluid! its just constantly sucking air into the system
Also as i stated above, ive already searched through every possible page on realoem regarding the braking system for this car, and i cant find anythin that looks remotely like it.... unless its a built in part of the abs unit that isnt removeable :oS
Old 03-31-2011, 03:33 PM
bluebee's Avatar
I see you've done your homework. I guess I should delete what I wrote as it's misleading (and confusing to someone coming in anew to help you).
Let's hope someone who has the same (or similar) engine will chip in and help.
Old 03-31-2011, 03:46 PM
Joe@Bavarian Joe@Bavarian is offline
Past Sponsor
Mein Auto: Me - E39 5spd, Wife - E36
I'm not sure if anyone will sale just that. Most places sale it complete. "ABS control unit"
Old 03-31-2011, 04:16 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
bluebee,
Do you have the description for the earlier ABS, as on my car?
Old 03-31-2011, 05:00 PM
cn90 cn90 is offline
Try tighten it up and see what happens.
Use only "Flare Wrench".
Old 03-31-2011, 07:07 PM
bluebee's Avatar
Doesn't that PDF also cover the earlier ABS control units?
If not, all I can tell you is we've ascertained the pinout and locations for the earlier ABS control modules ... but I really don't think your problem is ABS related.
I think you simply have a leak. Period.
I'd do what cn90 says first.
Old 04-01-2011, 07:23 AM
ok quick update... called in with bavarian there... mechanic says its a non-return valve and is part of the older DSC/ASC unit... the newer versions (eg on my own car) have this valve built in....
anyway a new unit is 1562+VAT :-O
So i may try and take it apart see if theres any rubber seals that can be changed or failing that try ebay or a scrapper....
thanks for help anyways guys!
Old 04-01-2011, 07:54 AM
bluebee's Avatar
Good for you for doing your homework and handing it in for us to learn from.
Please do keep us informed as this thread has potential for added value.
Good luck.
540i, abs, brake, leak, valve
