E46 (1999 - 2006)
Old 03-31-2011, 10:58 PM
kylegebo86 kylegebo86 is offline
Mein Auto: 1999 BMW 328i
Unhappy 1999 BMW E46 Lack of power,hesitation,and intermintently no fire.
I have a 99 bmw e46 the car ran great a week ago but recently when i go to fire it up sometimes it will start first try but sometimes it will just keep turning and not start.It also has been having loss of power and a slight miss upon mild to hard acceleration.The fuel filter and plugs were replaced,cleaned the MAF,and checked to make sure their was no moisture in the gas.I had the codes cleared and the only one that came up on scan again was po1o1 i beleive. PLEASE HELP!!!
Old 03-31-2011, 11:31 PM
OhMyShad OhMyShad is offline
E46 Turko
Mein Auto: 99' 323i
How many miles do you have on it? I recently had a loss of power caused by a pulley going bad, get your cooling system checked.
Old 03-31-2011, 11:36 PM
KrisL's Avatar
KrisL KrisL is offline
Ubergeek
Send a message via AIM to KrisL Send a message via Yahoo to KrisL
Mein Auto: 330i ZHP
Fuel pump.
Old 04-01-2011, 12:47 AM
E46 Turko
Mein Auto: 99' 323i
^^oo forgot about that one lol
Old 04-01-2011, 09:26 AM
It currently has 172,000 on it.
Old 04-01-2011, 09:33 AM
Thanks for the answers im going to do a pressure test today and see what i can find out.
Old 04-01-2011, 10:28 AM
KrisL's Avatar
Ubergeek
Mein Auto: 330i ZHP
I recently had the same problem. My pump was returning the right pressure at idle, but almost nothing was coming out of the return line... it couldn't do much more than idle the car.
Old 04-01-2011, 10:41 AM
When the car starts it idle's and even rev up like a healthy motor it's only during driving conditions it starts acting up.The only code the scanner is picking up is o2 sensor bank 2 sensor 1 i dont see that causing a hard start sometimes
Old 04-05-2011, 10:51 AM
Snwbrdtec Snwbrdtec is offline
Send a message via AIM to Snwbrdtec
Mein Auto: '04 BMW 325XI
I had this problem recently as well. Could be a failing/weak coil or a fouled spark plug... Are you using the NGK/Bosh/OEM plugs? Are the coils origional? Missfire will cause the O2 sensors to throw a code...
"You know that warm and fuzzy feeling? That means something BAD is about to happen..."
'04 BMW 325XI
'99 Ford Explorer Sport SOLD
'93 Honda Civic VX hatch WRECKED begging to be rebuilt
'93 Jeep Cherokee Sport SOLD
Old 02-03-2012, 01:59 PM
Ben810 Ben810 is offline
Mein Auto: E36 316 m sport
i know this is an old post and sorry if this is a stupid question, but im having similar problems on mine and have just replaced the thermostat and had problems bleeding the car, now the car missfires really bad, backfires pulling off (gaines power imediatley after backfire) and idles really low with lower exhaust tone,,, could the coolant system cause these problems, like ohmyshad said in his post ?
Old 02-06-2012, 07:52 PM
wzz 323 wzz 323 is offline
*dajoose
Mein Auto: 2000 323ci
I had the same problem last week..changed coil packs and plugs and issue resolved. I have 155,444 miles on mine. Way past due......
Sent from my SCH-I500 using Bimmer App
Old 08-22-2015, 10:44 PM
girlsdrivestick girlsdrivestick is offline
Mein Auto: 328i
Did any one find the solution to the problem? My BMW has been doing the same thing as the guy who posted this, and I havent really been able to find an answer to it....
Ive put new spark plugs in, and a new cam positioning sensor, and still having this issue. Any help would be much appreciated.
Old 08-22-2015, 11:21 PM
Fast Bob's Avatar
Fast Bob Fast Bob is online now
Keeping it surreal
Your fuel pump and filter are now 15 years old (assuming they`ve never been changed).
It`s time !
The road goes ever onward....
(R.I.P. Jever)
Old 08-22-2015, 11:24 PM
Mein Auto: 328i
Thank you for the reply, I'm going to start with the fuel filter, and then if that doesnt solve it. then im gonna do the fuel pump!
