#26
WOW bluebee nothing gets by you! lol that's a good thing. Actually i didn't even notice, when i was on youtube i clicked the box for the "short link" and that's what it gave me.
Andreas Queens NY BMWCCA# 186796 86 325es (wrecked by careless driver) 87 325 300k (project for life) aka 1BADETA/Christine 00 540is 6spd 202k (daily driver) |
#27
I was an EMT in my college days (emergency medical technician). One of the many classes I took was called 'light extrication'.
It was fun (jaws of life to pry doors open, air tools to cut handles off of doors, we even peeled the roof off a junked car ... it peeled like a can of sardines. Of course, we also extricated dummy heads shoved through windshields (you cut the head loose, with the glass all around as a necklace, believe it or not); and, we destroyed quite a few side and rear windows. None, and I mean none, in any normal car, are at all difficult to break. Here's a DIY for breaking a (tempered glass) side window:
Try it. You'll see. What does NOT result immediately in shattered glass is smacking the glass in the center with a mallet. It 'might' shatter the glass; but as often as not, it will just bounce off (and if it does shatter the glass, you spray it all over the occupants presumably trapped inside). We were judged by how much glass we didn't get inside the car, by the way. |
#28
In addition to programming the transponder code, don't you also have to 'cut the key' (the grooves and bumps in the metal blade) in order for it to start the car? |
#29
Previously, I simply cut-and-pasted the browser navigation toolbar results which always embeds the youtube video. Clicking on Share and then "Short URL" provides a link which isn't embedded. - That's nice! I've just added that recommendation to the thread on how to post pictures and video to Bimmerfest: - Everything Else > Site Feedback / Questions / Suggestions > How to post shrink modify edit annotate merge upload etc pictures for posting here |
#30
hahaha ur funny in a good way bluebee
#31
2001 540i - Orient Blue M5 bumpers, wheels, mirrors S/C, water/air IC A1 Headers, Random Technology Cats, Eissenmann Exhaust 3.15 diff, evosport power pullies Koni Sports, Eibach Springs/Sway Bars |
#32
Let's clear up some misconceptions in this thread :tsk:
The plastic wallet/spare keys as well as the other 3 available key types for your car has an EWS transponder chip inside it (remote, illuminated, & valet/service keys). Without the chip...the key has no way to start your car. The ISN (individual serial number) is required EVERY time you start your car...and the communication between the DME, EWS control module, Transmitter/Reciever (on older models), Ring Antenna, and the key must ALL communicate and identify that it has the same ISN as all the other EWS components. ![]() Quote:
Now, on the other hand, there are some companies (one is in Canada and advertises heavily on some forums) and possibly some repo companies...that have aftermarket equipment that can retrieve the ISN & password info from EWS, and can copy that info into a new chip. Since the copied info is not NEW, but a copy of existing information...the key can work...fooling the EWS system into thinking that it is using one of the keys that's already been programmed into the EWS control module. So again, both of you were right, but just on different pages. ![]() ![]() ![]() Quote:
Also, if you've locked the car with the key (manually or remotely) the doors can't be opened from the inside...even when you pull twice on the interior door handles. This "double-locked" feature changes slightly with the 2000-up model years. They can be opened after pressing the center console unlock button and pulling twice on the door handles. The alarm will still go off, but the doors will open. Note: interior trunk release button won't work if trunk has been "secured separately"
Q {BMW CCA Member #191509} 2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 97 740iL (Arctic Silver) 3/97 mfg date (SOLD) 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White) 91 735iL (Schwarz Black) <<~>> 85 325e (Bronzit) Last edited by QSilver7; 04-03-2011 at 11:01 AM. |
#33
All I said was the plastic key would open the door. I never said they would start the car. I have a copy of my Jeep's key without a chip that does the same.
Sent from my iPhone using BimmerApp |
#34
The last two things are what I made a reference to that were incorrect. The plastic keys DO have a transponder chip in them...and they also do more than one thing:
Letting that statement stand without clarification could confuse some people that may find it doing a search into thinking the plastic spare/wallet key would not be viable as a backup key...especially if they were led to believe that it DID not have a transponder chip in it. I wasn't trying to bust anyone's chops...just didn't want incorrect info to go unchallenged.
Q {BMW CCA Member #191509} 2006 E53 X5 4.4i (Sterling Gray) 12/05 mfg date <<~>> 97 740iL (Arctic Silver) 3/97 mfg date (SOLD) 99 540iT (Orient Blue) <<~>> 95 525IT (Alpine White) 91 735iL (Schwarz Black) <<~>> 85 325e (Bronzit) |
#35
I'm glad you did. I put this link into the bestlinks for future reference:
- The truth about the BMW diamond key transponder (1) and proper initializing (1) (2) and the truth about the 10-key limit to programming your own keys at home (1) & opening, charging, recoding, & battery replacement (1) of the new-style diamond key (1) (2) (3) (4) (5) (6) & converting the old-style 1996-2000 "square" key to a diamond key (1) & how to replace the rubber key pads in the old style keys (1) (2) & what to do if your key is locked inside your car (1) & a description of the various types of BMW "Remote", "Illuminated", "Spare/Wallet", & "Valet/Service" keys (1) (2). |
#36
Just as a suggestion, while we're talking about keys, if you do have both master keys, I'd suggest to make it a routine to swap the keys you drive with. This is only true for the 99 & later models that have the diamond key that charges itself as you drive.
In my case, I used to only use 1 key, and kept the other master key as a backup. But, I became worried when I started thinking if I didn't use the "backup" key, it may lose it's battery's charge. So, now I swap my keys so that both stay charged up. And, to be clear, that's charged up as in working the key remote for arming/disarming your car & opening the trunk. Having a charged/discharged key doesn't affect actually using the key to start your car, only to work the remote functions.
2000 740iS. MKIV, 16x9, DDEs controlled by Euro fog light switch, reversed steptronic +/- pattern, paddle shifters, clear corners, Basslink, Alpine DVD changer with stereo audio, TV tuner, gauge rings, ///M pedals, backup camera with 'on demand' switch, quad brake lights, Dinan engine & tranny software, windows/sunroof close via remote. 2003 540iS. MKIV, 16x9, PDC, CWP, TV tuner, backup camera with 'on demand' switch, paddle shifters, windows/sunroof close via remote, iPod video & audio. |
#37
#38
I don't know if we have a pic of the plastic-key chip, but here's a pic from QSilver7 himself from over in this thread of the diamond shaped key:
- Is there a "transponder" underneath the copper wire in the diamond key
#39
Apparently the transponder in the old (square) key is a 'loose chip':
- DIY - easy way to make a brand new diamond key work in your older car (96-00) |
#40
When I called with my problem I was asked vehicle details (BMW 528i e39....etc.) and when the representative arrived he promptly pulled out a small bag that he then inserted into the gap of the boot (trunk) lid and body - when I queried this he explained that they had attended specific courses in how to gain entrance to various vehicles and over-ride their security features. The e39 apparently has a wiring harness that runs down the driver side and is easily accesible at the trunk all he did was insert the deflated bag pump it up until a small gap had been opened (5-10mm), then he inserted a flat plastic hook and 'fished' out the wiring harness , he asked me to turn my back and cut one of the wires which he then connected to a power source and 'Hey Presto" the entire vehicle lock and alarm system disengaged!! I was both relieved and horrified at how quick and easy this was done. |
#41
For the record, another mechanical key lock opening problem was reported today:
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! |
#42
Yup bmws security system can be a pain in the butt. Couldn't you unscrew the back seat and go into the trunk that way. It sounds like you still had access to the car
Or were u locked out with the key locked in it |
#43
#44
Lots more on that backplate over here ...
- Rear center cushion armrest customizations (1) (2) (3) (4) & the E39 rear ski-bag arm rest pass-through retrofit DIY (1) (2) (3) (4) (5) (6) (7) (8) (9).
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
