Old 04-02-2011, 04:03 PM
LEOT LEOT is offline
Mein Auto: x-3
Passenger side mirror
My passenger side mirrror stopped working, won't tilt on reverse, can't adjust with switch, and doesn't defrost. I checked fuses and didn't find anything. Any ideas. 2007 X-3
thanks
Old 04-02-2011, 06:36 PM
vern vern is offline
Send a message via AIM to vern
Mein Auto: 01 330ci 05 530i 06 X3
thanks
Try moving it around by hand and then try to adjust it. Good luck
cheers
vern
2012 335iA Blk. Sapphire- Sport-Blk. Dakota Leather/Red-Brushed Alum.Trim-DAP-PP-CWP Rear View Camera-BMW Asst w/Enhanced BT&USB-High Gloss Blk.Trim Hghight-PSP-Speed Limit Info-Tech. Pkg-PDC-Rear Manual Sun Shades-SAT-Variable Sport Steering-Wheel Locks- Rubber Mats-Euro Del 5/14/12-Redelivery 7/16/12 2006 X3 3.0iA 4/6 Silver Gray Metallic-Black Leather-Nav-PP-SP-Xenon Headlights-PDC-Heated Front Seats-Privacy Glass-Servotronic Steering-Premium Sound System-R R R- Wheel Locks- Rubber Mats
Old 04-03-2011, 09:08 AM
UncleJ UncleJ is offline
Mein Auto: '09 Cayenne "S"
Mine works like it has a mind of its own. One day it works fine, the next, nada. Sometimes moving the L-R switch back and forth triggers a response, but somethimes nothing. I don't like it enough to do anything about it. If I need the mirror to point down, then I will point it down with the manual directional switch.
Old 04-03-2011, 12:03 PM
Mein Auto: 2004 X3 2.5i
... and doesn't defrost.
How did you confirm it doesn't defrost?
I think they switch on only when the ambient temp. as measured by the sensor is below 45F or something.
If it definitely isn't heating up the glass, then you have something more than a sticky tilt mechanism wrong.
A few people have had to have a new window/mirror switch, which somehow seems to control the heating ribbon as well as the expected mechanical functions.
Old 11-14-2011, 02:40 PM
Mein Auto: x-3
When it was cold and frosty it didn't defrost like the driver side. Any test I can do to see if its the switch. Also forgot to mention when I use the "fold mirror in" switch, the drivers side mirror folds in but not the passenger side. Seems like all mirror functions dop not work on that side
Old 11-14-2011, 06:01 PM
littleengin littleengin is offline
Mein Auto: 2006 X3 M-Sport
I had this same issue. It was fixed at the dealership. I believe they changed the motor.
Sent from my ADR6300 using Bimmer
Old 11-16-2011, 08:07 AM
X3 Skier's Avatar
X3 Skier X3 Skier is offline
Powder Days
Mein Auto: 2016 X3 28i
Mine stuck once. I pushed it by hand and it has been fine ever since.
Cheers
Just Some Consultant
"I never understood the dread term "terminal illness" until I saw Heathrow for myself." Dennis Hopper
Old 11-16-2011, 07:51 PM
bluskye bluskye is offline
Mein Auto: 2006 330i / 2007 X3
BMW mirrors snap into the motor that moves them up/down/right left. There is another electrical connection to the mirror itself that performs the defrost. Essentially, the mirror is coated with a resistor like material that heats up the surface when electricity is applied. You can safely remove the mirror itself by simply pulling it away (toward rear of car) and it will snap out of the motor/actuator. Yeah, its that easy.
If the mirror is just not defrosting ... simply replace mirror. If the motor is busted, it requires taking off the interior door panel to gain access to the bolts that hold the mirror assembly on. Ive done it on my old E46. Not fun, but not impossible.
Sounds like you have another problem if both motor and defrost are not working as they are separate systems.
Old 11-21-2011, 09:22 AM
Mein Auto: x-3
Yes..the mirror adjustment doesn't work..just on passenger side, the fold in switch works since it folds the driverside but not passenger side, and of course the defrost doesn't work, only on 1 side. Could be it as simple as a ground wire in the mirror? since all functions do not work..
Old 12-29-2011, 09:00 AM
Mein Auto: x-3
Just trying to bump this up to see if anyone has found a solution.
Old 12-29-2011, 09:31 AM
Dominic49's Avatar
Dominic49 Dominic49 is offline
Mein Auto: Bmw
8 months later and you still haven pulled the cover off to expose the wires?
Old 12-29-2011, 10:13 AM
Mein Auto: x-3
I did but there is a "ribbon" wire, similar to a computer connection to a hard drive. Not a lot I can do with that. Doesn't seem possible to check voltage etc.
Old 12-29-2011, 10:15 AM
Dominic49's Avatar
Mein Auto: Bmw
you need to check it at the mirror connection and at the module. you want to check for continuity not voltage.
furthermore please inform us of everything else you have tried.
Old 12-29-2011, 10:37 AM
madurodave's Avatar
madurodave madurodave is offline
BMW Enthusiast!
Mein Auto: 2007 Z4+X3, 2006 530Xi
Sounds like the mirror motor to me. But since you lost defrost too, who knows.
Madurodave
My garage: 2013 BMW 550xi GT, 2007 BMW Z4 3.0si Manual, 2006 BMW 530xi
Retired: 2007 BMW X3, 1998 BMW Z3
Member of BMWCCA!
Old 09-30-2012, 05:32 AM
BMWNL BMWNL is offline
Mein Auto: 2006 325XI
Want to remove folding mirror feature
My mirrors fold all the way out automatically every time I get in the car and I have to fold them to the correct position by hand. Drives me nuts. I tried hitting switch, moving them in and out by hand etc but they still keep folding all the way out every time I push key fob to get in the car. Dealer wants $700 for a new mirror car is not in warranty. Seems there should be a limit switch or little mechanical connector to fix without replacing whole mirror but after spending hours on this site I can not find a fix. I am happy to just disconnect a wire to remove fold in and out feature - if anyone can tell me how this will be appreciated - do you know if this will show and error on instrument cluster?
Old 10-05-2012, 10:02 AM
sjladopoulos sjladopoulos is offline
MotorPress.ca
Mein Auto: 2007 BMW X3 3.0si
look here:
http://www.bimmerfest.com/forums/sho...d.php?t=624838
Old 06-25-2015, 02:48 PM
P19 P19 is offline
Mein Auto: BMW E46
Passenger Mirror not adjusting
I have the exact problem as LEOT did on my E46. What was the solution to the problem?
