7 Series - E65 / E66 (2002 - 2008)
Discussion pertaining to the flagship BMW here. |
#76
'11 328i '03 745Li '03 Acura TL-S '02 Infiniti QX4 |
#77
Here are a couple of pics. The first one is the headlight with the flange removed with the dremel and now I am cutting the rubber to remove the lens. "Apomerans" drew a good diagram of what it is like and he labels them Cut #1, Cut #2. You cannot complete this task with cutting #2 only. I did not realize this with the first headlight I did and I had to then go back and cut all the way around again with his Cut #1. The second headlight I skipped cut #2, and went right to his cut #1 angle (still follow me?). I had better results cutting #2 first, then going back and cutting #1 (all still referencing Apomerans diagram drawing).
The problem with going right to cut #1 is you are cutting blind and can go too deep into the inner housing (making a hole into the headlight). I made a small error, this but was able to re-seal when I RTVed the lights back together. The first pic shows the rubber is UNDER the lens that has to be cut out. All in All, it was SO worth it to me. The front end of the car looks so much cleaner and new. If you have angle eyes it makes them ALOT brighter!!! I do NOT regret this mod at all. The good news is, if you have to re-do it again, you only have to cut the RTV, no more dremeling next time...
#78
(I made a couple of edits after I re-read my post).
Oyeah, whoever said you could get this apart by "baking" them?? I want what your smoking... This $**** is like tire rubber. An angled blade would have helped me, less stuff to dremel around to get my box knife into. Someone mentioned a dentist tool kit, that probably would have been better.
#80
The dremel work took about 20 minutes per headlight. The cutting of the rubber under the lens takes about 1 hour each.
***IMPORTANT NOTE*** Your side markers are snapped in, if you remove them to paint them, glue them in place. I have one side marker that is moving around a bit.
There hasnt been much discussion on it, and Im still very intersted in where (if possible) I can order just the headlight lenses for this car. Headlights themselves work fine, and since its a unit that was assembled in pieces Id assume (somewhere, some how) I would be able to purchase the lenses only. Please advise guys
#83
I plan to take on this project on Wednesday or Thursday. Couple quick questions/concerns before I pull the trigger. #1. Do I Dremel around the entire headlamp assembly or just the top lip that covers the lens seal? #2. If I want to paint the orange side marker black (or Anthracite Grey), which kind of paint do I use? #3. How long do I let the sealer bond/cure before putting the headlamps back in? Sorry for the rookie questions but I'm still a little hesitant due to the fact that our headlamps are a couple months rent. I have to do it tho because I hate the inside haze more than I fear f*<%ing up. Thanx, 'Fest!
#84
... more than I fear fouling up ...
#85
Did this today took me all day practically nice sunday project. Drivers side was HORRID. 100x better. Light cutoffs look perfect now. Thanks for the writeup and giving me the courage to dremel my headlamps open
06 X5 3.0 Toledo Blue Metallic/Light Beige 2: Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades, +Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs, +White Angel Eye LEDs, +4300K Foglight HIDs, +Blacked Out Chrome Grill Surround .. more updates to come PREVIOUS 2002 745i |
#86
Glad to see it worked for you bro. How about some pic so we can see how well you did.
Ill post some up tomorrow of it on the car. Heres a pic of the lens and the housing without it. Didn't take many pics but being an 02 you can imagine how they looked before. Dremel i bought from home depot for 50$ and came with attachments. The light output was well worth the cash and the time
Also would like to add the lens pic was taken after i used some goo gone spray on the inside. It took most of the grime off before more thoroughly cleaning and polishing. Used 3m, and meguiars. Buffed and polished. Didnt sand it as i did not have much but crud on the inside and out.
06 X5 3.0 Toledo Blue Metallic/Light Beige 2: Adaptive Xenon Headlamps, Panoramic Sunroof, Rear Sunshades, +Factory Aux Input in Ashtray, Bluetooth, Rear PDC Sensors, Rear Electronic Adjustable Seat Backs, +White Angel Eye LEDs, +4300K Foglight HIDs, +Blacked Out Chrome Grill Surround .. more updates to come PREVIOUS 2002 745i Last edited by 745iguy; 01-13-2013 at 09:39 PM. |
#88
I think this is generating a new generation of seven's owners.... the one's that have cleaned the interior of their headlights and the one's that are supossed to do so in a short time!!!
Well done!!!! |
#89
Daytime
#90
First I was afraid, then scared s#§%less. Once you dremel that case YOU ARE commited.
And no joking, cutting the seal all around is multi-hour PITA. Just put the glass back in with the 3M window weld urethane. Can't wait to see it back on the car. Thanks for all the good advice in this thread.
Silver 2004 BMW E66 / 745Li (DIYs): ASK, Logic 7, blower, battery, guibo joint, active stabilizer bar bushings, diff oil, tranny sw update, vacuum pump gasket, window lift, a/c compressor, washer fluid reservoir, belt tensioner and deflector, crankcase vacuum hoses, crankcase vents, solenoid gaskets, headlight overhaul, ISM, hood lifts, driver mirror, sway bar end links, rear fog lamps, headlight washer next up: headlight vertical aim, VCGs, P0492 |
#91
head lights
Nice! Thank you for blueprint man.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
