#101
[QUOTE=musa;6292510]Details, please, details! How hard was it to snake it in? Did you cut the old one or snake the old one out (I would imagine this helped you how to snake the new one in)? Did you remove the oil-level sensor to help snaking in he new pan gasket?
Thanks for any pointers! [/QUOSSnaking it was scary because i thought it was too much of a bend for the gasket but its a metal gasket so it bent back easily... It wasnt difficult. the old one was torn apart. After 200,000 miles some of the gasket stuck to the oil pan frame but it can be taken off with a razor of some sort. I was replacing my rack and pinon and thats all i took off which gave me a little wiggle room. I loosend the engine mount bolts and jacked up the engine by the main engine pulley which is right in front of the oil pan gasket. I had to loosen the fan shroud so i wouldnt brake the fan. |
#102
- You had the steering rack out, so it gives you some extra room to lower the oil pan. - Jacking up at the Crank Pulley is a no-no. I am glad you got away without any issues. The engine weighs about 350 lbs or so, jacking it up require more force b/c of the hoses and constraints on other parts, so the force to jack it up in the car is more than 350 lbs. You are lucky your Crank Pulley did not go caput. |
#103
So this thread is exactly what I was hoping to find. I have a 2001 325i with almost 160k miles. I have owned the car for 5 months and have been aware of the oil leak. It appears the valve cover gasket was over tightened and needs changed but I was getting very suspicious that the leak was more than that. I took it in to get brakes and oil change and have it looked at for the leak. It seems the oil pan gasket is the main issue. the pan is clean above the seam but covered in oil below it. *Does this sound to you guys that its good evidence that the oil pan gasket needs changed?
I have mechanic friends that could pull off this DIY method, but I am wondering if I should have concern about not doing it the right way in order to do a thorough cleaning b/c of the high mileage. The $ aspect is the real motivation for me to try it this way so I guess Im just looking for some advice from more experienced owners. Thanks. |
#104
I'm right in the middle of doing this. I have the patient up on stands and drained of oil, engine brace hooked up and ready to drop the crossmember. I'm changing engine and gearbox mounts at the same time.
Hecs21 : My oil pan is the same. leaks around the seam, no oil higher up the engine. You do need to first ascertain that it isn't the oil filter housing (see separate threads on this) because this is a more common leak. It's not easy to diagnose this so have someone check that out. I think it's unlikely you need to clean the pan. In all the photos I have seen of oil pans removed, I've never seen one that is full of sludge and debris, unless something has let go. There was one thread with a sludgey engine, but you could see the sludge through the filler cap. I was quoted 'at least' $900 to do this, which made me immediately run to the internet for a case of 'there's got to be another way'. And thankfully there is, it would seem. |
#105
Ahh- not so good
So I got the old gasket out. I decided to snip the old gasket in the location I expected to cut the new gasket.
So I positioned the snips and gave it a quick cut. Only to hear the horrifying tinkle of bits and pieces landing in the bottom of the pan. I tried to snake the old gasket out, and it broke in half. See picture: ![]() I cut at a diagonal (best way to get access) in the bottom right (LHS, rear of engine) and the front right of the gasket broke in half while attempting removal. The tinkling of bits falling into the pan are pieces of rubber. Much of the rubber material is hard and brittle and it has broken off and fallen in during the process. No surprise why it was leaking everywhere - the old gasket is toast. So I've got the engine on an engine brace, subframe is undone and sitting a few inches low, but I haven't touched the steering rack, power steering pump or sway bar mounts. At this point I guess I'm in for dropping the entire crossmember right down to completely remove the pan and retreive the bits that fell in. Anyone got some tips on getting the crossmember/subframe down further? What do I have to remove? |
#106
Jason5Driver : ForcedFirebird was referring to an E46, which was established elsewhere. The subframes are different. I'll try it out though.
#108
We use alldata at the shop and the same exact procedure is outlined for the 3 and 5 series. |
#109
I wish I could get it out because several bits of hardened perished rubber from the old gasket went into the pan. I've fished a bit out but I know there's more in there. It's all in bits about the size of toenail clippings. For all I know they already had fallen in before I removed the gasket and that is why it was leaking. I'm just going to have to entomb these bits in the engine and hope they come out with the next oil change. At least the rest of the pan is squeaky clean. I've got a fair amount of clearance to put the new gasket in though, I'll try and snake it under the oil pickup. Otherwise I'll do the cut/glue method and hope for the best. |
#110
So an update.
I couldn't get the subframe any lower so switched to clean out mode. Put on some rubber gloves and gave it a very thorough internal caress - working blind, but just feeling for bits and pieces. I also found a chunk of plastic in there - bizarre - it was about an inch long and looked a bit like a piece of zip-tie (but it wasn't zip tie, just similar). I got out probably 70% of the bits (going by the missing parts of the gasket) - the only part I couldn't reach was down around the oil pickup. I decided to bite the bullet and cut the gasket just to move forwards as I probably spent 4 hours going around in circles and getting nowhere. By this point I didn't care if it leaked oil every day for the rest of it's life I was just 'done' with trying to get more access to the pan. I'm already about about double the amount of time I expected to put in and I still have to put all the power steering pump, subframe, sway bar, dipstick, air box yadadada back on yet. Forgive me BMW for what I am about to do: ![]() Here's the gasket in-place - cut is just visible behind the oil pipe.
#111
Update from Mudbone
Hi all,
I got a PM from Cam asking for an update and an answer to a couple of questions. "1. How the heck you did it so well, while others had trouble removing old gaskets. Maybe they wait too long, at that time the gasket crumbles. Did your old gasket come out nicely, i.e., not crumbled? 2. Long-term report: any leak?" Answer to #1 - Could be I'm just lucky. The gasket was not "stuck" when I unbolted the oil pan. I merely pulled it away from the pan far enough to cut it in a couple of places and took them out. The rubber on the gasket was actually still "sort of" pliable. Given that, I'm not sure why it was leaking. I was concerned about it before I began. My backup plan was to spray/pour mineral spirits into the oil pan to flush out anything that might fall in. Plan "B" was to buy "that Jim Dandy DeWalt boroscope" they have at Loew's in order to be able to look around in the pan for the debris. It is approx $300 and could probably be returned after use if sufficient care was taken. Answer to #2 - Still NO LEAKS - Tight as a drum. I applied a generous portion of sealant at the 2 cut lines. I hope this helps anyone considering undertaking the DIY. |
#113
Did not disconnect rack. I can see with the rack out you would get the needed drop on the pan to get it low enough to remove. I looked at this for a while before I put the subframe back on. The problem is that the mounts at the rear of the subframe didn't drop at all, even with everything removed. Maybe I didn't disconnect the sway bar properly and somehow the torque from that wasn't allow it to drop. Maybe it is the 'pivot' point of the rubber jack point, such that the centre of gravity means that the front wants to fall forwards (I think the axle line is forward of the jack point?). Maybe removing the wheels might have helped in changing the centre of gravity. The subframe itself wouldn't go lower because of teh various hose still attached - I think these are both the powersteering (goes back and forward in a loop, presumably for cooling?), and the attachments to the rack itself. Either way, that subframe was never going to come down without a heap more things coming off. That's when I cut my losses, cut the gasket and just fished around in the sump with my hand to find any bits that fell in. I put them next to the dead gasket and I'm confident I got 90% of the bits that came off the old gasket. I found some other bits of plastic in the pan that had nothing to do with the gasket so I'll assume the odd bit of large non metallic detritus isn't going to kill the car. It's not a race engine. It's not ideal, but after having spent probably 15 hours just to get to the point of putting the gasket on, I had to start moving forwards somehow. I lost the screw that holds the dipstick tube on so I haven't started it up yet (had all parts in a tray but a slipped nut meant I sent the tray flying). I suspect some are in the cold air intake. ForcedFirebird - if you do another M52/M54 on an E39 could you possibly spare 2 minutes to take a photo of the subframe down far enough to remove the sump? |
#114
As for the flush - it's a tough one, because the front of the pan is lower than the middle, so you'd have to fill it right up and hope the bits float to get everything out. There is a good half inch of oil sitting in the front part of the pan after draining the oil. I took your advice and drained the oil for 48 hours before undoing the pan, and it still dribbled oil continually while it was off. In fact, the continuous dribble of oil made it very hard to get a good bead going on the sealant in the cut position (I did the corners as well). I'll post more pics of my entire process either in this thread or a new thread. I did take a lot of photos. I did make mistakes which caused me to have to re-do a lot of things so I will be able to provide a lot of traps for young players to avoid. EDIT : Forgot to add : this car has about 75,000 miles on it. The gasket was completely gone and brittle. It didn't stick to the block or the pan, but the rubber gasket part did shatter when I cut it to remove it. There's not much you can do about this except be prepared for it, maybe slide a thin piece of cardboard or plastic under the section you're going to cut before doing so. If I were to do it again, I would cut my old gasket in about 4 places and slip something underneath the snips before doing so, to prevent pieces falling in, so you can carefully remove the pieces without having to drag any of the gasket 'across' the pan. You want to remove the old gasket always in an outwards direction. Last edited by brc5; 09-25-2011 at 07:20 PM. Reason: added info about gasket. |
#115
The gasket arrived two days ago but I'm yet to muster enough courage to tackle the project, especially given the the difficulties people are having with this method. But the quote I got from my mechanic for the job is enough motivation to DIY.
#116
musa - it's all about gathering all the parts, the contingencies and the tools. There are no shortcuts, you need all the stuff, and you need to be prepared, patient and methodoligical. I'd rate it a 5/10 for difficulty, and 8/10 for PITA level.
I advise getting a dipstick tube o-ring and maybe an oil level sender o-ring as well. You will end up removing both these parts so it's good to have a fresh o-ring to put in. The cost is negligible, and you'd hard to stop the gasket leaking only to create an o-ring leak. Also consider replacing engine mounts while engine is off subframe if you're dropping the subframe. Chances are you could use some fresh ones. The problem is that many localities have rules regarding oil leaks w/regard to inspections. Often no oil leaks is a requirement of vehicle registration. But the price of fixing is massive, so you'll probably end up under the car cursing. All part of the ownership experience I guess ! |
#117
I am still amazed at how the Original Poster (Mudbone) did it without major issues.
Perhaps the most important thing is: if the old gasket comes off cleanly, then you are OK. If the old gasket breaks up in bits and pieces, you then deal with the same issues as brc5 is having. |
#118
After I completed the job I was dismayed to find that I still had an oil pan gasket leak! I'm pretty sure it's just a matter of not tightening the bolts enough because I was afraid of stripping the threads. That said, I just haven't been motivated enough to get back under that car. |
#119
This is the key: once you have an oil pan leak, do it soon and hopefully the gasket comes out nicely (not in bits/pieces). Once the gasket comes out nicely, do it the Mudbone's way LOL! If you wait too long (1-2 years after you first have the leak), then the gasket maybe stuck to the oil pan! |
#120
The torque rating on the pan bolts is 10 Nm which is virtually nothing. My torque wrench only goes down to 25Nm anyway, and there's no way you're ever fitting a torque wrench down there anyway. The 2 or 3 bolts above the dipstick area are near impossible to reach with a socket anyway. I just settled for a snug tighten and tried to manually match them all up so they all felt the same. I completely agree that you should just start with the objective of removing the subframe and work towards that. I also tried to shortcut my way in and just ended up taking twice as long because of the lack of space to get to the pan with the subframe in the way. Interesting that you took the rack off and control arms off - one of the things holding mine up was the hoses for the power steering rack, so that would give more play. But did yours drop straight down, or did it pivot backwards so that the rear mounting points stayed close to the car, but the front ones dropped down the most? |
#121
- Slide the "drywall taping knife" (the tool used to patch drywall) under the gasket and gently lift it off. - Then one finger behind the rubber part of the gasket pushing it outward while you cut the gasket to keep the rubber from cracking and falling in. This is what I mean by "drywall taping knife":
#122
THe problem for me wasn't the gasket sticking to the block or the pan, it was that cutting it shattered the brittle rubber, and when I abandoned cutting it, snaking it out also caused bits of rubber to fall off. The gasket came away fine, it's just that the moment any of the rubber touched anything else (camshaft drive sprocket, oil tube, anything) it crumbled away in little pieces about the size of toenail clippings. Same with your finger - the slightest pressure on the rubber crumbles it away, there is no flexibiltiy left. Maybe mine is an extreme case, but it's a possibility for anyone who removes the gasket. I took a close-up of the bits of rubber - hard to photo something small and black clearly, but hopefully you'll get an idea of what we are dealing with here. All these were retrieved from inside the pan: ![]() I think the best way forwards would be to cut with snips as I did, but place something underneath the snips to catch the pieces if they come off. Something like a plastic ice cream container lid or similar. It would need to be flexible enough to bend it into position but sit nicely once it was in position, and if you slid it under the gasket and angled upwards so any pieces would fall onto it and slide down out of way the pan once cut. With this type of setup, I would cut the old gasket in 4 places (as near to the corners as you could get) so that I could pull outwards on the gasket in all directions. However, if you have bits of rubber stuck to the block or pan then you're going to have to come up with something else to stop bits falling in. I would also think about the mineral spirits or similar flush idea, and have some at the ready. I would probably remove the oil sender unit before doing this though. But the flush method relies on the bits floating out, which I'm not sure would necessarily work. THere are plenty of nooks and crannies in there for them to stick to. |
#125
Yes, I unbolted the sway bar, but perhaps I didn't do it properly or it was stuck on or something, because it didn't really change anything for me. Maybe the torque of the sway bar was pushing it up because one of the brackets was stuck or bound on or something. I think a photo of an unbolted and dropped subframe would be great just to see how much drop there was at the back. When I undid mine the back of the subframe was tight against the car, you couldn't fit a finger between it. But at the front it was down a long way, long enough for me to fit my whole arm into the pan and feel around.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
