Old 08-19-2012, 10:34 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
For the record, so anyone reading this in chagrin, will know they're in common company, it happened again today:
- > E39 (1997 - 2003) > SRS Airbag Rest Tool In Sacramento Area
Originally Posted by PatmanBMW View Post
Like a bonehead, I was fixing the front window and disconnected the air bag before disconnecting the battery. Now the airbag light is on.
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders.
See also: E39 Bestlinks & How to easily find what you need, in seconds!
Old 10-26-2012, 09:05 PM
bluebee's Avatar
Happened again today:
Originally Posted by Black_B View Post
I recently replaced a window regulator and started the car to check the window operation with the airbag module unplugged. Now the airbag warning light is on. How do I delete the code and turn off the light. There is nothing wrong with the system it just set a code when the module was unplugged.
Old 11-27-2012, 09:54 AM
bluebee's Avatar
To keep these together to help the next person know they're in common company, here's another SRS airbag light thread posted today - this time from changing out the seats:
> E39 (1997 - 2003) > airbag light
Old 01-11-2013, 07:36 AM
bluebee's Avatar
Here's a first post from someone today with the air bag light after replacing a window regulator:
Originally Posted by Grzano View Post
The Drivers window regulator went bad and I replaced it a few months ago. Within one month the replacement stopped working. It seems that the wires controls are getting hung up on something. Has anyone had this problem? Also, note, before removing the airbag, you need to disconnect the battery otherwise it generates an airbag fault. No need to ask how I discovered this. lol.
EDIT: And another one today:
> E46 (1999 - 2006) > Driver SRS Warning light after changing window regulator
Old 03-12-2013, 09:53 PM
bluebee's Avatar
Originally Posted by Shogan View Post
I changed the window regulators. Followed good safety and disconnected battery to remove airbags. Oops, I reconnected without hooking up airbags. Now the SRS light is on. I'm looking for someone in my area (Salt Lake) for a reset. I'll pay, but not to the dealer.
I found Airbag Service to do it for $60.
Old 03-12-2013, 11:28 PM
alex712 alex712 is offline
Mein Auto: 2002 530i
Anybody in Austin TX has a airbag reset tool? Indy shop wanted $70. I didnt even bother going to the dealership.
