92 318i Engine sputters once i hit 60mph or 3,000 Rpm. - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 04-04-2011, 09:42 PM
bmwMobiletech bmwMobiletech is offline
Bimmerfanatic
Mein Auto: 1995 bmw m3
Unhappy 92 318i Engine sputters once i hit 60mph or 3,000 Rpm.
I have a 4 cylinder 3 series and when i rev it. It will start to feel like fuel cuts out once reaching 3,200 Rpm. It also does the same concern at 60mph... Has anyone had similar issue. I check fault codes and i got 1. 17 Front left inlet valve fault. Front Right inlet Valve. Last seven of Vin: NJA02775. No DME faults PRESENT
Can anyone help me solve this issue. Please!!!!!
Old 04-04-2011, 11:43 PM
Slave 2 Slave 2 is offline
I have questions!!
Send a message via AIM to Slave 2 Send a message via Yahoo to Slave 2
Mein Auto: 92 325is & 78 VW Scirocco
I usually do the cheapest and easiest first.
I'd change out the fuel filter and see if that clears it up.
Cheap AND easy.
Old 04-06-2011, 04:34 PM
Bimmerfanatic
Fuel filter, spark plugs, coils, fuel pump , and mass air flow sensor was replaced on vehicle. Any other ideas...I got fuel and spark...car has 213,000 miles...
Old 04-08-2011, 08:57 AM
AlphaTau1795 AlphaTau1795 is offline
Mein Auto: '93 325 IS
Disconnect the battery for a while, hook it back up and let it idle so the comp can remap.
had similar issue with mine
Old 04-08-2011, 09:38 AM
noexceptions325's Avatar
noexceptions325 noexceptions325 is offline
East Bound And Down
Send a message via AIM to noexceptions325
Mein Auto: 325e,Jeep,240z,528i
if you have a 92 318... its an e30 unless its imported (which would be retarded since its a 318)
but the M42 is the same engine, Sounds like the fuel filter to me
Built 325e too much to list, Heavily modified Jeep, Datsun about to get a 351, and now a 528i
Old 04-09-2011, 05:18 PM
thomason2 thomason2 is offline
Mein Auto: 1995 318i
Almost same problem
I have 1995 318i M42. My car has started stalling in all 5 gears at almost exactly 2500rpm. I have been told by multiple sources that this is due to a faulty TPS (throttle position sensor/switch). I would welcome other opinions also. I have the TPS ordered. If it does fix it I will let you know.
Old 04-09-2011, 05:38 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
Sounds logical to me.
Where are you in Alabama?
(I'm 20 miles N of Gulf Shores)
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 04-09-2011, 05:48 PM
Birmingham Area. My dad lives in Orange Beach. My sister works at the Original Oyster House. Very familiar with the area.
Old 04-09-2011, 07:48 PM
D'oh, You Kids!
Cool. If you're headed this way some time, give a heads-up and we'll get a burger somewhere.
Quotes to live by:
BMW-CCA #441426
Old 04-19-2011, 06:27 PM
TPS was not the problem...or at least not the main problem. Still getting the stall/no power above 3,000 rpm. We tested the Air Flow Meter per the Bentley manual. Getting no resistance at all across terminals 1&2 or 4&5. Not just no change...but no reading at all. I guess I should break down and buy a air flow meter....but I am so, so broke. Any suggestions of a good place to purchase?
Old 04-19-2011, 08:53 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Buy a fuel pressure gauge (~$20 from an auto parts store) and test if your fuel pump is providing the right pressure. (I do not recall what it is offhand but you can get it from the Bentley manual).
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 04-19-2011, 09:01 PM
Have you ever heard of a fuel problem causing the car to burn rich. Everything in my experience tells me it is not a fuel problem but an air problem. But this is my first BMW go around so I am very open to suggestions. Still leaning towards the air flow sensor b/c of the lack of resistance when I test it per the bentley manual but I am hoping it is not....so darn expensive.
Old 04-20-2011, 01:59 AM
jonesin's Avatar
The Canadian Prick.
My response of the fuel pressure gauge was to the OP... Your issue sounds different than his. I haven't looked into it yet. FOr your issue, try http://rockauto.com for a MAF.
Old 06-07-2011, 04:59 PM
QD QD is offline
Mein Auto: 318i
I also had this problem, however I had a rattle in my exhaust from time to time. So we checked the catalytic converter. Part of it looked like an apple and you could see where it had jammed itself in the pipe blocking the airflow. So have a look at this. Good luck
