Old 07-15-2014, 07:28 AM
Albo's Avatar
Albo Albo is offline
Der Ursprüngliche....Albo
Mein Auto: OO=[][]=OO
2003 530i (Alpine White/Sand Beige) - 18x8.5 & 18x9.5 ACS Type II Wheels - BC Racing Coilovers - Eibach Sway Bars - Beastpower Sway Bar Brackets - M-Technic Replica Bumpers - Slimmbones CSL-Style Spltters - Magnaflow Muffler - Dinan CAI - TopSpeed Performance Strut Brace - Carbon Fiber Valve Cover Fascias - Zionsville Autosport Radiator/Fan Kit - Revmax Stage II Torque Converter - AMG Paddle Shifters
Old 07-15-2014, 06:15 PM
Albo's Avatar
New Plugs and Vanos rebuilt:
Old 07-15-2014, 06:16 PM
Albo's Avatar
New CCV installed. Much easier with the OFH and Alternator out of the way:
Old 07-15-2014, 06:18 PM
Albo's Avatar
The old girl partially reassembled with an EMP Stewart Waterpump, ECS Tuning WP Pulley and new Wahler Thermostat.
Old 07-15-2014, 06:20 PM
Albo's Avatar
This girls needs a cleaning!!!!
Old 07-15-2014, 08:11 PM
Albo's Avatar
No pictures, but I also cleaned the Idle Control Valve while I was in there.
Old 07-15-2014, 08:43 PM
helmet75's Avatar
helmet75 helmet75 is offline
Mein Auto: 2000 528i 9/99
why didn't you do the CCV delete? the success rate of the delete and bypass is higher than the replacement CCV.
I bypassed mine with a catch can and couldn't be happier with the results.
CCV Delete- So happy about it too
Street Edge Coil Overs
M5 Rear Sway Bar
Hankook Ventus V2 225/55/16
Akebono Euro Front Pads- Awesome
Brembo OE Replacement Rotors- Makes my heart flutter
Stereo Fully Upgraded- Focal, CDT, Soundstream, Kicker
Old 07-15-2014, 10:59 PM
Albo's Avatar
I actually will be doing that at some point. I have a catch can as well, but didn't have the necessary ancillary fittings. So I decided to install the CCV that I have bought many moons ago for the interim.
I know it's doubling the work, in a respect, but considering the fact that the hose running from the bottom of the old CCV to the dipstick tube was severed in half, I thought it sufficient to do the swap.
Will do the bypass soon enough, my friend!
Old 07-15-2014, 11:01 PM
Albo's Avatar
When I fit the Catch Can, I'll probably leave the CCV in place.
Old 07-15-2014, 11:05 PM
Albo's Avatar
Ok... Cooling system will be completed tomorrow AM. I'm setting goals and trying to hit them!
Old 07-16-2014, 03:41 PM
Albo's Avatar
PS Pump and Alternator reinstalled.... actually...this was before I reinstalled the Idler Pulley
Old 07-18-2014, 01:20 PM
Albo's Avatar
Zionsville Cooling System in.... however found that they new lower coolant hose leaks when I started filling the system.... :-( Will try to source a new one ASAP!
Old 07-21-2014, 11:25 AM
Albo's Avatar
Started mounting the Auto Cool II PWM Fan Controller... now to figure out which wires to tap in the ECU Box:
Old 07-21-2014, 01:06 PM
champaign777's Avatar
Mein Auto: 2003 530 Sport Twins
this is some some serious engine work
you should consider to put all in PDF file for an easy access
Old 07-31-2014, 08:16 PM
Albo's Avatar
Engine fully reassembled and engine bay cleaned up. I finally installed my FCarbon Valve Cover fascias...looks spiffy!
Old 07-31-2014, 08:20 PM
JDeGraff89's Avatar
JDeGraff89 JDeGraff89 is offline
Otto Zwei-Punkt-Null
Mein Auto: 12- 2002 530i Auto,
Omg!!! I've never wanted a carbon fiber part that no one will see so bad before. In my life!!! Do they have one for the 528i? You're in the 530i?
Current: 12/16/2002 530i Auto Titangrau/Standardscwarz
R.I.P. Otto, 04/17/97 - 02/02/15 You'll be missed my drunken Bavarian friend.
"Owning one of these cars is much like owning a two year old child. It's annoying most of the time, but if anyone tries to take it from you'll kill them." J. Clarkson.
Old 07-31-2014, 08:22 PM
Albo's Avatar
I had difficulty getting the PWM controller to work with the Zionsville supplied temperature switch, so I wired it up via a SPAL single-relay wiring kit. Fan currently turns on at 97 degrees.
Old 07-31-2014, 08:28 PM
Albo's Avatar
They must available somewhere. I found mine secondhand on ebay.
Old 07-31-2014, 08:32 PM
JDeGraff89's Avatar
I'm too horrible at google right now to find it. I'll look tomorrow. It looks amazing. I've got a different intake manifold. I'll also have to do some. Googling apparently there is a turbo manifold floating around somewhere I wanna check out.
Old 08-01-2014, 08:34 AM
tmvE39/E53/Z32's Avatar
tmvE39/E53/Z32 tmvE39/E53/Z32 is offline
Mein Auto: Dinan //M5, Dinan 4.8iS,
Clean up those loose wires, Albo
2000 Dinan S1 //M5 (my DD), 06 DINAN E53 4.8iS (wife's DD), 90 Straman Z32TT (my pride & joy ride)
Gone, but not forgotten: 01 E53 3.0i, 01 525i Sport, 03 DINAN 540i MSport, 01 //M5 and 91 Z32TT
Old 08-01-2014, 09:25 AM
Albo's Avatar
Oh don't you worry about the wires...i've got a very OEM looking plan for them.
Old 08-01-2014, 12:37 PM
Jason5driver's Avatar
Jason5driver Jason5driver is offline
Mein Auto: E39 hamster w/ pin-wheel
That power steering reservoir cap/ reservoir needs replacing asap IMO...
Same for the oil fill cap as well...
Needs to be stock OEM IMO...
Old 08-01-2014, 03:29 PM
Albo's Avatar
I've grown rather fond of them...so I think I'll keep them. :-)
Old 08-19-2014, 11:45 PM
Albo's Avatar
Reinstalled the front bumper this afternoon and buttoned everything up. Took the old girl out for a 40 mile shakedown....no problems other than some previously leaked oil burning off of the exhaust manifold.... going to wash her tomorrow and take some quality pictures.
Old 08-21-2014, 01:11 AM
Albo's Avatar
Stop it Albo...your drunk!
