Old 05-08-2012, 08:47 AM
DinanBimmer's Avatar
DinanBimmer DinanBimmer is offline
Mein Auto: 1998 540i 6-speed
Well I figure with my stock 17" style 19's I shouldn't have too many rubbing issues, but I will definitely measure before I buy.
Dinan Free Flow Exhaust, M5 illuminated shifter and boot, black kidney grills, tinting on back windows, CCFL Angel Eyes, CDV delete, 15mm spaced (M5 rear sway bar soon)
Old 05-08-2012, 09:37 AM
Jason5driver's Avatar
Jason5driver Jason5driver is online now
Mein Auto: E39 hamster w/ pin-wheel
Albo,
The car looks a lot better...! Just needs more low for those wheels IMO...
Also note, that spacers and the powder-coated black lugs can be found from Turner Motorsports, ECS Tuning, and/or www.EACEuroParts.com .
Thread from Turner about information on spacers (great thread IMO!):
http://forums.bimmerforums.com/forum....php?t=1364210
I highly recommend H&R spacers.
Jason
Old 05-08-2012, 10:22 AM
Albo's Avatar
Albo Albo is offline
Der ursprünglich....Albo
Mein Auto: OO=[][]=OO
Originally Posted by Jason5driver View Post
Albo,
Jason
Excellent Link there... lots of good info regarding spacers. I would have preferred a nce name brand like H&R or Eibach, but the fact that they all use the same T-6061 Aluminum as the spacer that I bought gives me some confidence.
In addition, I've used spacers from this seller on my E46 and a Jeep Patriot (don't ask )...so I feel secure with the quality.
Want to learn about your E39 5 Series?
Click Me
2003 530iA - Mumbo Jumbo *E39 in Sig is Not My Car
Originally Posted by edjack View Post
If you don't want to do nothing, you must want to do something.
Old 05-11-2012, 09:48 PM
Albo's Avatar
Click Me
Old 05-11-2012, 09:49 PM
Albo's Avatar
Click Me
Old 05-11-2012, 09:54 PM
Albo's Avatar
Another big update coming on Sunday.... :-)
Click Me
Old 05-11-2012, 10:02 PM
Originally Posted by Albo View Post
The light hitting that looks brilliant!
Old 05-11-2012, 10:38 PM
Albo's Avatar
You should have seen the original....this one's been "modified".
Click Me
Old 05-12-2012, 07:04 AM
tmvE39/E53/Z32 tmvE39/E53/Z32 is offline
Mein Auto: 01 525i, 01 X5, 91 Z32TT
Keep in mind ....always measure the gap between the inner fender lip and the outer edge of your tire to determine how thick a spacer you can fit. I had about 16mm of space in the rear and and 17mm in the front. The 15mm spacers have brought me very close to inner lip of the fender. In fact I did notice two instances of fender rub in the rear. This should resolve itself once I install the appropriate tire size on the rear. I am currently running a 265/35/18 on the rear, but it should be a 245/35/18 on an 18x8" wheel.
I vote to roll the rear fender and keep the 265 tires unless you already have it rolled.
01 Anthracite 525i Sport, with 01 E53 3.0 and 91 Z32TT
Old 05-12-2012, 09:01 AM
NoWayJose's Avatar
NoWayJose NoWayJose is offline
Mein Auto: 00 528ia Sport
what can be bigger then having BBS wheels
00 BMW 528ia Sport
M5 F+R Bumpers, M5 Mirrors with OEM setup, M5 rear sway bar, Cluster Rings, 03 Business player with AUX input, HID fogs slim, OEM 01+ Hella headlights, EAC Aluminum Adjusters, FX-R low beam retrofit, Umnitza VXX 10w LED Halos, Hella Euro Celis Retrofit Kit, Koni yellow shocks adjustable, 19" M6 Reps, Full LEDs.
Old 05-12-2012, 09:37 AM
Albo's Avatar
The 265 tires are part of the visual problem. If you look at the front versus the rear...you can see that the rear tire looks like a "block". The sidewalls actually have to curve inward in order to have the beads seat on the wheel. Another side effect of this a central "bowing" of the tread..it causes enhanced wear at the center of the tire. A proper tire size will improve asthetics, longevity and maybe even some handling performance.
As Jason suggested, I may have to invest in some coilovers :-)
Click Me
Old 05-12-2012, 09:38 AM
Albo's Avatar
Ok....not as big as the wheels... But another "enhancement".
Click Me
Old 05-13-2012, 08:24 AM
^ M5 bumper mesh grill with drain sink mod?
Old 05-13-2012, 08:28 AM
Albo's Avatar
Nah...not my style.
Click Me
Old 05-13-2012, 08:46 AM
I like the sink drain look
Old 05-13-2012, 12:20 PM
Albo's Avatar
You do make a convincing case...
Well...i noticed that I had a major brain fart. I'm not running a 265 tire in the back....i'm running a 275!
Can't believe I forgot that.
Any way... I'm going to play around with different spacer sizes to get to where I need in the rear (just ordered some 5mm spacers). I'm going to replace with better tires when this set wears out.
Click Me
Old 05-13-2012, 02:27 PM
Albo's Avatar
A few quick pics while I went last- minute mothers day shopping for Mrs. Albo's grandmother.
I know..... The headlights need work!!
Click Me
Old 05-13-2012, 02:40 PM
NoWayJose's Avatar
nice pictures but yea the headlights need some work try this out
http://www.bimmerfest.com/forums/sho...18&postcount=1
and to really keep them perfect use laminx after.
00 BMW 528ia Sport
Old 05-13-2012, 07:12 PM
Albo's Avatar
Thanks for the link.. I was Planning to claybar them, but I may just go whole-hog and use this DIY.
I'm trying to improve my picture taking skills.
Click Me
Old 05-13-2012, 07:25 PM
^Then try not to have distracting things sticking out of your car: signs and posts ...
2nd about the headlights
Old 05-13-2012, 10:21 PM
Albo's Avatar
This is a test....this is only a test...
Click Me
Old 05-13-2012, 10:56 PM
Do either that DIY which looks excellent, or get yourself a 3M kit which worked brilliantly for me.
Old 05-14-2012, 09:05 AM
trying to give you a hard time
Old 05-14-2012, 10:16 AM
Albo's Avatar
..and it's much appreciated
Click Me
Old 05-14-2012, 10:17 AM
Albo's Avatar
Retouched pictures...
Click Me
