E34 (1989 - 1995)
Old 04-08-2011, 11:44 AM
THMitchell THMitchell is offline
Mein Auto: 1992 535i
Tranny swap
So I have just lost reverse in my 1992 535i automatic. It's up to 197k on the odometer so I figure there will be more trouble following this loss. I am set on doing a 5spd swap but not sure which transmission to look for. Anyone out there have any advice on this?
-THM
Old 04-08-2011, 06:41 PM
TWard's Avatar
TWard TWard is offline
Mein Auto: 91 e34 525i
Hmmmm that's the 3.5L right? If ur doing the swap make sure u gots some money and some time. I'm in the middle of mine and just a headsup the pedals suckkkkkkkkkk.
Old 04-08-2011, 06:44 PM
TWard's Avatar
Hey man check this out. This will tell the tranny and ur diff. Hm check around and find yourself a good junkyard u will need it.
Old 04-14-2011, 05:17 PM
So I recently discovered this site through late night insomnia driven research. After overlooking the prices I noticed the "Product Fitment/Applications" section and noticed all of the different models, including 3-series models, these manual transmission will fit. If my assumption is correct then it seems the 5-speed manual transmission from my 1989 e30 m20 would fit/work with my 1992 e34 m30??? If this is true finding the parts will be a hell of a lot easier.
Please correct me if I am wrong in thinking this. I know the salvage yard I frequently visit has about 20 e30s and very few e34s (especially manuals) and I am getting antsy to get started on this. Pushing my car backwards out of parking spaces is not only a much needed workout, but also turning out to be very annoying when leaving work after a 14 hour day.
Old 04-14-2011, 06:58 PM
south26 south26 is online now
Mein Auto: 535i 1989
the tranny from the m20 will not work on the m30. The bell housings will not match up. You can use a 265/5 getrag, 260/5 getrag, 260/6 getrag those came in the e28. Since you are not worried about the bell housing sensors they will work. The 260/6 is most likely what other e34 535i have. If you are interested I have the pedals and master, center consul in either black or blue, the soft and hard lines and the slave. You would have to find a tranny, fly wheel/clutch, and the drive shaft. For the fly wheel the lightest one would be from a 83 533i, it has the same weight as a e28 M5.
Andy
Old 04-17-2011, 08:33 PM
Thanks Andy, I may have to take you up on those parts.
I was just at the local salvage yard and found a manual 533i. Next paycheck I'm gonna head back there and grab what I can off of it.
Old 04-18-2011, 08:25 PM
Ok, so I think I am going to go ahead and pull the tranny, driveshaft, pedals, flywheel, and shift linkage off of the e28 533i at the salvage yard. I have seen on a couple other forum posts that the output shaft has to be modified. Will I need to make any other modifications for it to work in my e34 535i?
-Thomas
swap, transmission failure
