#76
wow that's real funny but sad--I too have the pss coilovers on my 1999 540i and recently experiencing excessive bouncing and noise when going over bumps. I thought the noise i was hearing was was the rear akebono brake pads loose in the caliper but come to find out after pushing the rear driver side i heard a clunk and seen a lot of rebound. I then pushed on the passenger rear and and heard no clunk. I proceeded around the car on both fronts and both were still stiff with no noise.
#77
540 m-sport What's the warranty on a pss coilovers from bilstein and what did you need to return them since i think my rear driver strut is shot--thanks bud.
#78
Be certain the problem is the shock and not the mount. I had an installation error with mine originally in the rear...if you forget to install the washers on top and below on the rear upper shock mount, the rubber insert can either push up and out, or pull down and out (it depends on which washer is left out...it will pull out in the opposite direction of the missing washer). In my case if pulled down and out, because the washer was missing on top. I removed the shock, took it apart, and used a hydraulic press to push the rubber back into the mount, and installed the washer, and reinstalled the coilover, and them bitched out the installer.
Factory M-Sport package with factory installed M-tech bumpers, factory Bluetooth, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, Bilstein B14 PSS coil overs, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar. Last edited by 540 M-Sport; 06-27-2012 at 08:56 PM. |
#79
Update
So, I noticed the faint knock returned today. I checked, and all the top nuts would take about 1/2 to 3/4 turn to get to proper torque, 30 NM. Obviously with red loctite, the nuts are not loosening, so either the studs in the upper strut mount are pulling through, or the upper mount is deforming or bending upward and outward. When I look at the studs closely, they are splayed outward very slightly...not anything like depicted at the BMP website: http://www.bmpdesign.com/technical/e...wer_damage.php So either could be the problem.
Regardless, I (and my tech) are pretty convinced the issue is damaged strut mounts, and possibly slight deformation of the strut towers as well. I am scheduled with the shop to install the BMP reinforcement plate kit, as well as new oem Sachs/Boge strut mounts on July 13th. I will report back after I have driven it for a while, but replacing both should be fix the problem and prevent it from returning. (fingers crossed) I believe the reason this is happening is the stiffness of the kit is transmitting the shock and jolt right to the strut mount and tower.
Factory M-Sport package with factory installed M-tech bumpers, factory Bluetooth, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, Bilstein B14 PSS coil overs, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar. |
#80
im getting the kit too
ESS Tuning m60 version software m60 intake manifold a.f.e. c.a.i. 3" obx catback full powerflex urethane setup 545 ssk cdv delete m5 rear sway bar M5 chassis rods M5 3.15 lsd Bc-r coilovers w/ swift springs Akebono=suck ss braided brake lines coming soon: Jb lwfw
#81
The Pss kit is too d@mn stiff...!
LOL!
Oh man...I knew you were going to beat me up on that! lol That is the weird part, having driven a few other E39's with various aftermarket suspensions, they were not much more or less stiff than my PSS kit, so why are we not seeing more of this? My tech says many people simply don't notice or don't care...
![]() BTW, I am ordering a front Strong Strut, strut bar as well. They have the thick, machined aluminum mounts that fit on top of the strut tower. I figure I am going "all in" on fixing this once and for all, and NOT have it recur.
Factory M-Sport package with factory installed M-tech bumpers, factory Bluetooth, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, Bilstein B14 PSS coil overs, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar. Last edited by 540 M-Sport; 06-27-2012 at 10:16 PM. |
#83
I would look at the Mason Engineering Strut bar for the E39. www.MasonEngineering.net http://www.masonengineering.net/Subpages/E39.htm
#85
It is not stiff in the rear any more--excessively bouncy so I guess I have to pull out the rear pss coilovers and send them to bilestein on the east coast for a rebuild
Sent from my SGH-T959 using Bimmer App |
#87
They probably will valve them differently than the original valving sweet thanks for the info
#88
Please check my post #78. I had a similar problem shortly after installation, and it was a problem with the upper shock mount. The installer forgot to install the fender washer under the top nut, so the rubber insert on the shock mount pulled free and down, under the mount. This allowed for basically no damping. You might have the same situation. Jacking up the car and inspecting will tell you for certain.
#89
#90
![]() IMO, I really do not think the Bilstein Pss coil-overs are any more stiff than my H&R's... I do really like that the Pss kit has helper springs, and that the springs are a smaller diameter, that prevents the spring from coming into contact with the wheel/tire... Quote:
I think he custom makes these. He is a VERY sharp guy. http://forums.bimmerforums.com/forum....php?t=1209198 http://picasaweb.google.com/mmm525i/...rInstallation# Quote:
Thanks! Jason
The reason I selected Strong Strut is they machine the upper mounting plates from aluminum so they closely fit the contours of the top of the strut tower, offering more support, which is what I need at the moment. Everyone else's mount is simply stamped steel, of varying thickness. The Mason Engineering looks very thick, but not as conforming as the Strong Strut. See this example (this is for another BMW, NOT E39) : http://www.strong-strut.com/underside_bar9.jpg By comparison, the Mason bar appears to be resting on thick washers https://picasaweb.google.com/mmm525i...55809263732546, so not offering full support all the way around the strut tower. Again, it serves it's purpose (reducing movement or flexing of the strut towers), but I am looking for additional support of the strut tower on top, along with using the reinforcement ring from below, that comes in the BMP kit. so I am less concerned with strut tower movement, I am more concerned with strut tower (and strut mount) deformation. I did note that my replacement Bilstein struts are a different part number than my originals, so they must be of the newer valving...I really didn't notice any difference. The valving is firm, but not unduly so.
Factory M-Sport package with factory installed M-tech bumpers, factory Bluetooth, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, Bilstein B14 PSS coil overs, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar. Last edited by 540 M-Sport; 06-29-2012 at 12:11 PM. |
#92
i just cranked down on my strut mount nuts and i was surprised at how tight they werent. I mean they were falling off but considering i only had a stubby ratchet that has almost no leverage they were pretty easy to turn. I almost think they are more parallel to each other now and now splayed out in different directions.
#93
Interesting, but understand the nuts are not supposed to be all that tight. You will only know for sure if you use a calibrated torque wrench. Bentley manual says 22NM. My tech says 30NM. I have been using 30NM, and they simply will not stay tight, even with red loctite. I am not sure if it is from deformation of the strut tower or strut mount, or loosening. Last week I removed the nuts, and installed flat washers, then split lock washers, then a drop of red loctite and tightened to 30NM. Been one week and so far, so good, they are not loosening after about 500 miles of driving. No knocking either.So I have th
#94
Back to square one!
So I had new oem strut mounts installed, along with the BMP reinforcement piece installed from below, sandwiched betweeh the strut mount and the strut tower. In place of the BMP provided 3/8" thick washers, I instead had installed the Strong Strut front strut brace, which includes machined mounts the perfectly fit the top of each strut tower, further reinforcing it from the top. So we have thick metal above and below the strut tower, along with new oem strut mounts.
Prior to my bringing the car in, I had largely eliminated the knocking noise by installing flat washers and a split lock washer under each nut, as well as using Loctite to secure the nuts. So after installation, what a surprise that the knock has returned!! Too late in the day to do anything further, but will be returning the car for further diagnosis early next week! Frustrating to say the least, as I felt we had the diagnosis nailed. Will keep you folks posted on what we find.
#95
likely a different problem but i'll weigh in here. i too have had the clunking sound and feel from the front struts on my 528 (now with 171k mi). It is happening now on the 2nd set of Bilsteins with the same symptoms. for me it is definitely the strut and i is worse after lengthy highway driving though i don't feel it on the highway but once i pull off the exit and into low speed traffic.... quite annoying.... i go clunk, clunkety clunk over every little pebble. i can replicate the clunk when pushing down a front fender. it is as though the strut is seized somewhat and sticks for a bit before giving in with a clunk.
I sent one pair back to bilstein (i had no receipt for the purchase of these) and they rebuilt the struts, admitting that they had failed. These are still in a box in my garaged. a 2nd pair of stiffer bilsteins that i had bought used on ebay are now producing the same symptoms. I plan to have the rebuilt ones reinstalled but am wondering if i should bother with any sort of lock washer or thread lock as has been discussed in this thread. I have noticed some cracking between what i presume is the very top of the strut and the rubber around it visible in the engine bay. is this an issue that needs to be addressed? thanks! |
#96
8/17/2012 knock update information
Since the replacement of strut mounts and installation of BMP strut tower reinforcements did NOT correct the knock, I returned the car for further diagnosis last week.
The shop went with the original premise Bilstein suggested, which is that on occasion, the seals get "stick" on their struts, and require relubrication internally. If you are not aware, Bilstein uses an "inverted" strut, within the housing...these larger bearing surface makes the strut stronger, but means a much larger bearing surface as well. The shop disassembled the struts and found what appearred to be some "ring" marks on the shaft...as if the seal was indeed "sticking" or stuttering as it went up and down. Noticed this more on the right strut than left. Also, there were some unusual wear marks on the right side shaft. There was plenty of grease inside, and several seals used inside that appearred to all be in good condition. The shop cleaned things up, and used some real sticky, tacky grease in place of the oem stuff. So the results? Not perfect, but much less knocking than before. So I think the issue IS a lubrication/seal issue internal to the struts. My plan right now, is to send them back to Bilstein for a proper rebuild, which would include new seals, along with greasing. I think this lack of lubrication thing is what everyone is experiencing. I've noticed everyone seems to be having issues only with the front struts, which have the inverted strut design. No issues with the traditional shock design they use for the rear. What a waste of time and dollars to come full circle back to the struts being the culprit. At least the shop has been very generous in comping me the labor on the most recent work.
#98
was the rebuild free? S$%* No! if i recall it was $75 per strut plus shipping (plus install labor, alignment, etc). It has been a real pain in the arse for a lot of people. I would love to get the bottom line answer to the problem from Bilstein. The clunk problem is a serious quality problem that should not be happening on ANY vehicle.
#99
That is a defect IMO. Unless it says on the shock/ strut description that they are meant to to clunk from improper seals...
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
