E30 (1982 - 1993)
Old 04-09-2011, 10:21 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Apparently you 'can' replace the E30 I6 oil pan gasket by removing ONLY the oil pan!
So that the E30 team can both benefit and pitch in with ideas, see this post about the E30 in the E46 forum referencing the E39 success story:
I post this E39 (I6 M54 engine) success here, for the following two reasons:
  • To let you know it is (apparently) 'possible' to replace the E30 oilpan gasket without removing anything other than the oil pan
  • To solicit your advice for improvements and ideas to the technique and/or gasket sealants and/or locations for the cuts
Here's where to add the advice:
- E39 (1997 - 2003) > Replaced oil pan gasket
Note: If you guys already have figured this out, please let us know; but, as far as we know, this is a first.
Old 04-09-2011, 11:41 AM
fcsteve's Avatar
fcsteve fcsteve is offline
610EUROs
Mein Auto: 90' 24v, 89' 325is
that is completely stupid.
if you want to lead the orchestra, you must turn your back on the crowd
build: http://www.bimmerfest.com/forums/sho...d.php?t=382667
Old 04-09-2011, 11:51 AM
noexceptions325's Avatar
noexceptions325 noexceptions325 is offline
East Bound And Down
Send a message via AIM to noexceptions325
Mein Auto: 325e,Jeep,240z,528i
Lol
Built 325e too much to list, Heavily modified Jeep, Datsun about to get a 351, and now a 528i
Old 04-09-2011, 02:50 PM
downhiller's Avatar
livin large
i thought just unbolting the engine mounts then lifting the engine was the easier and safer way then cutting the pan
Old 04-09-2011, 02:56 PM
bluebee's Avatar
Why?
In the M54 engine, it's an all-day job to replace a leaking oil pan gasket.
With this approach, it's an hour or an hour and a half, at most.
The all-day job is often farmed out to the shop (read $$$); while this approach can easily be done at home.
I 'assumed' the E30 oil pan gasket R&R (based on the comments quoted by m123) was the same situation.
Is it not?
Old 04-09-2011, 05:47 PM
fcsteve's Avatar
610EUROs
thats the time it takes to do it the proper way. cutting up a gasket and lobbing in sealant to fill the broken area is a dumb. if you cant do something right, dont do it at all. i HATE taking apart a motor to find out the previous idiot silicones the hell out of everything to avoid the little extra time it takes to do the job right.
Old 04-10-2011, 06:35 AM
anstead610 anstead610 is offline
dream chasin'
Send a message via AIM to anstead610
Mein Auto: 24v e30 -88 toyota pickup
Tell me about it. Took me 2 1/2 hours to get all that off the m50.
Steve and I replaced my oil pan gasket in the m20 (when i had one) without cutting or anything. Just dropped the pan down a bit and stuck it on.
This e30 is now being parted out. NO body panels are for sale, bumpers/fenders/hood/mirrors/valance or front turn signals. Everything else is up for grabs. Euro grills/cluster are sold, suspension/brakes/LSD/rear tails are already spoken for.
Old 04-10-2011, 01:41 PM
East Bound And Down
I have to work on this woman's jeep again today, I'll take a picture of here valve cover gasket this time (someone literally used 2 tubes of form-a-gasket on it)
I do not approve of Cutting any gasket Prior to installation, i dont care if it takes an extra two hours and involves lifting the engine
Old 04-25-2011, 08:33 AM
susanavilon susanavilon is offline
Mein Auto: none
Does anyone know where to purchase an oil pan gasket set? I am looking for a high quality part (oem as much as possible). And I also found this oil pan gasket set at **************.. Is this one good?Thanks!
Old 04-25-2011, 08:44 AM
fcsteve's Avatar
610EUROs
. what do you mean an oil pan gasket "set" .. its 1 gasket. you can get it at ANY bmw parts retailer. you can even order it at your local non-bmw parts store like autozone, advance auto or anything like that too. places like pelicanparts will have the OEM one.
Old 04-25-2011, 10:05 AM
First time's Avatar
First time First time is offline
INSANELY UNPREDICTABLE!
Mein Auto: 2001 540i sport/1994 525i
You stole my words! I call jinx.
Old 04-25-2011, 10:06 AM
First time's Avatar
They arent cutting the pan. Just the gasket.
Old 04-25-2011, 10:09 AM
First time's Avatar
Originally Posted by bluebee View Post
Why?
Is it not?
Go and ask the BMW dealership if they do this. The answer would be a resounding NO. If you are too lazy to get down there and replace the gasket the correct way, who's fault is it that your car ends up at the dealership?
