Old 04-09-2011, 10:13 AM
mrgbennett mrgbennett is offline
Mein Auto: BMW 528I Sport
MAF Cleaning Instructions
Hello to all....I have a 2000 E39 that I suspect needs a MAFS cleaning....can someone help me with the procedure. Thanks.
Old 04-09-2011, 06:30 PM
Rustyzipper's Avatar
Rustyzipper Rustyzipper is offline
97' 540i
Mein Auto: 540iA
This what I do, and I'm sure you will get many other ways...
Once off take a large zip baggy, and fill it with a bottle of 92% alc. ( about a $1.50) the kind you find in the store drug section , its next to the rubbing Alcohol.
Put the MAF in the bag, zip it, and swish it around, for like 5 mins.. this cleans it good, inside and out.
Take it out and let it dry for 30 mins, if it is wet when you put it in... it will toast everything.
Thats it.. no need to buy any thing else.
97' 540iA Build 4/96
73' 911 Targa Whale Tail
86 Coupe deville Convertible
Old 04-09-2011, 06:37 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
From a quick /MAF(F3) in the best links thread ...
- Mass air flow sensor (MAF) and idle control valve (ICV) require periodic cleaning (1) (2) & buying a replacement MAF cheaper than the BMW MAF (RangeRover MAF) (VW MAF) (Hyundai MAF)
Old 04-10-2011, 07:22 AM
bimmernut1 bimmernut1 is offline
Mein Auto: Porsche, BMW
I use CRC MAF cleaner. If you do a google search for it, there are several utube videos on how to clean the sensors. Some use the spray with a very gentle brush. Personally, I just use the spray and let it evaporate, no brush.
If after 1 or 2 cleanings, your MAF rate doesn't increase, I would replace the sensors. I consider them maintenance items anyway and replaced mine at 100k miles evern though they didn't exhibit any problem.
http://www.google.com/products/catal...d=0CDwQ8wIwAw#
1979 Porsche Tobacco Metallic 911SC
1996 Porsche Guards Red 993 C4S
2005 Porsche 996 Turbo S
2003 BMW Ti Silver M5
2013 BMW X3 35i Carbon Black M-Sport
Old 04-10-2011, 05:30 PM
NY_98_528i NY_98_528i is offline
Mein Auto: 1998 528i
I am a believer! I just cleaned my MAF and there is a definite difference! I am still getting my cat checked tomorrow, but WOW, such a simple maintenance thing to do!
Quick step by step for a '98 528i
- remove the 2 10mm screws holding the airbox (you don't have to pull it out, this will allow
you the wiggle room you'll need later)
- use your flat head to loosen the band on the engine end of the MAF
- use your flathead to pop the 2 spring clips on either side of the MAF where it connects to
the airbox
- unscrew the wire harness, it has an externally rotating ring
- use your fingers to apply counter pressure to the MAF and you thumbs push on the
assembly that leads to the engine.
- pop out the MAF where it connects to the airbox and spray away with the CRC MAF cleaner
(5.99)
- Just note there is an O-ring seal insside the airbox that might get caught on the MAF as
you pull it out depending on how hard of an angle your working with.
The whole thing took me ten minutes!
Old 04-11-2011, 09:09 AM
Thanks for the info everyone...great help....i cleaned and i did feel the difference...the ses light though is still on...should i clean the icv as well? Will this light turn it self off or do i have to bring it to a shop?
Old 04-11-2011, 09:22 AM
bluebee's Avatar
How can anyone possibly troubleshoot properly without you telling us the codes that triggered the SES light?
Oh my! I just realized you may not have read the codes yet. Is that the case?
If so, why not spend the $25 (at least that's how much it costs in the USA) to buy the code scanner and reset the light yourself?
- Cheapest CAN OBDII scanner on the net that reads DTCs, pending codes, & clears codes
Otherwise, you're just guessing (and, more importantly, wasting everyone's time, including yours!).
Old 04-11-2011, 11:05 AM
Fudman's Avatar
Fudman Fudman is offline
Just to clarify, for those who have not done so already, whenever you clean the MAF, DO NOT TOUCH IT (physically). Don't use a towel to wipe it dry or Q-tips to really get at the corners. Just let it air dry or you might damage the MAF.
Old 04-11-2011, 11:34 AM
Burning2nd's Avatar
Under the lift arms
I just wanna hit this on the head once and done ,
Every Ase tech will tell you this is bad
Checking the voltage is how you test a maf, cleaning a maf is how you get to buy a new one
15486372<-----
Old 04-11-2011, 01:02 PM
ChaseRobert ChaseRobert is offline
Mein Auto: Z3
+1 on CRC MAF cleaner (they have a video on their web site)
quadruple +1 on DON'T EVER TOUCH THE MAF ELEMENTS WITH ANYTHING.
Old 04-12-2011, 10:33 AM
Purchasing code scanner right now...thanks....
Old 04-12-2011, 10:46 AM
bluebee's Avatar
Just for the record, I have the exact one pictured above, and, well, it works just fine for what I need it to do.
When/if I need fancier stuff ... I'll get a fancier scanner.
Be advised there is also freeware out there if you have a serial port Windows PC:
- OBD II PC freeware & $15 J1962 cable for the BMW E39
Old 04-12-2011, 11:14 AM
franka franka is offline
Mein Auto: E39 540i Sport
I want to clairify only. I have no position to take or defend.
Are you saying that cleaning the MAF, with a MAF spray, and w/o touching it, is NOT advised?
Frank
540/6
540, Dirrezas (4) @ 275/35-18 ea, Eibach springs & bars, Bilstein Sports, Dinan Stage 2, slotted ATEs, Hi-Temp HTP pads, SS Lines, UUC-SS, White/Tan, Bling-free & Stealthy
Old 04-12-2011, 11:31 AM
Burning2nd's Avatar
Under the lift arms
Everything in the book says yes, don't touch it don't clean it
It's precision electronics, dropping it, disturbing the element inside anything like that is a no no ( from the shop side of business)
I'm sure many have done it but I'm sure there's a few,here who have done it and then replaced it afterwards....
15486372<-----
Old 04-12-2011, 12:18 PM
i have over 200k miles and have never touched it and never had a code on it.
Frank
540/6
Old 04-12-2011, 12:23 PM
Burning2nd's Avatar
Under the lift arms
They really don't go bad when they do the voltage will be out of range and it will throw a voltage out of range code.... not to be confused with short to ground or open circuit
Sent from my ADR6300 using Bimmer App
15486372<-----
Old 04-12-2011, 03:06 PM
DrewCrewOf2 DrewCrewOf2 is offline
Anyone know of a good MAF on sale? My E39 is sometimes throwing odd mixture codes (Indie says) it may be the MAF causing this.
Purr's like a kitten
Old 09-10-2013, 06:01 PM
scpousnret scpousnret is offline
Mein Auto: 2002 530i
"Once off.............
Thanks but I'm trying to get some simple but concise tips (and a video would be a plus),
on just how to access/remove it and the proper way to clean and put it back together.
Could you please provide the precise removal and cleaning procedures?
Much thanks in advance for your help.
Old 09-10-2013, 07:57 PM
bluebee's Avatar
Aren't the DIYs explicit?
Old 09-11-2013, 05:01 AM
I guess I did not see the one you are referring to, I'll look again.
