E90/E91/E92/E93 (2006 - 2013)
Old 04-11-2011, 07:29 AM
Schwiek Schwiek is offline
Mein Auto: 2007 BMW 328i
Interior LED light issue
I just bought and installed the 14 piece LED interior light mod for my e90 328i and they all work great besides my glovebox light and trunk light. When I installed them, they worked for a brief moment, but now will not work at all (even the previous stock bulbs wont work now). I tested the ones I was installing in those two places and the bulbs work in other places. What happened?? What can I do?
Old 04-11-2011, 07:36 AM
E92Submarine's Avatar
E92Submarine E92Submarine is offline
Officially Contaminated
Mein Auto: 2009 E92 335i
Did you check for blown fuses?
2009 E92 335i | 6MT | Black Sapphire | Black Dakota | Aluminum Trim | Premium | Sport | Heated Seats | PDC | iDrive | HD Radio | M-Sport Shift Knob |
Old 04-11-2011, 07:58 AM
Haven't yet. I figured that is a likely possibility. The fuses are behind the glovebox right? Do you just press in the corresponding numbers?
Old 04-11-2011, 06:35 PM
SK328xi SK328xi is offline
sk328xi
Mein Auto: 2011 328xi jet black
there is a fuse diagram sticker affixed somewhere behind the glove box it shows what each fuse does.
Old 04-11-2011, 07:17 PM
Zeichen311's Avatar
Zeichen311 Zeichen311 is offline
Lost but making good time
Mein Auto: '11 335xi Sedan
They're not circuit breakers, you can't reset them. Assuming you have blown a fuse or two: Pull out the blown one(s) and replace with new of like kind (same ampere rating). Then reinstall your stock lamps in that circuit until you have LED replacements that don't draw too much current for the circuit. Otherwise you'll just burn out the fuse again.
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
N47° 35' 30.13" E11° 10' 33.36" - End of break-in period. You can guess the rest. BMW CCA
Old 04-12-2011, 06:50 AM
Issue resolved! I replaced the fuse #61 because I noticed my trunk light, glove box light and a/c was completely out. So i took one of the fuses from the top that isnt on the map because I read on forums that those are extras? But everything works and put my stock bulbs back in the trunk and glovebox. I wonder why those blew the fuse and not the other 12 bulbs I used throughout the car? Oh well Thanks guys
Old 04-12-2011, 07:25 AM
Bill-SD's Avatar
Bill-SD Bill-SD is offline
Mein Auto: 2007 335i Coupe
You pulled a fuse from another slot? I cannot imagine them being "extras". Personally I'd buy a new one to replace the blown one.
Monaco Blue/Saddle 335i Coupe - Auto|Sport|Premium|Nav|CA|Sirius|Heated Seats|PDC
e90, glove box, interior lights, led, trunk
