5 Series
Ask questions and discuss the 5 Series here. If you would like to see all new posts in all the forums, click here. |
Brake upgrade question
Is it possible to upgrade the e39 540i brakes to the e60 545i brakes? Or is it easier to upgrade to M5 brakes? My 03 540 brakes look pretty small behind the M parallels that came with the car.
Wow... good question. Are the 545i brakes any bigger? DaveZ, didn't you already have one in for a CDV delete? Did you look at the calipers/rotors?
JB |
Upgrading to the M5 brakes would be easier. Don Jacobson (jacobsendm@shaw.ca) acquired M5 brakes, front and rear, for his 1997 540i, but then decided to install StopTech front brakes instead. You might try contacting him to see if he would part with the M5 front brakes at a reasonable price. Alternatively, the Brembos and StopTechs fit behind the front wheels without spacers: Left front wheel of my 540i
Dave Zeckhausen Owner, Zeckhausen Racing ![]() ------ 2012 BMW F30 328i Luxury Line 8-Speed StopTech 4-wheel big brake upgrade 2001 BMW E39 540i 6-Speed (Traded-in for F30) StopTech 4-wheel big brake upgrade M5 Limited Slip Differential, Front Swaybar Dinan Stage 3 Suspension, Strut Tower Brace Rogue Short Shifter, Transmission Mounts European Dash Conversion CDV deleted Last edited by DZeckhausen; 03-01-2004 at 06:16 AM. |
e60 535d -08 mostly stock for now. My 540iM -6 E39 M5 OEM Wheels and Cross Spoke Composite II 42 18", CDV Deleted, Eisenmann Race 2x76mm,Rogue Engineering Short Shifter (+WSR), Rogue Engineering Camber plates, Stoptech SS Brake lines, Axxis Ultimate, Bilstein PSS9, M60 intake. (Sold) My old 528i Touring -98 H&R+Bilstein Sprint, E39 M5 OEM Wheels 245+275, CDV Deleted, M50 intake manifold, BBTB (Sold 2005-07-15) |
Thanks for the info Dave. M5 brakes looks like a good option although your Brembo brakes look way better.
I assume M5 rotor and calipers bolt right on. Do you need to change the master cylinder to handle the bigger brakes or will the one on the 540 handle it? Also in terms of brake feel, how does the M5 brakes feel compare to the Brembo/Stoptech kits? Last edited by dchen; 03-01-2004 at 11:08 AM. |
My Style 66M wheels, by the way, are listed in the 4-sale forum. See: http://www.bimmerfest.com/forums/showthread.php?t=53796
Dave Zeckhausen Owner, Zeckhausen Racing ![]() ------ 2012 BMW F30 328i Luxury Line 8-Speed StopTech 4-wheel big brake upgrade 2001 BMW E39 540i 6-Speed (Traded-in for F30) StopTech 4-wheel big brake upgrade M5 Limited Slip Differential, Front Swaybar Dinan Stage 3 Suspension, Strut Tower Brace Rogue Short Shifter, Transmission Mounts European Dash Conversion CDV deleted |
In order to retain the factory balance, you probably want to upgrade the rear brakes to the M5 parts. The master cylinder is the same in the M5 and the 540i, so there's no issue there. As for feel, there is not really any difference between stock 540i and M5 brakes. The systems use the same 1-piston sliding caliper design, so you won't end up with a firmer pedal. Basically, you are just buying yourself a bigger margin in thermal capacity as well as longer pad and rotor life. You're also hurting your acceleration and handling a bit, since the M5 rotors are several pounds heavier and have greater rotational inertia. I've heard from several 528i owners who upgraded to M5 brakes and really noticed the hit in performance. The difference is not so dramatic on the 540i. The Brembo and StopTech brakes both significantly REDUCE the weight of the calipers and the rotors. Install one of those systems and slap on a set of lightweight SSR competition wheels and you are going to notice a difference!
