E46 (1999 - 2006)
Old 04-14-2011, 04:53 PM
x80byx x80byx is offline
Mein Auto: bmw 330ci
Bmw e46 330ci misfire and then starts and cuts off straight away
Hello Ppl,
Can anyone help.
I have bmw 330ci cab, i sent it to garage to get repair done on the code reader behind the ignition, however they said its the ignition switch, they ordered part however it turned out that i was correct.
took the car back, was driving it normally and all of a sudden it starts mis firing and low speed, i tried to accelarate but it wouldnt let me and then it eventually cut off. It now starts and cuts off almost immediatly.
any suggestions?
Old 04-14-2011, 06:43 PM
QAfred QAfred is offline
Mein Auto: 328i, 330ci, R1200C
1) check battery voltage
2) get your OBDII codes read
is where I would start.
Old 04-19-2011, 08:49 AM
Hey thanks for reply,
got it checked out, it was the fuel pump at the tank which gave inn.
