Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series & 8 Series > 7 Series - E23 / E32 (1977 - 1994)
Old 04-14-2011, 09:34 PM
smartmccoon smartmccoon is offline
Mein Auto: 1988 BMW 735i
Flasher relay on 88 735i HELP!!!!
OK first of all my flasher turn signal and hazard signal went dead not even a beep. so i went trough some threads on here and found out it most likely is my flasher relay. so i opened up the bottom of the dash and the only relay i see is connected to a old alarm system that i guess the old owner had put in cause it doesn't work. there is a wire from that going towards the turn switch. SO NOW JUST WONDERING IF I HAVE THE RIGHT RELAY AND IF THAT OLD ALARM SYSTEM HAS ANYTHING TO DO WITH THE RELAY BEING OUT? PS...REALLY NEED SOME HELP ON THIS ONE BOYS THANKS IN ADVANCE
