Old 04-15-2011, 04:04 AM
JimLev JimLev is offline
Mein Auto: 540/6, Tribeca
Looks like PS systems are the hot topic today
Edjack had mentioned in a post below about draining the pump and cleaning the reservoir with gasoline. You'd be surprised at the crap that the screen collects. No need to replace the reservoir, a cleaning is all that's needed.
On the V8 the drain plug on the PS pump will empty almost all of the fluid.
(Pulling the hose off the cooling loop on the radiator is pretty messy, and it's not easy to catch the fluid).
You can then remove the reservoir, unscrew the filter and flush with gas.
While your at it stick the head of a Q-tip in the vent hole to keep most of the mist from coming out. I haven't found the cap o-ring to be a problem.
Name:	PS Pump Drain.JPG
ID:	274761   Click image for larger version
Name:	Empty Reservoir.JPG
ID:	274762   Click image for larger version
ID:	274763   Click image for larger version
Name:	Clean Screen.JPG
ID:	274764   Click image for larger version
Old 04-15-2011, 04:35 AM
DominguesE30's Avatar
DominguesE30 DominguesE30 is offline
BMW FETISH!!!
Send a message via MSN to DominguesE30
Mein Auto: `97 BMW 318is
Every thread is literally about power steering!!'
Sent from my iPhone using BimmerApp
MADEINDEUTSCHLAND
`00 BMW e46 330i
`97 BMW e36 318is
Beeeeeeeee Eeeeem Double-YOU!!!!
Old 04-15-2011, 04:45 AM
Burning2nd's Avatar
Under the lift arms
Replace your cooling system
.p
Sent from my ADR6
15486372<-----
Old 04-15-2011, 05:32 AM
.p
Sent from my ADR6
Already done about 4 years ago, Zionsville!
No clutch fan or mechanical fan either.
Old 04-15-2011, 10:32 AM
edjack edjack is online now
Mein Auto: '97 540i 6 speed
Wow! Pristine engine! I'm shamed!
Old 04-15-2011, 03:36 PM
Burning2nd's Avatar
Under the lift arms
that was a sarcastic joke... but you took it literally ...
15486372<-----
Old 04-15-2011, 04:12 PM
Albo's Avatar
Albo Albo is offline
Der Ursprüngliche....Albo
Mein Auto: OO=[][]=OO
Just bought some Dexron VI ....will takle this R&R on Sunday. After I mow the lawn... ;-)
2003 530i (Alpine White/Sand Beige) - 18x8.5 & 18x9.5 ACS Type II Wheels - BC Racing Coilovers - Eibach Sway Bars - Beastpower Sway Bar Brackets - M-Technic Replica Bumpers - Slimmbones CSL-Style Spltters - Magnaflow Muffler - Dinan CAI - TopSpeed Performance Strut Brace - Carbon Fiber Valve Cover Fascias - Zionsville Autosport Radiator/Fan Kit - Revmax Stage II Torque Converter - AMG Paddle Shifters
Old 04-15-2011, 04:17 PM
jordan16j jordan16j is offline
Mein Auto: 2001 BMW 525i 124k
Thanks for the post, the photos are really helpful. I think Bluebee was searching for a picture of the filter itself, too.
Old 04-15-2011, 07:13 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Yes I was.
Here is what I added to the canonical power steering fluid replacement DIY:
- DIY - E39 525i Fluid Triple Play (PS, diff & tranny fluid change)
Originally Posted by bluebee View Post
I added a link to this thread in the bestlinks for future reference.
In addition, I linked to it in the summary fluid printout:
- BMW E39 fluid summary printout for your glovebox (1)
Doru suggests we replace the fluid in the power steering reservoir at every oil change:
It only takes about half a quart to suction out and then refill:
Most say you can't remove the filter but some (JimLev) say you can, so see his DIY on cleaning the filter.
Just make sure you use the right fluid. Do not use PSF; use DexronIII/Dexron VI ATF!
(This was my rookie mistake a few years ago when I first bought my bimmer & changed the fluids.)
Tying the PSF with the oil change makes sense, especially since the o-ring in the cap deteriorates at about the same rate as the two little o-rings in the lower half of the oil filter housing; so replace all three o-rings at the same time (every few years):
At about the same time, check the lower reservoir hose for leaks & fix it the cn90 way:
And, climb underneath to fix the power steering pump hose leaks also:
Otherwise, you face a power steering pump autopsy like this:
As for the power steering fluid pump filter, here is JimLev's procedure:
- E39 (1997 - 2003) > Looks like PS systems are the hot topic today
There is apparently a screw or bolt holding the filter in place:
Apparently the circular screen will simply lift off at this point:
JimLev suggests you flush it all out with gasoline or other suitable solvent.
He also suggests you plug the filler cap with a Q-tib cotton swab:
But most of us recommend simply replacing the filler cap o-ring every few years.
Old 04-15-2011, 08:43 PM
bluebee's Avatar
Since JimLev didn't state the year of his 540, and since I read in the previously mentioned threads that only the 'older' E39s had a removable filter, I went out just now to my garage to see if my 2002 540i M54 filter could be removed in situ.
Sure enough, after suctioning about 8 ounces (about 250 ml) of Dexron VI out ...
I could easily disengage the circular screen filter with a magnetized T20 Torx screwdriver.
You can't remove the screen, but, you can tilt it 90 degrees to see how clean it is.
ID:	274880   Click image for larger version
ID:	274881   Click image for larger version
Old 04-15-2011, 08:48 PM
bluebee's Avatar
Looks like this effort is morphing into the following recommendations:
  • Every oil change, suction out about 8 ounces (250 ml) of the power steering fluid and replace with Dexron VI ATF
  • Every five years (or so), when you replace the two lower oil-filter stem o-rings, also remove the T20 Torx bolt holding down the circular screen filter in the bottom of the power steering fluid reservoir and flush with gasoline (off the vehicle!) to clean the screen
  • Likewise, also replace the o-ring in the power steering fluid reservoir cap at the time you replace the two lower o-rings in the oil filter stem
  • And, of course, check/fix leaks in the hose below the power steering reservoir & at the bottom of the power steering pump.
Since I would want someone to find this information in the future, I would like to append it to the one 'canonical' thread on how to flush your power steering fluid.
Unfortunately, I find LOTS of threads on how to flush your power steering fluid, so, it's a pain to update them all.
Here's what we currently have in the bestlinks for a /power steering(F3):
- How to clean the power steering fluid reservoir internal filter (1) & how to replace the cap o-ring (1) (2) & why you want to fix the power steering hose drip onto the alternator (1) (2) (3) & how to debug PSP power steering pump noises (1) (2) (3) or steering rack noises (1) & a nice power steering pump autopsy photo (1) & how to flush cloudy ATF fluid (1) (2) (3) (4) (5) & what PS fluid to use (1) (2-pdf) (3-volume) & what volume is needed to buy (1) & DIYs to replace the power steering hoses (1) (2) (3) (4) (5).
I'll at least try to update those threads (rather than try to update them all).
Old 04-15-2011, 09:55 PM
bobdmac bobdmac is offline
Older than old school
Mein Auto: 2001 540i/6, '90 k75s
JimLev and Bluebee, thanks for the great photos. Now we have yet another maintenance issue to obsess about. In the immortal words of Kurt Vonnegut, "So it goes..."
Old 05-13-2011, 11:03 AM
bluebee's Avatar
Originally Posted by bobdmac View Post
Now we have yet another maintenance issue to obsess about"
Yup.
As I said in the E46 forums today, it's part of our recommended maintenance schedule:
- E46 (1999 - 2006) > ATF reservoir overflow
Originally Posted by jcourcoul View Post
Is this an E39 thing only or does it apply to E46 as well?
It's the same engine (M54).
I don't recall seeing anything like a Torx screw head at the bottom my E46 power steering fluid reservoir
It's there on my 2002 M54 engine (see pic below of my magnetized torx in action):
Note we generally replace the power steering fluid in the reservoir at every oil change; and at every fifth (or so) oil change, we recommend replacing the oil-filter o-rings, the power-steering reservoir o-ring, and we clean out the power steering reservoir mesh filter.
The Standard Knowledge is
The guys here (at least on the E39 side of the house) make new tribal knowledge all the time!
  • We/they don't have weeping power steering fluid reservoirs
  • We/they fix ABS control modules ourselves (for free)
  • We/they replace M54 I6 oil pan gaskets without remove the sub frame
  • We/they replace our PBT plastic headlight adjusters with Delrin for five dollars
  • We/they have a good source for M54 DISA o-rings
  • We/they have a BMW source for M54 lower-radiator-hose thermoswitch o-rings
  • We/they replace our mechanical tensioner pulleys with aftermarket pulleys
  • We/they rebuild our own alternators with better quality bearings
  • We/they get wiper blade refills for just a few bucks, often from the stealer
  • We/they do brake jobs that are almost completely dry
  • We/they resolved the gym-sock AC smell problem
  • We/they make our own viscous fan clutch nut counterhold tools for five bucks
  • We/they know that brakes (almost) never warp (contrary to 'common knowledge')
  • etc. [/quote]
Old 05-13-2011, 10:59 PM
540indiana's Avatar
540indiana 540indiana is offline
Mein Auto: 2000 540i Sport
We have power steering on these cars?
Old 08-06-2011, 03:02 PM
bluebee's Avatar
See what happened today when power steering filter clogged from the rubber components of the system caused cavitation in the power steering pump:
> 2002 E39 525i - Power steering whine solved in detail
Old 10-05-2011, 10:35 AM
bluebee's Avatar
For the record, I updated the 'what parts to buy' thread today with concurrent power steering & oil change parts lists:
- Recommended parts kits for overhauling cooling, drive belts, CCV/ICV, VANOS, OFH, PSP
Old 10-10-2011, 11:39 PM
bluebee's Avatar
For the crosslinked record, Bavauto has a nice blog video on replacing the power steering fluid reservoir:
Changing Power Steering Filter and Fluid
Old 11-04-2011, 06:57 PM
bluebee's Avatar
Today a related post was asked:
- E39 (1997 - 2003) > Changing Powere Steering Filter
See also:
Power steering fluid (1) (2) & power steering fluid flush DIYs (1) (2) (3) (4) & volumes (1) & how to clean the power steering fluid reservoir internal filter (1) (2) & how to replace the cap o-ring (1) (2) & why you want to fix the power steering hose drip onto the alternator (1) (2) (3) & how to debug PSP power steering pump noises (1) (2) (3) or steering rack noises (1) & a nice power steering pump autopsy photo (1) & how to flush cloudy ATF fluid (1) (2) (3) (4) (5) & what PS fluid to use (1) (2-pdf) (3-volume) & what volume is needed to buy (1) & DIYs to replace the power steering hoses (1) (2) (3) (4) (5) & how to debug common BMW power steering issues (1) and noises (1) (2) (3) or steering rack noises (1)
Old 12-31-2011, 12:30 PM
ztitans1 ztitans1 is offline
Mein Auto: 1997 528
Does the power steering housing come apart so you can replace the filter in there?
I just love this logo...
Old 12-31-2011, 12:52 PM
No it doesn't come apart, that info is in the posts above.
All you can do is clean the filter or replace the whole reservoir.
Old 12-31-2011, 07:15 PM
Mein Auto: 1997 528
I did the clean with gasoline and cut the ends of the hoses and reattached. Hopefully this will fix the leak. I noticed my steering sounds quieter. Great writeups guys. This was a free repair as I had some PS fluid already in the garage. Nothing like free.
Old 08-31-2014, 11:22 AM
Solo12 Solo12 is offline
Mein Auto: e39 530i e28 535is(Sold)
For those of us who don't have a ton of DIY experience I have some newbie questions about flushing the filter with gasoline or other solvent.
  1. I plan on using gas as I have no idea what other type of solvent to use. I am assuming regular 87 that I use for the lawnmower is fine to use, correct?
  2. Once I have the reservoir removed (& filter loosened inside) and flush it all out with gasoline do I need to make sure every drop of gasoline is out of the reservoir/ does the gasoline need to be rinsed out? Or if a couple drops of gas are left behind it that okay?
  3. If every last drop of gas needs to be removed what is the best method?
  • Turn reservoir upside down and let gas drain out of the big hole (top of reservoir) and leave overnight or for a couple of hours?
  • Dry out reservoir with rag as best I can?
  • Flush reservoir with ATF while it is off the car and that will get rid of the gas?
  • Some combination of those?
  • Other method?
E39 2003 530i: SP, CWP, PP, Manual, Sunshades, Split folding rear seats, 17" Style 42s
E28 1987 535is: Manual, Bilstein HDs, 16" Style 5v2 (from e38)[Sold]
Old 08-31-2014, 07:09 PM
bluebee's Avatar
Wow. It wouldn't matter at all what solvent you use, whether it's gasoline or alcohol or acetone, etc., so, certainly don't worry about the knock-resistance rating.
Just make sure you air dry the filter outdoors, before putting it back together.
Out here, in California, it's about 75°F, so, the gas will evaporate in an hour in the sun, so, there's really no reason for any gasoline to be left in liquid form.
Have you taken Organic Chemistry yet?
If you have, you'll note that ether is used all the time to "wash" out less volatile solvents, so, if you are really paranoid, just wash it out with any solvent with a greater volatility than gasoline. But I wouldn't bother. Just let it sit in the sun for an hour.
Flushing is also a good idea, especially since you'll likely have far more Dexron VI than that which you need to fill the system back up.
Old 06-25-2015, 07:50 AM
bluebee's Avatar
A V8 owner asked today, what the bolt size is for the power steering pump drain plug...
> E39 (1997 - 2003) > How much volume of power steering fluid do we have in the E39?
Originally Posted by Edgy36-39 View Post
Hi Blue, thanks. My thinking is the reservoir is by all odds original and 13 years old at this point. It's pretty cheap and seems easy to replace. Every filter will fail eventually.
But OTOH I'm not looking for a project. If these filters don't usually need replacing, I'll just change my PS fluid. Return hoses were done in late 2011 so fine on that front.
Maybe I'll just clean, as the link you provided earlier in thread describes: http://www.bimmerfest.com/forums/sho...68#post5999468 Anyone know the number of that drain plug, how to reomove?
Old 06-25-2015, 07:06 PM
Tutti57's Avatar
Tutti57 Tutti57 is offline
Mein Auto: 1999 540it
Did you use power steering fluid or auto trans fluid?
1999 540iT: aFe Intake | M60 Intake | Bavauto Springs | Bavsound Stage 1
2006 X5 3.0
