Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series
6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations.
Old 04-15-2011, 04:22 PM
SHAARK SHAARK is offline
Mein Auto: 650i
Advice on Spacers
Hi,
I bought a set of wheels and got them to the tire shop today to get them fitted and the person said they are rubbing on the inside edge(they were good when we checked with just the wheel but after having the tire mounted on it, it didn't sit flush) and I can't use them, So I am thinking may be I can use spacers to resolve this problem.
I need your help guys in finding the right spacers, have any of you guys used spacers and if so did you have any problems after having them??
Is it recommendable to use spacers, since these are Hub centric wheels do we have problems like the normal wheels??
Please advice
2006 650i-Blk on Blk
Old 04-15-2011, 04:28 PM
Mein Auto: 650i
The Tire's I have are the stock one's 245/40/19 and 275/35/19 and the wheels I bought are same as stock Bolt Pattern of 5*120, Rim Diameter and width of (19*8.5 and 19*9.5) with Hub Bore of 72.56, except for the offsets are ET18/ET20
so please advice on what kind of spacers I can use and is it reliable to use spacers
Old 04-15-2011, 08:12 PM
yamahoe72 yamahoe72 is offline
Mein Auto: 645 ci
I have spacers on mine. 10mm front and 12mm rears. My 20" wheels are ET20 front and rear.
2005 BMW 645 ci - Matte black 20" M6 replica wheels/10mm and 12mm spacers/ Britalman cat back exhaust/tinted tailights/red calipers/H&R sport springs/Arc Audio amp/1 Kicker 12" L7
2002 Cadillac Escalade - Veloche Vellano 24x10 wheels/2 Kicker 12's/Arc Audio amps/chrome billet grille
2007 GMC Yukon SLT - all stock!
Old 04-16-2011, 04:35 AM
incorrigible incorrigible is offline
539 South!
Mein Auto: 08 650 Conv
Now, this depends on the "back of your wheel offset" and not all wheels are identical. After I swapped wheels but kept stock tires the fronts rubbed on the strut. I ran (literally) down to the local speed shop and he had some universal spacers, somwhere between 5 and 10 mm. Slipped em in and was able to go. I then ordered H&R Spacers hub centric 10mm all around (front and back) and they filled in the gap without causing a wheel/fender collision. QUality spacers are important as the universals are not guaranteeing a balance. I did need longer lugs - pay very close attention to the warning on the box and make sure you have enough lug getting into the hub threads, otherwise disaster can result! I am contemplating replacing the 10mm rears for 15mm...
08 Stratus Gray
Cream Beige/Dark Wood
HUD/Night Vision
Lane Departure
Passport 9500CI w/GPS
Resonator delete & added "X-Pipe"
Current Toys:
Sea-Doo RXT-X aS 260 (supercharged, intercooled, Fox Shock Remote Res suspension) handles chop like a dream!
Ski-Doo Renegade X ETEC800 & MXZX 800
Kawasaki Brute Force 750i 4x4
26ft Hurricane w/twin Yamaha 150 Outboards
Toy-Hauler Ford F250 QuadCab
Previous Toys:
2004 M3 SMG
40 foot Mainship Sedan Bridge
Yamaha GP 1300R waverunner
Old 04-16-2011, 05:52 AM
Mein Auto: 650i
Thank you so much for those replies and based upon that I am considering one of these, please look at the link below it's from the local shop in my city and I am thinking of buying the
http://www.tulipcitywheels.com/tcwst...uct_list&c=706
10mm Hub Centric Wheel Spacer, BMW, Pair, 5x120mm, 72.6mm Centerbore, Flat - SP80B
or
5mm Hub Centric Wheel Spacer, BMW, Pair, 5x120mm, 72.6mm Centerbore, Flat - SP55120
let me know if I made the right choice and which one should I buy 5mm or 10mm, and I also might have to look at the longer lugs as you might have mentioned
Old 04-16-2011, 07:01 AM
539 South!
I think in the DIY section there is a how-to on measuring for spacers. 5mm isn't much and while it may solve the rubbing problem they may not make much of a difference aesthetically. I am considering buying larger ones than the 10mm I have for appearances.
08 Stratus Gray
HUD/Night Vision
Lane Departure
Current Toys:
Previous Toys:
2004 M3 SMG
Old 04-16-2011, 07:45 AM
Mein Auto: 650i
but if I push it out too much will it make the tire rub on the outer edge??
Old 04-16-2011, 07:50 AM
mpc1971 mpc1971 is offline
Mein Auto: 645i vert
mate,
just used an online wheel n tyre offset calculator
assuming your oem fronts are as mine and a 14 offset
and assuming your new wheels are the 18 offset then your wheel is sitting 4mm closer to the suspension strut. so a 5mm spacer will take it back to more or less oem.
but this 4mm shouldnt really rub.
if your front offsets on new wheeels are 20 then the wheel will sit 6 mm closer to the sus. strut..
personally i would go with 10mm spacers, fill them arches and get rid of any rubing for sure
measurements taken from http://www.rimsntires.com/specs.jsp
hope it helps
Old 04-16-2011, 08:27 AM
Mein Auto: 650i
Thank you so much for the quick reply
Old 04-16-2011, 08:43 AM
no problem, we gotta help each other out where we can and stop the stealers robbing our mods money
next i gottta stop people getting robbed for brake pads and rotor changes . this is so easy to do it makes me how much they charge. more so here in the u.k than the states from what i understand
good luck with the wheels and remember pics , pics, pics
Old 04-16-2011, 01:32 PM
Mein Auto: 650i
You are so right!!!, I went to store this morning but guess what there was not store in that area..looks like they went out of business, and no other store in Town does the spacers, So my next best bet I am thinking is to buy the spacers online and get them done myself, I am not sure on how good it's gonna turn out to be...keeping my fingers crossed here
Oh by the way did I mention the new wheels I am doing are the Matte Black M6 Design and I am changing the front grille to matte black as well
So I am thinking of buying some 10mm spacers for both front and rear, please let me know of any websites that sell some good stuff and if I have to change the lugs, then where can I get an appropriate set of longer lugs for both and front
Thanks!!
Old 04-16-2011, 02:16 PM
Yorgi's Avatar
Yorgi Yorgi is offline
You need longer wheel bolts if you use spacers larger than 5mm.
Here are a few good places to order them from:
Turner Motorsports
Rogue Engineering
EAS
JleviSW
Most performance parts places sell spacers. I like H&R spacers the best but Rogue and Macht Schnell are good too.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 04-17-2011, 08:48 AM
Mein Auto: 650i
Thank you!
Old 04-19-2011, 09:11 AM
Mein Auto: 650i
The Tuner Motorsports said something about compromising the safety when using 10mm spacers, I tried to understand it but I am not really good when it comes to cars and not able to understand it, can you please explain it what it is that I am jeopardizing or should I just go for 12mm or 12.5mm and if I am doing what are the things that I have to considor....please advice
