Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 6 Series
6 Series
The BMW 6 Series builds on BMW's sporty heritage with aggressive lines and an incredible motor to back the design up. Available in coupe and convertible trims with a standard 4.8 liter engine producing 360 horsepower and 360 lb-ft of torque, the 6-series is a popular choice that exceeds expectations.
Old 04-16-2011, 07:12 AM
incorrigible incorrigible is offline
539 South!
Mein Auto: 08 650 Conv
Uneven rear tire wear common?
Bought my 08 w 11k miles and during the wheel swap I noticed uneven rear tire wear - these tires are almost shot on the INSIDE. Is this common or were the wheels mis-aligned at the factory? Thanks in advance for anyones replies.
ID:	274910   Click image for larger version
08 Stratus Gray
Cream Beige/Dark Wood
HUD/Night Vision
Lane Departure
Passport 9500CI w/GPS
Resonator delete & added "X-Pipe"
Current Toys:
Sea-Doo RXT-X aS 260 (supercharged, intercooled, Fox Shock Remote Res suspension) handles chop like a dream!
Ski-Doo Renegade X ETEC800 & MXZX 800
Kawasaki Brute Force 750i 4x4
26ft Hurricane w/twin Yamaha 150 Outboards
Toy-Hauler Ford F250 QuadCab
Previous Toys:
2004 M3 SMG
40 foot Mainship Sedan Bridge
Yamaha GP 1300R waverunner
Old 04-16-2011, 08:23 AM
AFCNEAL AFCNEAL is offline
Mein Auto: 645 E64
Run-Flats?
Yep - usual issues! Get rid, save 50% and more life in each tyre and better ride!
Old 04-16-2011, 09:25 AM
650 Ryder's Avatar
650 Ryder 650 Ryder is offline
Mein Auto: Dinan///M3 - Countryman S
I wouldn't call it normal. It's more of a tire pressure issue. I got great life out of my tires.......only changed the rears and that was around 35k if I remember correctly. Turned the car in at 39k..........Phil
2011.5 Dinan ///M3:
SSII DCT
Comp Pkg
Conv Pkg
Premium Pkg 2
Heated Seats
Enhanced Premium Sound
Black Kidney Grills
BMW M Performance Steering Wheel
BMW Carbon Fiber Performance Spoiler
BMW Aluminum Pedals
Dinan Exhaust
Dinan Mid Racing Exhaust (x-pipe)
Dinan Carbon Fiber Intake
Dinan Racing Middle Exhaust Software
Dinan Pulley Kit
Dinan CH-R Wheels
Dinan Carbon Fiber Strut Tower Braces
Arkym Front Lip
Carbon Front Reflectors
Lux H8 V3
Brembo 365mm BBK
Old 04-16-2011, 10:37 AM
JPEG23 JPEG23 is offline
Mein Auto: E63
It is normal but preventable. The camber on the 6ers needs to be adjusted to factory specs, quite often(6months-year) or you'll go through tires like water...just another preventive maintenance thing.
Sent from my iPhone using BimmerApp
6 series - Sapphire Black w/ 22" Beyern Mesh wheels
Old 04-16-2011, 01:36 PM
Yorgi's Avatar
Yorgi Yorgi is offline
I would get an alignment and also check the condition of the bushings in the rear suspension. When bushings start to wear you can bad toe-out during acceleration which will give you a narrow band of tire wear like in your pics.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
Old 11-27-2011, 05:54 PM
marty123$ marty123$ is offline
Mein Auto: 650i
Dealer says I need a $350 " dynamic balancing " ??????
Old 11-13-2012, 11:05 AM
richardp3 richardp3 is offline
Mein Auto: BMW 650i
I know this is an old thread, but thought I would add: I've replaced my rear Bridgestone Potenza Run Flat's 3 times in the last 2 years, getting almost exactly 8,000 miles out of each set. Classic BMW in Dallas performed the alignment when the tires were changed. I took it to a non-BMW german service garage, and they said the camber was adjusted correctly, but the toe was drastically out and was causing the tires to wear one inch of the inside down to the threads while the rest of the tread remained. He corrected the toe and said he feels confident that he's fixed the tire wear problem. We're going to check it in 3,000 miles.
I called Classic BMW who told me that the factory setting for the toe is aggressive for good handling and that's the way they set it. I was told "Some M cars are having their tires replaced every 7,000 miles". Well, I suppose that's great for Classic BMW's tire sales. I made my tire wear concerns known, and they still set it to max tread wear. I'll try to come back and update whether the new alignment cures my tire wear problem.
