E90/E91/E92/E93 (2006 - 2013)
Does the N54/55 engine run a vacuum?
Racing engines run a vacuum, something to do with oil lubrication + horsepower gain, but I don't understand why, or whether the N54/55 runs a vacuum.
Suspect they do, as the dipstick, a potentially large leak, has been scotched. Some engines have vacuum pumps. BMW mechanics, what can you tell us? . Last edited by CALWATERBOY; 04-19-2011 at 09:07 PM. |
Sounds like you're speaking of crankcase vacuum.
If so, this is an old old trick. It's used to alleviate the pretty nasty parasitic horsepower loss due to oil "windage", or oil being whipped up into long ropey strands that tangle up with very fast-spinning crankshaft when the engine is running at high RPMs. Decent oil control + little/no air = little or no windage.
Don't resent growing old. Many are denied the privilege. -- Irish Proverb |
its a forced induction engine....
Here you go Cal:
http://nutterracingengines.com/racin...uum_facts.html They talk about what you were asking about.
Somehow BMW moves air + fumes from the crankcase to incoming air [crankcase ventilation]. A centrifugal separator's built into the engine to pevent oil from leaving the crankcase and 1) coking incoming air valves at the cylinders 2) burning oil So, how is crankcase gas made to move? |
when the engine is under boost, the crankcase is pressurized. vacuum for the brakes is provided by an aux pump.
see here: http://www.n54tech.com/forums/showpo...80&postcount=1 |
If I remember correctly, the crankcase is not under vacuum and the dipstick has nothing to do with BMW removing it. The 335d has a dipstick, does it not?
08 E90M3 6MT Alpinweiss/Schwartz |
N54/55 operates @ what pressure? Anyone? |
Honestly, I don't believe BMW uses this trick with the N54 or N55. I doubt they even use a windage tray.
So, to answer your question CAL....I think 1 atmosphere, or about 15 inches of mercury.
But what if boost is generally higher than normal - read just about any 335i tune? Not heavily modded - those engines are known to have intake valve coking / crankcase vent blow-by issues. Talkin' average schmos w/JB3/4....? Of interest, believe Audi supercharged engines were known to coke valves. Maybe that's solved? Westy-West? Last edited by CALWATERBOY; 04-20-2011 at 08:53 PM. |
Here's what Terry says @ N54Tech.com yesterday, post #15, high noon, regarding vacuum and crankcase ventilation:
IMHO there is no reason to expect massive amounts of blow by unless there is a ring sealing problem.Terry's no poseur - over 20K posts there! ![]() ![]()
Wait, I think we (you vs everyone else) are talking at cross-purposes here.
I (we?) were talking about using crankcase vacuum to gain horsepower. You're talking about ways to minimize oil contamination on the intake valves/combustion chambers..... The N54 guys worried about the latter usually use a catch can.
An engine using centrifugal separation of liquid [oil]/gas needs gas exiting the engine @ some velocity, provided how? If blowby's minimal, then is gas extracted, creating negative crankcase pressure? Blowby + extraction? . Last edited by CALWATERBOY; 04-21-2011 at 04:12 AM. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
