Old 04-19-2011, 11:41 PM
rashid rashid is offline
Mein Auto: X5 E70, 4.8 - 2010 White
E39 Auto Transmission Shift Problem
I have 2002 530i (E39) automatic and having a problem of late shifting from the third gear sometimes. When I pull away, it will shift from 1st to 2nd normally. Then it will only shift up from third at 4000 - 5000 RPM, to the 4th gear. This has been going on for months and has been a minor inconvenience but I want to fix it now before getting bad
Can someone help?
Old 04-20-2011, 01:25 AM
edmonem's Avatar
edmonem edmonem is offline
Mein Auto: 97 528i
does it feel like it is struggling to shift into 4th like its slipping? kinda sounds like the same problem i had? i wonder if this is a common problem with the auto tranny? check the other thread about somewhat the same problem.its titled something like transmission wont shift in D or something like that....here http://www.bimmerfest.com/forums/sho...d.php?t=371867
BMWCCA member #446696
aloha state
Old 04-20-2011, 04:06 AM
Jimmys 530i Jimmys 530i is offline
Mein Auto: 2003 530i
This seems to be a common problem on these cars. I noticed that faulty transmission computers or the ABS unit usually cause the symptoms you have described.
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03
Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02
