Old 04-20-2011, 03:53 AM
Calleros5079 Calleros5079 is offline
Mein Auto: BMW 750LI 2008
I Need to change cooling on my 745 li Any instructions any one?
Hello I need to change the anti freeze on the 745 li,any instruction or video from some so I can follow? Thank you in advance
Old 04-20-2011, 05:02 AM
***CCCP***'s Avatar
***CCCP*** ***CCCP*** is offline
Major
Mein Auto: 745 li
Go to INDY and let them do it. They will drain the whole coolant and properly bleed the system. I'll have to do mine in a bit.
Old 04-20-2011, 06:54 AM
MakaveliFaison's Avatar
MakaveliFaison MakaveliFaison is offline
Mein Auto: Bmw E64/5, Maserati GT
If you do it yourself put the car on a ramp and remove belly pan. Drain plug will be on passenger side of radiator. Takes a while to drain. Did my friends 750. And I had to do mine when I installed new ALTERNATOR.
650i sport hud ac schnitzer eibach resognator delete m6 quads akebonos
Old 04-20-2011, 10:06 AM
muggzytx muggzytx is offline
Mein Auto: 745li
yeah its super easy i wouldnt waste money taking it to an INDY. Just lift front side of the car remove the belly pan as stated before, they wll be a screw with ridges on it on the passenger side and connected to it is like a faucet knob looking thing where the coolant will come out of. Put a pan directly under that and turn the ridge looking screw till you see a full stream of coolant, Let that drain for a good 30-40 min and go have a couple beers. Come back screw the pin back shut, fill up the reservoir with coolant, then after that massage the lower,upper radiator hose and any other hose that has coolant flowing through it for a minute or two, you should hear it gurgling as air is released from the system, now you should be able to pour more coolant into it, after you top it off again, go into the car put the car into the accessory position, turn AC on and turn the heat to 90 on both sides but keep the fans as low as possible for about a minute or two, you will hear more gurgling coming from the reservoir. After that check reservoir, fill again if needed, turn car on, let it run for a minute or two and then put the cap back on and your done! Check level again when car is dead cold and top off to max line. Hope this helps!
Old 04-20-2011, 11:40 AM
Muggsy just summed it up step by step. That's all! Good luck!
Old 04-20-2011, 01:33 PM
***CCCP***'s Avatar
Major
Mein Auto: 745 li
Ok I agree lol what he explained is very easy but how about all the coolant that stays in the engine I was doing my friends e38 not a while ago what ever I drained from radiator was only half coolant that is in the system. So if ur only doing half job what's the point. They had couple diy for e38. I don't see any for e 65/66.
Old 04-20-2011, 05:10 PM
What's Indy? Sorry sorry for my ignorance
Old 04-20-2011, 05:14 PM
Thank you for the advice
Old 04-20-2011, 05:45 PM
745LI 4 AJ 745LI 4 AJ is offline
Mein Auto: 2002 745LI
INDYWALLET! J/K...Independent BMW Mechanic/Specialist, other than the Dealer.
BMW 2002 745LI Toledo Blue...Moz Riviera 22" Staggered Wheels...MTEC 2.1 Angel Eyes...NGK Laser Platinum spark plugs...MTEC D2S 6000K...MTEC H3 4350K Fogs...ACS Roof Spoiler...More to come ...
Old 04-20-2011, 05:55 PM
Thank you,
Old 04-20-2011, 06:08 PM
Where can I get the antifreeze or what type antifreeze do you recomend I can use?
Old 04-20-2011, 07:38 PM
Expo BMW's Avatar
Expo BMW Expo BMW is offline
Local Enthusiast
Mein Auto: E65,P71 Police Intercept.
OEM only. Don't cheap out. I suspect you haven't done your homework on this car?
. 360infiniteusa Angel Eyes . H&R Springs . mObridge AUX Integration .
Old 04-23-2011, 08:30 AM
Mein Auto: 745li
What kind of antifreeze you put in doesnt mAtter, as long as its not dexcool orange stuff, regular green stuff is fine, keif posted a while back approved antifreeZe from bmw and the green stuff qualified. But to each its own, ive used the green for 50k miles with no prob.
Old 04-23-2011, 06:01 PM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
A sidenote -- unlike most other cars, this car's setup is self-bleeding. As muggzy said, turning on the heater is all you need to do to open all passages.
For bleeding/venting, there is a thin hose going from the driver's side of the radiator across to the coolant reservoir (constantly bleeds the system), and a vent hose from the two heads over to the coolant reservoir (which I'm guessing is at the top of the system).
+1 / muggzy. I use the normal green stuff too, no issues; all the fluids I've bothered to look at meet BMW specs.
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 04-24-2011, 04:15 AM
***CCCP***'s Avatar
Major
Mein Auto: 745 li
Keif good too know thx. But when changing coolant and u drain it from radiator plug at the bottom it's only part of ur coolant system right? What about the rest in the engine and stuff
Old 01-25-2013, 03:04 PM
FinishLine FinishLine is offline
Mein Auto: 745LI
Thermostat fixed it, not a hard DIY project either...why spend for $475 when you can spend $80 and 3 hours taking your time?
Commercial content removed. Please email admins for sponsorship information.
**Installed World's First ipad3 in a C6 Corvette**
Old 01-25-2013, 03:40 PM
pedro2u pedro2u is offline
Mein Auto: 745i
it's always an option to refill with water and redrain
