Just wanted to make a small DIY thread about a problem I had with my steering column not going up or down. I asked how much it would cost at the dealership to fix this problem. They told me that I would have to replace the whole steering column to fix it. They quoted me $800. Well I wasn’t going to pay the dealership $800. You can hear the motor trying to going up and down, when you hit the button. I took off the bottom cover in front of the gauge cluster and then I was able to see some of the linkage and steering column. There is a retainer clip that was stuck and causing the motor to lock up. I took a long screw driver and used a hammer to lightly wedge the screw driver tip into the clip. This was enough to free the linkage. This may not fix every ones steering column problem. But I would try this if you can hear the motor trying to go up and down.
