Old 04-21-2011, 04:55 PM
jimbob2 jimbob2 is offline
Mein Auto: 525i
problems with ccv replacement
The problem I'm having is getting the connector off between the expansion tank and the head, right under the front valve cover. I've searched all the ccv threads and don't see anything about it. just can't get it to release. anybody done this?
Old 04-21-2011, 08:00 PM
Fudman's Avatar
Fudman Fudman is offline
Why would you need to remove this? As I recall, everything associated with the CCV is on the other side of the engine.
Old 04-22-2011, 05:27 AM
Jimmys 530i Jimmys 530i is offline
Mein Auto: 2003 530i
Can you take a picture.
2004 BMW 330ci Silvergray Sport Package, Cold Package, Xenon Headlamps, Premium Package, 6 Speed Manual, Build Date 9/03
Sold - 2003 325i Sedan Japanrot 5 Speed 8k Xenon Headlamps Build Date 11/02
Old 04-22-2011, 07:54 AM
rdl rdl is offline
Mein Auto: 530i 2003
I think the connector you refer to is the one mentioned in paragraph 2 of my post here
http://www.bimmerfest.com/forums/sho...7&postcount=77
I found that I could complete the CCV without disconnecting the 3 plugs and pulling the wiring harnes toward the inlet manifold side.
Regards
RDL
Old 04-22-2011, 02:05 PM
Mein Auto: 525i
Thanks for the responses, I was finally able to get the connector off, it's different than the other connectors because it doesn't have the wire retainer clip, there's tabs on the sides that you have to squeeze together but you still can't pull it off, you have to squeeze and push it off with a screwdriver, I still was unable to pull the connectors completely through the thermostat housing but it gave me some slack. on the problem of getting the "s" tube onto the top port of the valve I found out that you don,t have to rotate the hose to get it on, if you push the connector hard it will snap on without rotating, the problem is being able to push hard enough up under the manifold, I used a screwdriver once I got the connection onto the valve to pop it on from the valve side. the way they designed the lock you have to turn it in the wrong direction to lock it and there not enough room to do that.
Old 04-22-2011, 07:18 PM
Mein Auto: 525i
Got the ccv job done, it's true when they say it's a bi**ch, if I did it again it would only take me half the time, but that's always the way. can't believe how many sensor connections there are. worse part is trying to get the 's' tube and the ccv in place. old ccv seemed to be good at 95k. all the hoses were clear and the valve seemed all right. one thing is the dip stick tube was clogged, if you think you have a ccv problem but don't think you can tackle the job I would at least take that tube out and clean it. it has a connection from the ccv that runs through a baffle in the dipstick. it's has a very narrow passage through the dipstick and clog's easily.
Old 04-22-2011, 07:56 PM
bobdmac bobdmac is offline
Older than old school
Mein Auto: 2001 540i/6, '90 k75s
Thanks for the dipstick tip. Glad you got through it all okay.
BMW--giving new meaning to the phrase "disposable income."
Old 04-22-2011, 10:10 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Now I no longer want to tackle the CCV when I find the round tuit!
Old 04-23-2011, 03:02 PM
repcapale repcapale is offline
Mein Auto: 2014 535 XDrive
Disconnecting this plug was the hardest part of the job for me. I almost gave up. It is just so awkward.
Old 06-09-2012, 09:07 AM
bluebee's Avatar
I came here again searching for a way to TEST for a clogged dipstick guide tube.
As the OP noted, the steel tube going from the CCV lower vent hose to the dipstick guide tube will clog solid.
I wrote up how I cleaned mine (it wasn't easy); and since I'm in a warm-weather clime, I'd guess almost EVERYONE (by now) has a similar problem.
So, if you know how to TEST for a clogged dipstick guide tube (without removing it), that would be a great input to this thread:
- How can we clean out a clogged oil dipstick tube (connection to CCV)?
