E30 (1982 - 1993)
Old 04-22-2011, 06:39 AM
Gammetrunner Gammetrunner is offline
Mein Auto: 1987 325
Intake pictures...
Does anyone have any pictures of their intake set up or the top view of the engines on the M20? I've run into some problems and would like to compare mine to others and see is its set up right or if its been rigged. Here is what mine looks like. I've developed some idling issues and wonder if this set up has anything to do with it. Can't imagine that all those hoses are supposed to be running across the intake.
ID:	275581   Click image for larger version
Old 04-22-2011, 06:43 PM
downhiller's Avatar
livin large
yep thats right. vacuum leak is where to start. just wait til you have to do a heater hose on the back side of the block.
Old 04-22-2011, 06:49 PM
Mein Auto: 1987 325
Can't imagine
Old 04-22-2011, 10:40 PM
Krumchev2's Avatar
Krumchev2 Krumchev2 is offline
Straight Bimmin
Mein Auto: 91' 318ic
Yep I had a coolant leak from that exact hose you speak of. Took me 2 long hours of cursing and frustration before I finally got the hose on and the hose clamp tightened. But besides that yes that vacuum line set up has definitely been rigged like that. Not completely sure why you would run hoses over a hot intake manifold but I guess some people just don't think.
Old 04-23-2011, 08:10 AM
Mein Auto: 1987 325
I'm still trying to figure out if its vehicle specific or not b/c the diagram above shows the hose I'm replacing #11 laying across the intake. Is anyone able to definatively say if this correct. I'm guessin it might be but that the hose itself was just rigged to restict airflow.
Old 04-23-2011, 06:38 PM
downhiller's Avatar
livin large
thats how mine were. that all changed in 88 after eta when the icv got moved to the intake.
