Old 04-22-2011, 11:06 AM
RedSoxGurl RedSoxGurl is offline
Mein Auto: 2000 740il
00 740iL - White smoke. Ahhhhh, what now????
When I start up my baby, either in the morning or after she has been still for about an hour, I get a cloud of thick white smoke from the tailpipe. It smells awful, like burning rubber or something along those lines. It will pour out of the exhaust for about 5-10 seconds, and then stop. help!!!!
Old 04-22-2011, 11:57 AM
FABOCH's Avatar
FABOCH FABOCH is offline
Mein Auto: 2000 BMW 740I SPORT
White Smoke on start up is the classic OSV back cover plate. The IC cover is located and mounted on the back of the manifold. Theres a rubber diaphram that cracks..You`ll have to remove it and there 7 Torx head screws that will make you want to cry...They are hard to remove because they are brittle heads..They strip easily...Removing the Manifold is your best move ..There u can remove the torx heads with Vice grips..Replace the torx head bolts with HEX HEADs instead....I did this ...Also when u install new one make sure u buy the orange rubber gasket...Also theres 4 rubber gaskets on the manifold that need replacing..They CANNOT BE RE-USED...
Torx head bolts that are a PITA
2000 740i Sport , Alpina 21`, Alpina Lip, Alpina Deco kit,Dinan 7,Dinan TB, DINAN CAI, DINAN Exhaust, Dinan Stage 5, Dinan 4/5 transmission, Dinan manifold, Highline individual interior,Eibach/Bilstein,Zimmerman Timing guides 08/13
Old 04-22-2011, 12:08 PM
joyism5's Avatar
joyism5 joyism5 is offline
Mein Auto: '99 740IL, K75RT
Is the engine running hot? Is the smoke just white or white-blueish? Smells like rubber or like burned oil? When it smokes is the engine cold? Oil consumption? Check your oil and coolant levels. Millage on the car?
Rubber smell and white smoke could indicate a failure in your coolant system...Again, is the engine overheat?
Oil smell and white-blueish smoke could be due to a failure in crankcase ventilation system (PCV/rear cover of the intake and related gaskets/seals) or your valve stem seals are very worn. Again, millage on the car?
To better pin point your problem, more information is needed.
Old 04-22-2011, 02:51 PM
The smoke is thick and white, and does not happy when car is fully warmed up. Only in the morning when I start it for work, and if it's been sitting for more than about an hour. The car has 157,000 miles on it. The car does not overheat.
EESH, OSV looks a bit much for me--not mechanically inclined. But hopefully I can find someone to dig into it...
Old 04-22-2011, 04:56 PM
joyism5's Avatar
at 157k miles you could have the crankcase issue as well as the valve stem seals. Similar symptom's. If you running on 0W/5w or synthetic I suggest to move to a thicker (10W/15W) non synthetic and ad some oil additive to it. It work's for me. When the oil is fresh (less than 500 miles on it) the smoking still happens more likely the crankcase ventilation is your issue. If the smoking comes after the oil is worn/used a bit more more likely the valve stem are your issue.
Old 11-15-2013, 10:14 AM
finalapproach2 finalapproach2 is offline
Mein Auto: 1997 740 IL
CCV Valve Fixed Smoking-$60 Part
The CCV valve replacement ($60) remedied the embarassing oil smoke 100%. Its amazing.
white smoke
HTML code is Off
