E34 (1989 - 1995)
Old 07-23-2016, 01:20 PM
BMW_507_4ME BMW_507_4ME is offline
Mein Auto: 530i
Wiper Blade Hits the Hood?
On My 94 530I the P/S wiper blade hits / rubs the hood when in use, waring down both the top of the wiper arm where it mounts on the car and the paint on the bottom of the hood where it rubs. I am planning / hoping to paint my car this fall and would love to know an easy fix. This seems to be a common problem as I have seen it on other e34's. The blade is pressed down on the shaft as far as it will go and the hood has no damage or dents in it.
Old 07-23-2016, 03:44 PM
south26 south26 is offline
Mein Auto: 535i 1989
The bushings are worn out and you have to remove the wiper tranny. It is a pain to do. I do have a good wiper tranny for 40 plus shipping. I am still trying to get to my garage to check for the tan handle.
Andy
Old 07-24-2016, 08:15 PM
Charlygirl Charlygirl is offline
Mein Auto: 1989 bmw 535i
Thanks, I have this issue on my 89 535i E34 too.
Charlygirl
Going through a full life cleanse: getting divorced, getting a new home, getting new cars after being t-boned
1988 Mercedes Benz 300 SE, W126, 185,000 km, Auto, i6
1989 BMW 535i, E34, ~375,000 km, Auto, M30, 3.5L
Old 07-25-2016, 01:13 AM
aliff01 aliff01 is offline
Mein Auto: E34 M20 and 850SE
My wiper blade hits the hood and collides with each other when I put it on the highest speed, is this caused by the wiper bushings and tranny as well?
Old 07-25-2016, 06:17 AM
That sounds like worn bushings and worn wiper arms. If they are hitting each other then they are either not tight or they are worn and they are able to wiggle around and the arms need to be replaced.
Abdy
Old 07-25-2016, 11:34 AM
Mr._Graybeard Mr._Graybeard is offline
Mein Auto: '95 540i, E30, E24
Replacing a wiper tranny is a less-than-joyful experience. I stopped the wiper-hood collision by taking a Dremel sanding drum to the wiper arm to grind down the metal area impacting the hood. You can touch up the wiper arm with some flat black paint if you like.
Old 07-25-2016, 11:56 AM
LOL
Andy
Old 07-25-2016, 08:33 PM
WOW! I'm a girl and I wouldn't do that.
Charlygirl
Old 07-25-2016, 08:42 PM
Originally Posted by south26 View Post
lol
andy
btdt!
Old 07-25-2016, 09:01 PM
If that's the only thing wrong with the linkage, why not?
When the bearings finally seized up in my wiper transmission, I had to dismantle the cowling to replace it -- no options, because the wipers wouldn't move. With my big paws it took the better part of a day. Get a quote on the job from a shop, and maybe you'll find that notching the wiper arm isn't such a bad idea for a relatively insignificant problem.
On another forum I used to frequent, they'd refer to solutions like this as a "kludge." Some people say that's based on the German klug -- translation, "clever."
Old 07-26-2016, 10:19 AM
Mein Auto: 530i
PIA to work on sometimes
I understand, the old "if its not broke don't fix it" of most cars, can be, "if it's not totally broke on your BMW, don't totally fix it" I had my A/C condenser go out on my 740IL and after you remove the, console, air bags, steering wheel, dashboard and on and on, you could get to it, a 18 hour job by the books! It is not just bimmers though, on my 66 GTO it took a total of 10 min. to change all 8 sparkplugs and the points, on my nephew's Cougar, you have to take the motor loose and move it to change 6 sparkplugs.
My wiper bearing has very little up and down play, but no side to side, I was thinking of putting a rubber stopper between the hood and cowl to hold the center of the hood up a few mm to keep it from touching when I paint it, thoughts?
Old 07-26-2016, 10:26 AM
If the stopper contacts painted surfaces, it could wear through the paint as road vibration causes it to shift slightly while you drive. Beyond that, I'd say it's worth a try.
