E34 (1989 - 1995)
Old 11-18-2011, 05:23 AM
bmwrod bmwrod is offline
Mein Auto: bmw 545i 2004
Check crank positioning sensor if its bad or going bad it will cause the car not to start.
Sent from my SPH-M820-BST using Bimmer
Old 11-18-2011, 11:31 AM
Yako2922 Yako2922 is offline
Mein Auto: 1995 bmw 325i
Old 11-18-2011, 11:51 AM
ok i downloaded the manual, but it doesnt seems like is the same car....my car doesnt have relays in the rear right corner, and the ecm is inside the firewall on the passenger side....no next to the strut, my car is 4 cylinders, no individual coil packs, it has spark plug wires, so what engine i have?? sorry for the dum question, but is my 1st bmw and i dont know nothing about it...thanks
Old 11-18-2011, 01:12 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Yako, Yako, Yako ....... You list a 1995 325 in your "Mein Auto" section of your account You didn't tell us you were dealing with a 318. What year is it? Is it an E30 or E36? The E36 Bentley manual will cover the 318 if you have an E36. You can find the link to the Bently manual on the E36 forum or on Google. The things we have mentioned still hold true with the 318.
Steve
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 11-18-2011, 02:26 PM
the year is 95 i dont know which one is sorry like i said im new on bmw the car is automatic and has a button that says auto or manual 2 doors, let me see if i can upload some pictures when i get home.....sorry
Old 11-18-2011, 02:39 PM
BMR_LVR's Avatar
Humble E34 lover
Yeah. You have a 318is. It is an E36. The E36 Bentley manual will cover your car.
Steve
PS: We still want to see pics
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 11-18-2011, 08:35 PM
ok so i work on my car again for a little while, i found the right manual this time so i did couple test and i feel like im getting closer, coils have power and resistance is good, relays are good and fuses are good and getting power, so i have to check the crank sensor and cam sensor, BUT i can find the connector, some one knows if i have to remove the intake to get to those plugs? i trace the wire and it just vanish under neat the intake, i cant really see where it goes, it has a little black box there, i work on my car at night when im back from work so is kinda hard to trace those wires, i believe my cps is bad
thanks guys
Old 11-19-2011, 02:20 AM
Banned
Mein Auto: car
thanks guys
You don't need the caM sensor checked. Check the cranK sensor alone. You don't need to remove the intake but you might need slender hands to get under all that.
Old 11-19-2011, 10:21 PM
hi guys good night, i didnt work on my car today since i work on my other one lol... anyways i been thinking all day long about my no spark and no fuel issue, so i just wanna make sure i did all right, so in my ewsII I cut the thick wires and put them together and then i cut the green solid, my dme is gray label, so i just wanna make sure i dont have the security system activated, i try to get codes from check engine cell pressing the gas pedal 5 times but there is no codes, it dont do nothing, also my hazards wont work, i was reading in other treats and there mention something about the hazards, anyways i dont think hazards have something to do with my non spark and fuel issues, im going to check my cps tomorrow, i just need to know if there is some way to check if the security system is disabled, i was thinking.... if ewsII works for the starter only some one can just push start the car and get it running? sorry for sooo many questions but i swear i have nightmares about my electrical issue lol pretty much i took my whole car apart (dash, harness, ecu and all that) hoping to find just a bad wire lol thank you guys
Old 11-20-2011, 08:25 AM
BMR_LVR's Avatar
Humble E34 lover
Hey Yako. I know that you read my thread about the EWS delete and my no-start saga. You confirmed that you have the silver label DME so that DME is specific to your car.
You absolutely have to check your CPS. Remember, it should read 540 ohms +/- 10%. If the CPS is out of specs, then I would recommend that you get a new one (I would get one off of a reputable site like BAVauto or RMEuropean, etc. and not from Autozone or the like), return your wiring to the stock configuration and then see if the car will crank. If it cranks, then you’re good to go.
If your CPS is within specs and the car still will not crank, then I highly suspect that your DME is bad (which was my case as well). Since you have already modified the wiring, you only need to find a red label DME and put it in. Keep in mind that it may take a little time to get it running depending on how long it has been down. It may also knock a little in the VANOS if it has not been run in a while. Don't worry, it will resolve with a short amount of driving. Just run it easy until the knock goes away.
Hope this helps. Make sure and post back what your CPS ohms out at.
Steve
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 11-20-2011, 08:55 AM
BMR_LVR's Avatar
Humble E34 lover
Yako (and others), I just remembered something on the DME swap. Since you have the 95 model, it has VANOS and you will need to replace the DME with a red label from a VANOS equipped engine. This should be build dates of 9/92 - 12/94 with a part number of 0 261 200 413 (also known as the red label 413). Non-VANOS equipped engines (M50) use the 0 261 200 402.
Here is a good write up from Pelican Parts regarding the DME. It is for the E36, so the pics show where the DME is on the E36.
One of the main things to look at is the compatibility chart. That's golden when you need to find a used DME. Notice that the DME for the E36 is not necessarily the same for the E34 with the same M50 engine. You have to really look at what you have to find what is compatible.
Steve
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 11-25-2011, 01:31 PM
supertech777's Avatar
supertech777 supertech777 is offline
Mein Auto: 1995 525i
Originally Posted by BMR_LVR View Post
Even though this relates to an E36, I’m posting it here because it has the same M50 engine and electrical system as the E34.
This is the story of a BMW lover’s journey through diagnosing and fixing a no-start situation. First of all, I want to express a sincere thanks to a fellow forum member, Roberto Baggio (aka RobertoBaggio20). I would have neither had the courage to do this nor would I have had the information necessary had it not been for Roberto. He found a link to a fellow that had information about bypassing the security system on the car. If I did not have this, I would not have been successful. So again, thanks Roberto.
My E36 would not start about 6 months or so ago. I was in no hurry to fix it as this is a spare car. I probably would have been done a lot sooner, but I had to have knee surgery in early December and that really slowed me down.
Now, on to the story. I have a 1995 325is with 236K miles. This has been a very good car and has only had about 4 no-start situations. The first was a failed fuel pump. This was before I joined the forum or knew anything about working on BMW’s. I had it towed to a mechanic. He diagnosed it and replaced the fuel pump for around $400. I had an old 85 Mercedes 300D that I was not a bit afraid to work on. I would adjust valves and service the transmission etc., but I was always intimidated about working on the BMW’s because (I’m almost embarrassed to say this) I could not even find the darn spark plugs! I know, it was silly, but all I would do at first is change the oil. Anyway, I found Bimmerfest and as the saying goes, the rest is history.
The second no-start situation was a bad fuel pump relay. By this time I had found out about the Bentley manual and was well on my way to becoming a much more savvy DIY’er. I removed the air filter and squirted a little starting fluid into the intake. It started for a couple of seconds, but would not respond to the throttle. I made a fused jumper with an on/off toggle switch per Bentley instructions and jumped the fuel pump relay socket and the car started and would run just fine. I replaced the fuel pump relay and all was well.
The third no-start situation was about 1 ½ years ago. At that time, I had followed my usual daily routine and turned the key to crank it, but I “stuffed it”, meaning I didn’t let it fully catch before I let go of the key. After that, it would not crank. The first thing I checked was the fuel pump relay, but that was not the problem. I went through the usual routine of checking things, but it just wouldn’t crank. I had no fault codes stored in the ECM. I messed with it for about an hour but it still would not crank. On the last try, it coughed a little and finally cranked. The frustrating part was, I never did figure out what caused it to not crank.
I continued to drive the car for another year with no problems. Then one day (a couple of days after a rather heavy snow fall), the wife got in the car and it wouldn’t crank. It would turn over, but it would not catch and run. So, I started the usual process of diagnosing it thinking that it would be an easy fix. I was so, so wrong. First, I checked to see if the fuel pump was working. I pulled the seat and confirmed that I had voltage at the connector. I plugged it back in and proceeded to remove the fuel pump relay and use my jumper that I had made per Bentley specs. Sure enough, the fuel pump purred like a kitten. So, while the fuel pump relay was jumped, I tried to crank the car. It still would not start. Now I was thinking that I may have an electrical problem. However, to try to rule out a fuel delivery problem, I got out my trusty can of starting fluid. Yes, I know, one should not use much when attempting to start the car. It still would not crank with the starting fluid. Now I realized that I had a no-spark situation. I had never dealt with this on a modern car. I started doing research on the forum and Google. Next, again wanting to do the easiest thing, I put in a new DME relay and a new fuel pump relay. Still it would not crank. I checked the relay sockets (once I learned how to pull them up to get to the bottom of them) and they all seemed fine and had no corrosion.
I remembered a problem about E36’s having a “wet DME” problem. So, I opened up the DME compartment, but it was dry as a bone. Next I suspected a failed crankshaft position sensor (CPS). I checked the resistance and it was about 500 ohms. Well, Bentley states on page 120-6 that it should be at 1280 + or – 10% (BTW, I found out later that it was a misprint in Bentley. It should have said 540 + or – 10%). So, I was way off or so I thought. I thought, okay, that must be it. I found a used one at a junk yard and bought it. When I got it home, it too was at about 500 ohms. I thought, great, now I have two bad CPS’s. But it just seemed to defy the odds that two CPS sensors would be bad. So, I tested the one on my E34. What do you know? It too was about 500 ohms. I thought, well, if I put the used one on it and it doesn’t crank, then I still can’t say for sure that the CPS is not the problem because I can’t be sure if the used one is good or not. So, I took the CPS off of my E34 (because I knew it was good since that car was running) and put it on the E36. It still would not crank. I put the original CPS back on and returned the borrowed CPS back on the E34 and it promptly fired up (remember this part for how it plays out later in the story).
Now I was becoming really frustrated and felt that I was reaching the limit of my knowledge and ability regarding diagnosing the problem. Just for kicks and giggles, I replaced the plugs. After all, they had (ahemm, clears throat) at minimum, 138K miles on them, but obviously they would not all fail at once. I decided to check the coils. They were getting proper voltage and had resistance within specs per the Bentley. But, I had no spark with trying to crank the car.
At this point, I basically narrowed the problem down to the DME. That’s usually not a big deal right? I mean, after all, you just go to a junk yard and get one or buy one on Craig’s List. So, I started my research. Well, I was not too happy on what I was finding. You see, the 1995 325 is a unique car in that it is the first year that BMW put the EWS II security system on the car. This is a system whereby there is a very small chip in the ignition key. There is a EWS antenna ring around the ignition tumbler. The DME is paired with the key and the EWS module. When the proper key is inserted, the antenna receives the signal from the key chip, it is sent to a unit that amplifies the signal. That signal is read by the EWS module which communicates with the DME and gives the go ahead to allow the car to crank. If the incorrect key is used, then, when the key is turned, all of the gauges and such will come on, but the engine will not turn over. This was confirmed when a while back, I had the very early stages of the dreaded “key spin”. I tackled it as soon as I had the first signs of it so it was not bad to do. Anyway, I replaced my ignition tumbler and forgot to install the antenna ring. I tried to start the car and nothing. I just about left a big brown spot in my underwear until I realized that I forgot to re-install the antenna ring. Once I did, the car cranked fine. Whew!
Now, back to the story. The DME that is in my car is what is called a “silver label” DME. It is specifically for the EWS II car. So in researching, I found out that my options were pretty limited and the cost of repair was going to be quite a bit. A re-manufactured silver label DME was going to be almost $1200 from the dealer and on top of that, I would have to have the car towed to the dealer to have the new DME “re-coded” or “re-synched” to my specific car. Needless to say, I did not want to chunk down this kind of money on a 15 year old car with 236K miles. So I also looked into having mine re-built. I came across these guys at bmwdme.com. They will test the DME for $50. If there is no problem with it, they send it back to you after you pay the $50. If it is bad (assuming it is not massive damage from a fire, drowning or severe electrical shorting), they will repair it for $475. This was certainly better than the approximate $1300-$1400 it would cost with a remanufactured one (taking in to account the tow and labor at the BMW dealership for re-synching it).
Here is where Roberto really came in to the picture. He was kind enough to research this problem for me (without me asking him to do so BTW). He came across this fellow’s blog. His name is Richard. Here is the link: http://qcwo.com/technicaldomain/ews-deletion-chip. He communicated back with Roberto and advised that a standard “red label” 413 DME (for the 1992-1994 M50) would work if the EWS system is bypassed. Roberto forwarded the information to me. I started my search for a red label DME. I am located right between two gold mines in the form of Pull-A-Part junkyards. There prices are unbelievable. A DME would cost about $30. Only problem is, people know this and the on of the very first things that gets snagged is the DME. So I constantly searched for a red label DME. One day they put a VANOS M50 E34 on the lot. I got there the very same day, but the DME was gone. I also searched Craig’s List. I finally found one from a 93 325i and got it for $60.
I had to remove the glove box to access the EWS module. Bentley leaves out one important information about a bolt that holds the glove box assembly in the car. It is a 10 mm bolt that is located above the glove box light. Pop the light out and you have easy access to it. Locating the EWS module was the next challenge as there are several modules in there. The instructions given were to cut wire #4 (green) and then cut and bridge wires #1 and #3. The wires are not labeled this way so it was a challenge to figure this out as well. With the assistance of the wiring diagram in the Bentley manual, I was able to determine which module it was (it was the module in the lowest bracket with a yellow connector) and locate which wire to cut (the green #4 wire is the very small, solid colored wire), and which wires to cut and bridge (#1 is black/yellow and #3 is green/black).
I consider myself an electrical moron, so I have to tell you, I was scared to start cutting and bridging wires. So, I cut the green wire #4 and capped off each end. I then cut wire #1 and #3 at the EWS module and spliced them together. I put the red label DME in the car. I turned the key and the dashboard lit up as usual, but the engine would not turn over. Remember me mentioning how the EWS was activated when I forgot to put the antenna ring back on the ignition tumbler when I replaced it? Well, I knew that the EWS was being activated because it was the exact same scenario. So, I also spliced wires #1 and #3 on the DME side as well. Again I tried to crank the car. This time the engine would turn over, but it still had no spark and would not crank. Now I was really ticked off and thinking that I had no chance of fixing this thing. So, I just put the wiring back to as it was from the factory and I put the silver label DME back in it with the intention of having it towed to my mechanic.
By chance, I thought I would get a used camshaft position sensor and replace it, but to my understanding, a bad camshaft position sensor will not cause a no-start situation, but can cause the car to run poorly. So, off I went to the Pull-A-Part and found an M50 that had had the intake removed, so it was a breeze to pull it. Due to weather and issues with my knee, I didn’t work on the car for a couple of weeks. The other day it was nice out and my wife was doing some things and I commented to her that I had just decided to have it towed to my mechanic. My fear is that he would spend a couple of hours (at $80/hr.) just to diagnose it and he may well say it had a bad DME. So I would then have to send the DME off for a $475 repair. As I told her this, she said “what about that wire you bought?” I asked “what wire?” She said “you know, the one you bought at the junk yard the other weekend.” I was like “oh yeah, the camshaft position sensor I pulled at the Pull-A-Part”. So, I opened the hood and began trying to figure out how I was going to get the VANOS off so I could remove the sensor. As I looked around, I saw an electrical connector under the intake manifold that was not connected.
I traced it and found that it was the connector for the CPS. Remember earlier in the story when I took the CPS off of my E34 and put it on the E36 and it still would not crank? Earlier when I was swopping the CPS from my E34 to the E36 and it didn’t work, I proceed to take the CPS back off and put it back on the E34. I bolted the original E36 CPS back on the front of the engine at the toothed wheel. Well guess what, I didn’t re-connect the sensor (doh). I was like, “well crap, that explains why it wouldn’t crank with the red label DME”. Just for kicks and giggles, I re-connected it and tried to crank the car with everything stock (silver label and stock EWS wiring set up). But just as expected, it would not crank and seemed to have no spark. So, I proceeded to do the red label DME swap again. I put it back in and re-did the EWS delete wiring bypass.
I tried to crank it again. It would not crank, but sounded like it wanted to. So I tried a one second squirt of the starting fluid in the intake at the MAF. I tried again and still no start, but it sounded like it wanted to crank even more. So, what the heck, if one second is good, two seconds should be better right? So, I gave a good two second squirt and tried again.
It did not crank up immediately, but just like something winding up, IT FINALLY CAUGHT !!!!. It ran rough for a couple of seconds, then smoothed right out. I didn’t let it run long because I had not yet filled and bled the coolant system. I shut it off and waited about 5 minutes. I tried it again and it cranked up immediately. So in the end, it was the DME that was bad and the red label DME swap into an EWS II equipped car does indeed work. After about 6 months, the lifters were noisy on start up. This was due to leak down of the lifters over time. Also, the VANOS was rather noisy. After bleeding the coolant system and making sure everything was okay, I took it out for a short ride (7-8 miles) without revving beyond 2500 PRM. By this time the lifters had pumped back up and the VANOS quieted down.
Here are some morals of the story that I learned:
If you have the desire, persistence, a good repair manual, some decent tools and some basic mechanical skills, you can do most anything on the BMW’s (well, at least the older models like E36, E34 and earlier). Realize however that you may have limitations on your abilities. I’m not at the point that I would feel comfortable doing and R&R on a head gasket or head. Sometimes you just have to take it to a mechanic.
Don’t be afraid to ask for help from other BMW owners who may have experienced the same problem. Listen to their input. This forum has some of the nicest and most knowledgeable people around.
Be willing to do research on the problem. Remember, Google is your friend. Search it and search this forum as a lot of the problems have been experienced before.
Don’t just throw parts at a problem. Try to be methodical in your approach. Think things through thoroughly. If you get stumped or frustrated, take a step away from the vehicle (sounds like you’re being arrested lol) and take a break. Take time to “re-charge” your batteries so to speak. Sometimes during that break a moment of clarity will come that will point you to the problem.
Always double check your work. Had I realized that I failed to re-connect the electrical connection side of the CPS, I would have had the car running a couple of weeks sooner.
I hope this long winded dissertation has or will help someone who faces a no-start situation.
Best regards,
Steve
dear steve , since this was a 3 series , would the splicing of these wires work on a 1995 525i with a ews 2 ? and the cutting of the solid green wire you mentioned is that on the DME side or all 3 of these wires are on the ews side ? thanks Noel
Old 11-25-2011, 07:19 PM
BMR_LVR's Avatar
Humble E34 lover
Hello Noel. The EWS II was the same on the E36 and the E34. The only difference is the location of the EWS module (behind the glove box for the E36 and under the driver's side kick panel on the E34.
I have read on the E36 forum IIRC, that in order to bypass the EWS, one only needs to clip the small solid green wire. All you do is clip it and cap off each end. It doesn't have to be bridged so it doesn't matter which side. I assume this would be the fix for a failed EWS module. However, my problem was a failed DME (silver label, thus specific to my car) and I had to do the full wiring modification (cut the green wire and cut and bridge the other two) in order to put in a red label DME.
I guess it depends on what the problem is in your car (bad EWS Module vs. bad DME).
I hope this answers your question and helps with your problem. I would be happy to hear exactly what problem you are having.
Steve
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 11-25-2011, 10:02 PM
hello Steve thanks for the reply , well it all started when my wife broke down , the steering lock sheered of so in the meantime while waiting on the dealer for the ( ignition steering lock assembly ) I needed to get the car home , if you remember i was getting a wee bit frustrated with removing the ignition tumbler LOL . By the way thanks for the encouragement , like you said sometimes a lot of persistance helps and to mention prayers ..... well i got that out and unlocked the steering collum and removed the EWS2 antennae ring , removed the ignition switch and just had the key inside the ring so it could energize the chip on the key and I used a screw driver to start the engine . did this for about a 2 to 3 days and on the day the steering lock housing came it did not work anymore fortunate for me I was in our garage at this time . now its dead except for all the lights on the dash . so to make sure it was not the starter I jumped pins 1 & 3 on the EWS module and the starter was strong . Oh and I have a fully charged battery , but no spark and no fuel , hopefully it's just my EWS system only ( my quetion is the green wire to be cut , is that on the DME harness or the EWS ? Thanks Noel
Old 11-26-2011, 07:08 AM
BMR_LVR's Avatar
Humble E34 lover
Sorry to hear of your tribulations. I would cut the green wire at the EWS module. I don't think it makes a difference since it simply connects the EWS module to the DME, but I would tend to do it there so that everything is nicely hidden once completed.
If you do that and you still have no spark and no fuel, then I would check the CPS and the main (DME) relay.
Hope this helps.
Steve
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 11-29-2011, 03:36 PM
hello guys, finally i have some time to work on my car, cps is good, so im going to get a red label dme to bypass the ews, so i was wondering what year it will fit on my car and what model, that way i can look for it at the junk yard or ebay, thanks again
Old 11-29-2011, 04:41 PM
BMR_LVR's Avatar
Humble E34 lover
Hey Yako. You will need a red label 413 DME. I'm about 95% sure you can get one from any car with a Vanos equipped M50 engine. I think it is restricted to just the E36 with date of manufacture of 9/92-12/94 or a E34 with a date of manufacture of 1/93-12/94 though. The key is to make sure that the car had the Vanos engine.
Good luck. Hope this helps.
Steve
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 11-29-2011, 04:48 PM
I found one from 94 325i that one works?
Old 11-29-2011, 05:25 PM
Banned
Mein Auto: car
Any red label 325 or 525 ecu for an e36 or e34 will work, as long as it has a red label. If it has a green or silver label, no.
Old 11-29-2011, 05:30 PM
BMR_LVR's Avatar
Humble E34 lover
Yes if it is a red label 413.
Steve
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 11-30-2011, 07:08 PM
Ok guys, so i get a new dme red label today, and still no spark and bo fuel, i cut both thick wires on ews and put them together and i cut the solid green, and still nothing.... Any sugestions after this?
Old 11-30-2011, 11:03 PM
Banned
Mein Auto: car
You need the Bentley manual. It has a checklist. I'll send it to you.
Old 12-01-2011, 05:43 AM
BMR_LVR's Avatar
Humble E34 lover
Were the two thick wires you cut #1 and #3? Did you bridge them on each side (meaning on the DME and EWS module sides)? Is your engine now turning over when you turn the key (meaning is the starter engaging)?
If so, then you have something else wrong such as CPS or main (DME) relay. Take a long look at the Bentley manual that Roberto sent you and read up on how to check them out.
Steve
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 12-01-2011, 08:50 AM
O shi$& that maybe the problem, i cut the wires and i put them together on one end,in the ews side are just disconected
Old 12-01-2011, 08:52 AM
The cars crank and cranks but wont start, i have no spark
