E30 (1982 - 1993)
Old 04-23-2011, 02:48 PM
eieio4tn's Avatar
eieio4tn eieio4tn is offline
BMW...riceless
Mein Auto: 1987 325is
rear end noise suspect
i've been hearing a low rumble from the right rear wheel area of the car when turning slow. rebuilt the brakes, and while bleeding i found this...
kinda guessing this stabilizer bar link might be the problem. but also suspect wheel bearing. is the link a prime suspect ? i know it's not a good thing, and i will order tonite. just wondered if this link would cause a rumble...
Old 04-23-2011, 05:30 PM
downhiller's Avatar
livin large
if it made a sound itll be a knock. and thatll be over bumps
Old 04-24-2011, 05:52 AM
7pilot 7pilot is offline
Git
Mein Auto: 90 Ford Tempo
That is not your rumble.
That causes differences in handling when comparing the chassis behaviour on Left and right turns.
m
Old 04-24-2011, 08:43 AM
eieio4tn's Avatar
BMW...riceless
more of a moaning or rubbing sound than a rumble, but i didn't think this was it.
Old 04-24-2011, 05:27 PM
Krumchev2's Avatar
Krumchev2 Krumchev2 is offline
Straight Bimmin
Mein Auto: 91' 318ic
Wheel bearing I think would make that sound rather than the sway bar endlink being broken
Old 04-24-2011, 08:59 PM
First time's Avatar
First time First time is offline
INSANELY UNPREDICTABLE!
Mein Auto: 2001 540i sport/1994 525i
^ agreed. Just jack the car up (leave the wheel bolted to the hub) and see if you have play in the wheel moving left and right and top to bottom. Excessive play will mean a bad wheel bearing. And judging buy the sounds you are explaining, I would count the end link out.
Old 04-24-2011, 09:04 PM
Krumchev2's Avatar
Straight Bimmin
^also agreed as to how to check for a bad wheel bearing. The endlink would make more of a tapping sound as it bounced up and down and the broken pieces hit each other. A bad or worn wheel bearing would make more of a humming or rubbing sound like you are describing. The wheel bearing would be the first thing I'd check for
Old 05-29-2011, 06:28 PM
eieio4tn's Avatar
BMW...riceless
found it...wrong fluid in lsd. it was getting bad, started sounding central instead of left or right. new lube and lsd treatment and it shut up immediately.
Old 05-30-2011, 12:45 AM
First time's Avatar
That will teach that LSD to talk again! Shut up!
Sent from me, who else?
