E30 (1982 - 1993)
Old 04-23-2011, 04:04 PM
impact audio impact audio is offline
Mein Auto: 1992 E30
2.5/2.7....please help.....
Hello to all.....
I have a 325ic e30 1992 that I broke a valve and broke a rocker arm as well.
The head has a few numbers on the side tha read....1705-885...... I also noticed in a circle on the head that read 2.5/2.7,,,,,
What I would like to know is this the big bore motor and also the 2.5/2.7 on the side of the head mean that I can put a 2.7 head on this motor.....
Please let me know and thank you very much.....
Old 04-23-2011, 05:13 PM
downhiller's Avatar
livin large
how did you break a valve and rocker
Old 04-23-2011, 11:59 PM
Mein Auto: 1992 E30
Thank you for the reply. Well in a nut shell, I was doing a timing belt and I cut the belt to help, well I put a breaker bar on the 22 MM nut on the crank and bumped the starter to free the nut and the bar slipped of the frame and spun enough for the pistion to come up and hit the intake valve and also break one of the rockers as well.....
Old 04-24-2011, 08:54 AM
eieio4tn's Avatar
eieio4tn eieio4tn is offline
BMW...riceless
Mein Auto: 1987 325is
you shouldn't turn anything with the belt off, much less bump the starter. i'd say you are lucky if that's all that was damaged in your valvetrain.
Old 04-24-2011, 02:23 PM
Mein Auto: 1992 E30
Please look at my first thread.... I need to know.....PLEASE and thank you very much and Happy Easter......
Old 04-24-2011, 05:21 PM
anstead610 anstead610 is offline
dream chasin'
Send a message via AIM to anstead610
Mein Auto: 24v e30 -88 toyota pickup
i believe a more common name for what you want to do, mixing the m20b25 and m20b27 is called a "stroker". There are plenty of topics on it on www.r3vlimited.com.
This e30 is now being parted out. NO body panels are for sale, bumpers/fenders/hood/mirrors/valance or front turn signals. Everything else is up for grabs. Euro grills/cluster are sold, suspension/brakes/LSD/rear tails are already spoken for.
Old 04-24-2011, 06:55 PM
Mein Auto: 1992 E30
swap
Thank you and before I forget I own a car audio shop and (please) if anyone has any questions about audio I will try and answer them.....
Thank you tooooo all.....
Lee
