Old 04-24-2011, 10:17 AM
TechFreak TechFreak is offline
Mein Auto: AC Schnitzer 745i Sport
A heads up for older E65/E66's .....Rear Wheel Rattle... found and sorted !
I had a rattle at the rear of my car which i could only hear if i had the back windows open while the car was going over bumps at very low speed......it sounded tinny almost like the Brake Disk Back Plate was loose....
Eventually i narrowed it down to the Parking Brake inside the Brake Disk Hub......
It turns out that the 'Expanding Lock' part number 5 in the drawing below was the cause :
When its dry and worn the spring inside it doesn't pull the Bowden Brake Cable tight enough and it rattles like having coins inside your wheel hub....
My mate slapped loads of grease on it and bent the spring back a little .....lo and behold totally silent now ....
My BMW ACS7
Old 04-24-2011, 10:25 AM
DFEL750I's Avatar
DFEL750I DFEL750I is offline
Mein Auto: 750I
That would be a pain to find out. A lot of guys forget to adjust this when they are changing the rear rotors to make sure that the parking brakes work correctly
Old 04-26-2011, 03:31 AM
mikegoblan mikegoblan is offline
A 7 series Fanatic
Mein Auto: BMW 745 Li
Man you are pure awesome.
It's so irritating that it drives me nuts,
Is it an easy job to do it yourself? or do I need to find someone and spend a 100 dollars on ? because this just drives me crazy to hear it. makes my BMW sounds like a 89 Toyota ( With all respect to Toyota holders )
"It's all about what's worth living for" Quote by me
2003 BMW 745 Li black on black
Old 04-26-2011, 06:14 AM
Tkrtape12 Tkrtape12 is offline
Mein Auto: 745i,FX35,951,ML55
Wow what a great find...thanks for the heads up...
03 745I
87 951 T BLACK
05 FX35 RED
04 ML55 BLUE
08 TrailBLAZER
91 300 ZX TT SOLD
05 A8 SOLD
07 LAND ROVER SOLD
Old 04-26-2011, 07:16 AM
DFEL750I's Avatar
Mein Auto: 750I
If youve doen brakes and rotors before yourself I dont see why you wouldnt be able to give the repair a try or atleast inspect to see if you have a problem. The rear caliper and rotor will need to come out.
Old 04-26-2011, 09:00 AM
Originally Posted by DFEL750I View Post
If youve done brakes and rotors before yourself I dont see why you wouldnt be able to give the repair a try or at least inspect to see if you have a problem. The rear caliper and rotor will need to come out.
DEF750I is correct......only the brake rotor/disk and the brake caliper need to come off (but not disconnected). Nice and easy once youve done it once. If you've not had your brake calipers off before then the 2 bolts that hold it on could be the hardest to remove.
Once removed ....If you flick the Expandable Lock in the parking brake (detailed in pic above) with your finger you may here it rattle ...thats the problem.
My BMW ACS7
Old 06-03-2011, 09:40 AM
Hmmm.......the rattle is back again ....so i'm going to change the 'Expanding Lock' on each side to see if it cures it .....
My BMW ACS7
Old 08-07-2011, 12:27 AM
Forgot to update this thread ....
I fitted new 'Expanding Lock's' on both sides and everything is nice and tight now ......Rattle gone !!
My BMW ACS7
