Old 10-15-2012, 03:47 PM
wjjklj's Avatar
wjjklj wjjklj is online now
Certified 7
Mein Auto: 2004 745i
Originally Posted by casper004 View Post
We toke belt off turn engine it turns left and right with no problem. We then tryed turning alt pulley not spinning at all locked in place. We then checked starter its getting 11 volts try starting with belts off still nothing.
Sent from my HTCEVODesign4G using Bimmer App
Bad Alternator. If you decide to rebuild it I have a brand new voltage regulator for the original Valeo unit. You would just need brushes then and a rebuild place to do it.
Old 10-15-2012, 08:12 PM
DFEL750I's Avatar
DFEL750I DFEL750I is offline
Mein Auto: 750I
Did you have a booster on the car when you were trying to start it? Maybe battery is dead? If the battery is not dead and the starter is not even turning over the engine then most likely you have burned out your starter likes SFBAY said...listen to him...he knows what he is talking about
Old 10-15-2012, 08:30 PM
wjjklj's Avatar
Certified 7
His starter may indeed be bad but if his alternator pulley will not turn with the belt off then it is most likely fried too.
Old 10-17-2012, 01:42 PM
casper004 casper004 is offline
Mein Auto: 745i
Heres the deal. We changed the alternator Did not start so we changed the starter car is turning over but still will not start. New alternator and starter but still wont turn over. Wants to start but not. Any ideas of what it could be now.
Old 10-17-2012, 02:07 PM
SFbay SFbay is offline
Mein Auto: BMW 745i
What do you mean?? Will it crank?? Battery is ok?
Old 10-17-2012, 02:18 PM
Mein Auto: 745i
It is cranking ,battery is good was on booster the whole time. But still not starting.
Old 10-17-2012, 02:48 PM
Mein Auto: BMW 745i
Well if it's flcranking it means your engine is not stuck which is a very good sign.
Now you should read errors, or simply check if you have spark and fuel pressure. When it's cranking do you smell gas from exhaust?
Old 10-17-2012, 03:02 PM
Mein Auto: 745i
There are only to codes passenger side airbags and parking brake malf.
They were on before this problem. Hook up no codes. Or Im sure if car is responding to
The ecu. Will check spark plugs and Pay more attention for gas smell.
Is there a way to reset the computer?
Old 10-17-2012, 03:27 PM
PAPER's Avatar
PAPER PAPER is online now
CRISP & CLEAN
Mein Auto: 745LI
Clear the airbag fault. ..
Sent from my GT-N7000 using Bimmer App
If you need a Custom 2013 DVD Navigation Map
East or West for your E65 E66 PM me for price .
Or if you Need an AUX Plug for your car hit me up
Old 10-17-2012, 03:41 PM
Mein Auto: 745i
Even with it on car was running Fine. Will see if we can clear it
Old 10-17-2012, 04:59 PM
Mein Auto: BMW 745i
Side airbags?? Which one exactly?? There is a fuel pump relay in one of them, if it's shot your car won't start.
Do a simple test:
Open your air filter box and spray some carb cleaner or they sell smth for that while it's cranking, if it starts it's your fuel pump issue.
Ps. Should I charge for free advice?
Old 10-17-2012, 05:13 PM
MINI+BMWtek MINI+BMWtek is offline
BMW master tech
Mein Auto: e30 318
Do a cas- DME calibration with a BMW tester,battery clamps tight, check fuses and review all work performed maybe you forgot something go to SBSR Check fuel pump speed and amps
Sent from my Nexus One using Bimmer App
Old 10-17-2012, 05:25 PM
Mein Auto: 745i
SFbay Man u are on point. Maybe u should. Lol I will do that i the morning and give
The results
Old 10-17-2012, 05:27 PM
Mein Auto: 745i
Minibmwtek. Will try it out. Thanks guys
Old 10-19-2012, 02:54 AM
Mein Auto: 745i
While lastest update. Car still not starting after trying all advace. Car is currently at dealer to get to the root of the problem. I'll keep all postes on results as soon as they call me today. Worse or all its my bday and I have to real with this.
Old 10-19-2012, 08:27 AM
Mein Auto: 745i
Car went into safe mode and locked down. the whinning noise was from the ignition being off center. Dealer reset problem car started right up. Cost $105 happy as hell right now.
Old 10-30-2012, 11:36 AM
ctjames3 ctjames3 is offline
Mein Auto: 2006 750li
car won't start
Hello, I have a2006 750li, when I try to start, everything lights up but the brake pedal does not depress and the car will not start. Anyone have any idea what's going on. thanks
Old 10-30-2012, 11:57 AM
alpinaman24's Avatar
alpinaman24 alpinaman24 is offline
what amg?
Mein Auto: 07 B7,91 735i , 91e30sold
brake light switch
Old 10-31-2012, 06:32 AM
MassGuy74 MassGuy74 is offline
Mein Auto: 2007 BMW 750i Sport
I have an 07' 750i Sport and the exact same thing happened to me this morning. The car started fine. I stopped at Dunkin Donuts to get a coffee and when I came out - it wouldn't start back up. All the lights were on, nav, everything. I called AAA and after about 25min of waiting, I tried to start it again and it started.
What I did notice prior to it starting, it was saying that the transmission would be in "safe mode" or something like that. But like I said, it did end up starting and running fine.
So - what would be a culprit of this?
Thanks in advance!
Old 10-31-2012, 09:16 AM
what amg?
yours sounds like starter
Old 11-01-2012, 06:01 AM
Dammit!
Oh well, dropping off at Indy today or tomorrow.
I'm in the Lexington/Waltham area of Mass. Has anyone had any experience with Auto Engineering of Lexington??? I know there are a few shops within a 5 mile radius of me - but this place is literally 2 miles away.
Old 11-01-2012, 08:18 AM
what amg?
i have no idea about up there but i know shops in Cali
Old 11-01-2012, 10:10 AM
Mein Auto: BMW 745i
Sounds like brake switch is bad. Probably some water got there, very common
Old 11-01-2012, 10:28 AM
Will it dry out? Or will it need to be replaced?
We did have some serious weather out here recently? Between the portion of Hurricane Sandy we got hit with, then the following nights some additional terrential downpours.
Where is the switch located?
Thanks!!!
Old 11-09-2012, 08:21 AM
wjjklj's Avatar
Certified 7
Car won't start
I had my car running great after installing a new alternator, water pump, thermostat, radiator, belts, and hoses. I did have a fault error 8E111 though that I wanted to check out. I ran Dashsoft and INPA. I didn't see anything out of the ordinary except that I need to inspect my parking brake. I turned my car off and then did the transmission reset by holding down the gas pedal for 25 seconds with the key in the ignition and foot off the brake. When I tried to restart the car just cranks and cranks but won't start. Any ideas? I hate to tow it to the dealer.
