E30 (1982 - 1993)
Old 04-25-2011, 09:30 PM
needshave needshave is offline
Mein Auto: 89 325
2 bmw's - now what!
Over a year ago, I inherited two BMW's that have been in the family since new. A 87-325 ic with 52 k miles and a 89 with 32k miles, both are actual very low mileage cars. Both are setting in the garage with every tire flat and dry rotted. They are beautiful cars but have been setting for years. I'm getting ready to start on the 89 first and of course before I can even turn her over, I need to replace the timing belt. i know that most of the rubber air inductions parts are toast. they all need replaced, all are cracked. Both cars are in a nice dry garages and have been lovingly cared for until late.
Located in central Ohio, I'm looking for a reference sheet or diagram that might list all of the suspect rubber hose and assemblies (part numbers or reference information) that I might be able to source on the internet. Also if there is someone that you might recommend as a cost effective vendor or someone in the mid ohio area that might give some guidance to someone that has never worked on a BMW, and at first site, it doesn't look like it is going to be all that easy a repair. Yikes.
Your thoughts will be greatly appreciated. I'm anxious to get started. I have wore out a pair of shoes walking around them until I finally now have them and can start. Thanks for any advise.
Old 04-25-2011, 09:38 PM
fcsteve's Avatar
fcsteve fcsteve is offline
610EUROs
Mein Auto: 90' 24v, 89' 325is
realoem.com will show you exact parts diagrams with individual part numbers for everything.
pick up a Bentley service manual for the e30. you can get a Haynes manual as well but the Haynes isnt nearly as good.
i normally shop online at Pelicanparts.com but there is a huge amount of parts dealers for these cars.
if you want to lead the orchestra, you must turn your back on the crowd
build: http://www.bimmerfest.com/forums/sho...d.php?t=382667
Old 04-26-2011, 07:11 AM
Mein Auto: 89 325
89 bmw
Thanks for the Info, that helps a great deal. I got the car up off the concrete this morning tires dry rotted beyond belief. I believe they are the orginals. Looking at engine comaprtment and the timing belt change, does it make sense to pull the hood of the vehicle or not. I'm going later this afternoon to see if I can find a bentley service manual. Thanks again.
Old 04-26-2011, 02:03 PM
noexceptions325's Avatar
noexceptions325 noexceptions325 is offline
East Bound And Down
Send a message via AIM to noexceptions325
Mein Auto: 325e,Jeep,240z,528i
^ taking the hood off HELPS ALOT.... but you dont "have" to
Built 325e too much to list, Heavily modified Jeep, Datsun about to get a 351, and now a 528i
Old 04-26-2011, 02:54 PM
fcsteve's Avatar
610EUROs
taking the hood off can also lead to hours and hours of trying to re-align it at the end of which you might not get it to sit perfect again. if the hood hasnt been previously removed and the motor isnt coming out i wouldnt go that route at all.
Old 04-26-2011, 02:59 PM
Mein Auto: 89 325
89
Thanks for the insight. I could see where that could be a real problem. Having said that do you pull the rad and work from underneath. I dont was to risk damage to the rad. Thanks for the advise. Going to post some pictures of the 89 the day I got her. She looks very sad.
Old 04-26-2011, 03:37 PM
fcsteve's Avatar
610EUROs
i work from the sides of the bayand through the rad support under the front of the hood.
Old 04-26-2011, 04:53 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
You will have to pull the radiator to do a timing belt. It would be impossible to do it with that installed
E30 above Sold
E34 V12 Project Thread Here: http://www.bimmerfest.com/forums/sho...=502437&page=4
Last updated 2nd January 2014
Old 04-26-2011, 06:35 PM
eieio4tn's Avatar
eieio4tn eieio4tn is offline
BMW...riceless
Mein Auto: 1987 325is
oh, to to get such project cars...you sir are fortunate. best of luck.
Old 04-26-2011, 06:40 PM
charlesberry's Avatar
charlesberry charlesberry is offline
Mein Auto: E46 944 Turbo
Good God Man we need Photos!!
Old 04-27-2011, 05:37 AM
claver claver is offline
Mein Auto: 1997 328i
+1 on the photos
Old 04-27-2011, 01:53 PM
Mein Auto: 89 325
Thanks, I will get some pictures posted shortly. The rubber under the hood, is not looking good on the 89. All of the air intake rubber interfaces must be replaced. I also found that a disconnect switch had been installed in the battery cable in the trunk. Spare is new, never been down.
Old 04-28-2011, 08:10 AM
leecrosson leecrosson is offline
Mein Auto: 1972 2002, 1987 325iS
disconnect switch = unresolved battery drain.
(or would someone opt for a switch for storage only? seems a bit silly)
Old 04-28-2011, 10:37 AM
Mein Auto: 89 325
I was concerned when I saw it.. Both cars have it(87 and 89) is this a real or common problem with these models. I would love to hear some comments on this if anyone has any experience with this potential problem.
Old 04-28-2011, 02:05 PM
I don't think any worse than any other german car. I tracked one down last fall to the auto antenna - some years of neglect before I had her left the antenna not wanting to retract after shutting off. disconnected the harness that powers the motor and she was right as rain.
But then again, if it's holding a charge it doesn't really matter.
Old 04-28-2011, 07:53 PM
Mein Auto: 89 325
Picture.....
Making an attempt to attach some pictures, as I promised, of the 89 as I found her. Many years of dust on her, but at least she was inside and heated. If posting the pictures actually works, I will send some more...Sorry, my first attempt to post a picture. Car is extremely straight and the interior is beautiful.
Thanks for the information about the potential of battery drain.
ID:	276581   Click image for larger version
ID:	276582   Click image for larger version
ID:	276583   Click image for larger version
ID:	276584   Click image for larger version
Old 04-28-2011, 10:22 PM
mzambrana78 mzambrana78 is offline
Mein Auto: 1985 325e
I buy all my parts from autohausaz.com fast reliable and best prices anywhere
Old 05-01-2011, 11:00 AM
Mein Auto: 89 325
Thanks for the info on the parts house, I will check for their web page.
I have the 89 up off the concrete on jack stands, pulled the front rim/tires and had new rubber put on. The rear wheels is another issue. With the car in the air and the lugs off, I can not pull the rims off the car. I can't separate the wheels from the axle assembly. With tires totally dry rotted and flat I can't beat on the tires to separate them, Any Ideas? I have soaked with penetrating fluid/oil.
Old 05-01-2011, 02:11 PM
hornhospital's Avatar
D'oh, You Kids!
Use one of these, and hammer the rim top-bottom-front-rear alternately until it breaks free.
Name:	4 lb dead blow hammer.jpg
Quotes to live by:
