Old 04-26-2011, 07:12 PM
skinchin13 skinchin13 is offline
SittinRock
Mein Auto: 1996 BMW 750il
Rear differential fluid change
Hey i have a 96 bmw 750il with 201600 miles and was wondering how and if i should change the rear differential fluid.
Old 04-26-2011, 10:03 PM
PETER NEWMAN's Avatar
PETER NEWMAN PETER NEWMAN is offline
Mein Auto: BMW 635 CSi BMW 730i E38
I recommend changing the diff oil every 80'000 miles as it has a very hard life but you must make sure that you use the correct oil, in the uk i use castrol oil which i buy from a specialist oil supplier, jack up the rear of your car and drain the oil out when it is hot, caution undo the filler plug first so that the oil runs out smoothly and then refill, i recomend that you replace both of the plug washers.
Old 04-28-2011, 07:13 AM
SittinRock
thanks i guess i will have to search around on the internet. Does the dealer provide diff fluid. and is it really expensive
Old 04-28-2011, 08:18 AM
joyism5's Avatar
joyism5 joyism5 is offline
Mein Auto: '99 740IL, K75RT
Take a look @ this :
http://www.e38.org/gsussman/differen...uid_change.htm
Good Luck!
Old 05-02-2011, 01:58 PM
SittinRock
Thanks joyism5. helped alot i couldn't find the weight of the oil anywhere.
Old 05-04-2011, 09:55 PM
sgh1345 sgh1345 is offline
Mein Auto: 89 E34 525i 5sp
gear oil
are you kidding how can you not find 7590 gl5 synthetic its everywhere if there is no bmw dealership go to gm and buy it lol it's freaking everywhere every truck uses it well almost.
Old 05-05-2011, 12:24 PM
balance balance is offline
Mein Auto: 97 740iL
I changed mine with factory fluid from the dealer. If I'm remembering right, it only cost me about $35 since it took just a little more than a quart.
I still have some of the factory stuff left over, and it is as thin as tranny fluid. Not sure if this helps.
Old 09-25-2011, 06:28 PM
rufredbird rufredbird is offline
Mein Auto: 01 740i Sport, 00 528iT
I use the REDLINE brand and change my DIFF and TRANS fluids every year!
Old 09-26-2011, 07:44 PM
SoCal740 SoCal740 is offline
Mein Auto: 00 e38, 95 e34, 94 e36
trans fluid in a 740 hu? funny cause every one I ve changed I use BMW hydrolic oil, and if your in there, change the trans oil filter as well, and youll need to order a new gasket, they are paper so you have to, if you have never changed an oil pan, and if you dont know how to properly fill, dont try it, you will make your tranny slip...
Old 09-26-2011, 07:45 PM
forgot what I was getting to, use a good synthetic oil, dont go cheap, it doesnt take alot so there is no reason to go cheap.
HTML code is Off
