E30 (1982 - 1993)
Old 04-27-2011, 12:22 PM
Michael Sotomay Michael Sotomay is offline
Staudman
Mein Auto: 325I Convertable
Speedo!!
I have a 1987 325i with a bouncing Speedometer...I would like to fix that...
The face says electronic..what are my options...I have a Chilton Manual..and pretty good mechanical skillz...but this is my first foriegn car...Used to street a 1969 Camaro Z..
Assistance appreciated
Mike S
Old 04-27-2011, 03:58 PM
downhiller's Avatar
livin large
thatll be from a voltage jump from either the alternator or the sensor at the tranny, loose wires, bad ground. so any way you look at it, itll most likely be an electrical issue
Old 04-27-2011, 06:20 PM
anstead610 anstead610 is offline
dream chasin'
Send a message via AIM to anstead610
Mein Auto: 24v e30 -88 toyota pickup
i'm willing to bet it's your wires connecting the plug to your differential.
This e30 is now being parted out. NO body panels are for sale, bumpers/fenders/hood/mirrors/valance or front turn signals. Everything else is up for grabs. Euro grills/cluster are sold, suspension/brakes/LSD/rear tails are already spoken for.
Old 04-27-2011, 09:37 PM
First time's Avatar
First time First time is offline
INSANELY UNPREDICTABLE!
Mein Auto: 2001 540i sport/1994 525i
^uh huh.
Old 04-28-2011, 08:44 AM
Staudman
Speedo
I should also mention the odo isnt working..The speedo wires go to the rear diff???Damn!THats different!
MIke
Old 04-28-2011, 09:06 AM
Burning2nd's Avatar
Under the lift arms
I've had this issue for years but I know what my problem is I'm just to lazy to fix it .... check the connection at the rear then the connection in the cluster ...... leave your alty alone
send from space command
15486372<-----
Old 04-30-2011, 12:06 AM
dream chasin'
MIke
Your odometer runs off your speedo. When your speedo doesn't work your odometer doesn't. It's most likely the wires connecting it to the differential like I said earlier. Clean them up or get a new plug. My wires were frayed apart leaving 2-3 wires attached which was not enough connection. Rewired it and works like new. Took about 5 minutes.
