Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 04-27-2011, 12:49 PM
DylanT DylanT is offline
Mein Auto: 1986 BMW 325e
Clutch Master Cylinder will not bleed
The other day I was driving and my Clutch peddle hit the floor and didn't come back up. Every one I talked to told me that it was most likely the Master Cylinder. After a long and painful struggle the Master is in. Now on to Bleeding it. I open and completely removed the plug on the bottom of my slave and no fluid is coming out. The res is full and I can pump the clutch as many times as I want and still no fluid comes out, any ideas?
Old 04-27-2011, 02:20 PM
Okay I finally got the whole system to bleed but now when I press in the clutch it sounds like there is air in the Master and it still hits the floor and doesn't come back up.
Old 04-27-2011, 03:55 PM
downhiller's Avatar
livin large
pressure plate bad
Old 04-27-2011, 03:57 PM
Have you seen it before?
