E36 (1991 - 1999)
Old 04-27-2011, 02:31 PM
edirty4and6 edirty4and6 is offline
Mein Auto: 90 525i 92 325is
m50nv to s52
This all started because 2nd gear in my trans on my 92 325is decided to give up on me. So what better an excuse than to buy a trans that comes with a s52. Alright i'm going to get an s52 trans driveshaft dme harness and tons of other goodies on saturday and plan on swapping the engine in within the next month or so. I have searched multiple websites and have come to a general conclusion but, i want to clarify everything with the wonderful people of bimmerfest. The s52 is an obdII out of an 97 m3. So i want to do the obdI swap since i have the manifold from my original m50. So in order to do this swap i also have to purchase an obdI harness and a red label 413. Then get a chip from trm. Do i also need knock sensors from a obdI vanos motor or can i source all the other parts from my m50nv(OBD I Crank Sensor ,Cam Sensor, Fuel Rail). Is there other components i am missing? If my engine/car was a vanos motor basically this swap would be easier on my part but, i don't really care i just want to understand everything fully before i have dead car on a lift and have to push it in and out every weekend. So any info would be great i have searched this topic as i said with no luck.
Thanks Phil
Old 04-28-2011, 08:49 PM
Really? no one?
Old 04-29-2011, 03:54 AM
Spinning Vinyls
Mein Auto: e39(01) e36(97)
Headache
send from space command
01 540I
97 328is
live Thursday and Saturday night
www.ukbassradio.com
Old 04-29-2011, 07:50 AM
noexceptions325's Avatar
noexceptions325 noexceptions325 is offline
East Bound And Down
Send a message via AIM to noexceptions325
Mein Auto: 325e,Lifted Jeep,240z
pretty sure the ecu out of a 95 M3 will run the S52.. but yeh you will need to chip it
there are EXTENSIVE threads on this topic use the Search button
(1986 BMW325es -MSD ignition coil/ebach springs/bilstein sport shocks/Ireland Engineering sway bars/K&N air filter/"high flow" cat/dodge shadow radiator/ANSA resonator/3.46 LSD/CERAMIC brakes/Dinan chip/Shaved Head/Ported Intake manifold) = sex on wheels
Old 04-29-2011, 08:11 PM
crisscross's Avatar
crisscross crisscross is online now
Just living MY dream
Mein Auto: 1995 M3 Boston Green
Search on bimmerfourms or m3forums, they would have more info regarding the swap.
-Alan
Member #2 of the Boston Green Mafia BMW-CCA #457574
1995 BG M3 2000 TiAg 4.4l X5
-I do the things today that others won't do, so I will have the things tomorrow that other won't have....
325is, m50nv, non vanos to vanos, s52, swap
